Question about Vehicle Parts & Accessories
I have a 2007 toyota hilux pick up. I opened the pickup the passenger door with the keys and locked it back with the keys and now the pick up would not start. i looks like a total shot down. what do i do to et it running again
Try disconectigg the battery 4 hlf an hour and c will the brain reset itself
Posted on Jan 02, 2014
5 Suggested Answers
  • 18 Answers
SOURCE: transit doors not locking
james i have had the same problem on a transit an trace the problem in the wiring to the rear right door where the wirin goes through the plastic slider between the door and the vehcle i had to cut out the damaged wiring and run new and solder up make sure the wires you put in are long enough too so you can open the door all the way , failing this think logically which is the door opened and closed the most ,ther might be your prob in the wiring between the door and vehcle
Posted on May 16, 2009
SOURCE: mgf central locking won't open the car doors
I had same problem. It was cured by "flicking" shut the interior opening handle of the drivers door. This allowed the central locking to lock then unlock the drivers door properly. You get into the car in the first place by using the romote to "unlock" and whipping the passenger door open quickly before it has a chance to relock!
Posted on Aug 13, 2009
luke_bradfor
  • 662 Answers
SOURCE: Have a 96 VS holden calais the drivers door
aaahhh...im glad i have someone that gives enough information to solve your proble,......the short answer is the drivers door lock motor.......the info that you provided proves that the remote is communicating with the vehicle, and that the wiring is good and sound......the part that you ned to know and understand is that door lock motors come in 2 main types. Master and Slave.
The back doors are slaves and they do what the master tells them, self-explanatory.
The front doors are masters. On the calais, there is an option for 2 stage unlocking, where one press of the remote opens the drivers door only, and the second press, unlocks the rest commanded by the passenger door, which is a master.
The master door locks have a remote section and a hardwire section. The hardwire section works because unlock/lock of the drivers door commands all the others but the remote section (electric motor - push/pull) is not working, hence it wont work by itself.
get yourself a 2nd hand drivers door lock motor and this will fix all your problems
hope this helps
Posted on Jun 11, 2010
logosc75
  • 625 Answers
SOURCE: I bought a used car
The Camry you purchased may not be equipped with a power trunk. Press and hold the trunk button for appoximately 4 seconds. The trunk should release if the wire is connected and, you have a power trunk.
The Camry (and other toyotas) require a double pulse on the unlock wire. If the double pulse is not programmed the aftermarket unit will mimic the factory keyless entry. One press of the unlock button opens the drivers door. Immediately press the unlock button again to unlock the other doors.
Posted on May 06, 2011
Hi, My 2013 Toyota RAV4 front passenger door lock is caught. It sounds like it locks/unlocks- but we can't get it open-seems caught. How can we fix this? We don't use keys, always have fobs in our poc
SO DOES THE METAL KEY WORK OR NOT?
If the electonics magic fails , this is first., right?
just passenger door?
so locks can jam, and can be very hard to fix.
object stuck there, (closing door with junk in hands)
also playing with latch, by kids can trip it into an illegal mode.
first get it closed, 100% is it.
then use the key, if that don\'t work it needs service.
the key is for emerancies, say baby stuck in car, so..... use it.
Dec 20, 2014 | 2013 Toyota RAV4
How to reset toyota hiluxe airbag lighet
Because there is a;ways an explosion danger, I would not go there. Just ask a Toyota certified repair centre to solve the problem. You never know what is wrong.
Check your manual, if the airbag can be switched off, when you have a baby on the passengers seat. Perhaps that is the problem.
Jul 16, 2014 | 2007 Toyota Hilux 2.7
PICKUP D4D HILUX 2007 STARTS BUT NO REV
Check the throttle pedal sensor.
Jun 01, 2014 | 2007 Toyota Hilux 2.5
How program the key remot
Keyfob remote reprogramming is not very difficult but on some cases it can be done by dealer service tools.If the remote s faulty then keyfob will not get programmed.Insert the key in ignition.Turn the key to on position,and cycle the key three times off-on-off-on-off-on.Then with the keyfob remote select your remote and then try to operate the vehicle with remote.These is just the basic procedure,but sometimes it will not help.
On that case dealer is the only option.
