Question about Garden
Hunter tc3250 won't turn - Garden
2 Suggested Answers
  • 98 Answers
SOURCE: Hunter tire machine, TC3250 bead breaker has no
Check the filter that is in line with where the air line hooks up . it could be restricting your air flow.
Posted on Jul 23, 2009
My control won't activate the light on my Hunter fan. The light comes on via pull chain fine, and the control works the 3 speeds on the fan, but the light won't respond.
Check the wiring on your receiver to make sure the light wire is connected.You have to have the light on with the pull chain and then use the remote to turn it on/off.
Jan 06, 2013 | Hunter 52" Ceiling Fan With Light And...
Hunter fan light switch won't turn off light
by looking at the sw. it looks like u can only put it to a low dim and not off and the button at the bottom is all off including the fan if this is correct u should be able to change to a different kind of fan sw. combo or even a remote style that comes with a receiver ,also your fan should have three wires at the box a light wire "blue" a fan wire "black" and a neutral "white" oh and a ground "green" in order to switch these separate u need those 3 wires at the sw. also . but with a remote u only need the hot and neutral it hooks up in the box or canopy of the fan to the receiver all wires are marked for easy installation turn power off to be safe u can install a regular sw. to over ride the remote and turn power off at the fan .......its alot i know but hit me up if u need more help.
Mercedes Parts
May 25, 2012 | Hunter Ceiling Fan Light Switch Control
Two years ago we redid our kitchen and installed a Hunter fan. About a month ago I pulled the chain to change the fan speed. It must have stripped or something because now that chain won't work at all....
Contact hunter and they will send you a replacement switch.. Its very easy to change. You do not have to remove the entire fan to do so.
Hunter Customer service is. 1-888-830-1326
Hunter does in fact make some of the best ceiling fans there are.
P.S. You might be sure that the chain simply hasn't bound up a bit.. Check to make sure its not hung on something.
Sep 14, 2011 | Hunter Heating & Cooling
The fan sometimes turns itself off and then won't start for a while...it is controlled by a wall switch
there must be loose wiring in switch or in the fan you will need to check the wiring at these two points they may spark and start a fire, if they are all tight your switch may be going bad this atleast is an easy fix, good luck
Aug 27, 2011 | Hunter (25417) Ceiling Fan
Good Morning, I have a Hunter foor standing,
Hi medoody...
Sounds to me like you need to disassemble,clean and oil your fan.
After 5 yrs of running it probably needs it badly.
Please take time to rate me
Aug 11, 2011 | Hunter Floor Stand Fan Stand (Pedestal)
Hunter tire machine, TC3250 bead breaker has no power.. still moves... what next??
May 09, 2009 | Air Tools & Compressors
Progrmmable Thermostate
Check to make sure you have pm or am set correctly. Or reset everything. ??? ;)
Dec 13, 2008 | Hunter Fan Company 5/1/1 Programmable...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