---------There are few very relted troubleshooting links mentioned below for remote key fob reprogramming.I suggest you to go through the list and click the link below to go through its details and procedure:-------
2009 Toyota Highlander: Smart Key Not getting Detected? http://whatisbyme.blogspot.in/2012/05/2009-toyota-highlander-smart-key-not.html
----------2007 Toyota Prius: Reprogram Remote Keyfob? http://whatisbyme.blogspot.in/2012/05/2007-toyota-prius-reprogram-remote.html
----------- Pin that holds the flick key part to the key fob? http://whoisbyme.blogspot.in/2012/07/pin-that-holds-flick-key-part-to-key-fob.html
2006 Toyota Hilux: Programming New Key? http://technoanswers.blogspot.in/2012/04/2006-toyota-hilux-programming-new-key.html
----------Where is Key chip memory located on 2004 ford Freestar? http://technoanswers.blogspot.com/2012/01/where-is-key-chip-memory-located-on.html
----------Ford Keyless Remote Fob Reprogramming?
http://schematicsdiagram.blogspot.com/2011/12/ford-keyless-remote-fob-reprogramming.html
----------After getting car washed, check engine light is ON and key less entry not working, tried reprogramming. Also car shows fuel pressure? http://schematicsdiagram.blogspot.com/2011/12/after-getting-car-washedcheck-engine.html
-----------Audi A8 Key Fob Programming?
http://technoanswers.blogspot.com/2011/12/audi-a8-key-fob-programming.html
Oldsmobile Aurora Key Fob Reprogramming?
http://technoanswers.blogspot.com/2011/12/olds-aurora-key-fob-reprogramming.html
Buick Lesabre Key Fob Reprogramming?
http://technoanswers.blogspot.com/2011/12/buick-lesabre-key-fob-reprogramming.html
Keyfob remote not working on 2003 Ford E350 Econoline?
http://technoanswers.blogspot.in/2012/01/keyfob-remote-not-working-on-2003-ford.html
KeyFob will open the doors but not start on BMW?
http://technoanswers.blogspot.in/2012/02/key-will-open-doors-but-not-start-on.html
Mitsubishi Car Key Not getting detected after replacing ECM http://repairhelpcenter.blogspot.com/2012/11/mitsubishi-car-key-not-getting-detected.html
----------- Key Fob will not lock and unlock doors?
http://technoanswers.blogspot.in/2012/02/key-fob-will-not-lock-and-unlock-doors.html
2000 Jeep Cherokee Limited: KeyFob Remote Not Working? http://schematicsdiagram.blogspot.in/2012/06/2000-jeep-cherokee-limited-keyfob.html
----------- Chevrolet Malibu: Key Stuck in ON position? http://technoanswers.blogspot.in/2012/04/chevrolet-malibukey-stuck-in-on.html
----------- Theft indicator not letting car to start?
http://technoanswers.blogspot.in/2012/02/theft-indicator-not-letting-car-to.html
2012 Dodge Ram: Ignition Key will not release? http://whoisbyme.blogspot.in/2012/07/2012-dodge-ram-ignition-key-will-not.html
These details will help.Thanks.
Nov 23, 2012 | 2006 Toyota Tacoma
Central locking not locking all locks from drivers door, will unlock, but not lock. working fine on passenger door with key, locks all. switch to activate central locking on drivers door unlocks but doesnt...
You will need to replace the driver door switch. You can try to pick a switch up from the dealer or a local car wrecker (i.e. Pick-n-Pull). It will involve learning to take apart the door trim panel.
Sep 05, 2011 | 1993 Toyota Corolla
1992 toyota pickup key code
you can go to your nearest dealer with your vin number and some type of id and they can call and get your key code.and on the passengers side door on the key cylinder lock assembly there is a key code but you have to take the door panel off and take the lock cylinder out to see it.it is a lot easier to get the dealer to get it because they can also cut the key for you while you are there.......i hope this info will help you and good luck.......let me and fixya know how i did and if i can help you any further let me know.......
Jun 20, 2011 | 1992 Toyota Pickup
I have a toyota hilux utility 2000 model. I am trying to open the bonnet to access the battery terminals to power up the electronics as I have central locking and cannot open the vehicle with the key...
Do you have the original key for this vehicle. If so you can unlock the door with this key. Even if the battery is flat. Allowing you to access the bonnet release catch.
Apr 04, 2010 | 1995 Toyota Pickup
1986 Toyota pickup, Hilux fuel pump
NO the problem most likely is your carb. draining down or accelerator pump not working.
Jan 01, 2009 | 1986 Toyota Pickup 4WD
Vehicle Parts & Accessories Logo
46 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
