Kenmore washer manual
Changing out main bearing
Washer stopped working with low humming noise
Belt may have broken or come off, or idler seized or main support bearing siezed or even motor bushings may have seized. Best access is from above to check.
If you can spin the drum with ease from the inside, the belt broke or is off. If it will not turn, the motor bushings may have siezed, or the main bearing siezed.
Apr 12, 2012 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite Oasis Top Load Automatic Washer Model 2708 When spinning it makes very loud noise. Also water leaks out the bottom when in operation
Sounds like the main outer tub and bearing assembly is bad. Water has(is) leaking through the main center seal, through the bearings(noise your hearing is these bearings) The tub and bearings with seal and center shaft come as a assembly, not a inexpensive repair. Also the water is getting on a little electronic board called the roto position sensor which can fail, found as part of the motor assembly on the bottom. Causes corrosion on the connection to the wiring. Your main problem is the outer tub assembly........ Good luck.......(I would also suggest you unplug the drain motor(some have a recirculation pump also) to make sure while spinning empty to run only the main motor that this is for sure the noise and water leak if this is your first repair)
Sep 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Kenmore [2005]front load washer that vibrates severely when in high spin and is quite noisy. I have had the top panel, back panel, and bottom front kick panels off and I can not find any obvious...
you may need to change the bearing on the drum easy way to check is while the door is open try to manually spin it with your hand if you hear a grinding sound then the bearing is gone
Nov 05, 2010 | Kenmore 44102 Front Load Washer
I came across a Kenmore Oasis washer-model# 11027062601 thats noisy on spin.Do you know what they have for a center bearing & seal setup? Rene
First, see the Sears Parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.########) and you'll see a set of diagrams with all the parts / costs for the washer:
Also see the following Whirlpool Service Manual for their Cabrio washer. It's basically the same as the Kenmore Oasis.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Between the two sites, you should be able to determine what the center bearing and seal setup is.
Aug 10, 2010 | Kenmore Oasis HE 27062 Top Load Washer
Kenmore 70 series
hello mam for two years you have not used the washer so the bearings may worned out so lubricate the bearings and check the belt should not have any cracks on it,and after lubricating run the machine without loading clothes the observe the noise if seems to be same then change the bearing to change the bearing call the engineer.
Sep 29, 2009 | Kenmore 24032\24036 Top Load Washer
KENMORE FRONT LOAD WASHER - PULL THE SHAFT OUT OF THE BEARINGS.
NO , if there is damage to the shaft you will need a drum BIG $$$$$$$$
Jan 17, 2009 | Kenmore 43052 Front Load Washer
Bad Drum bearing need part number
Im sorry, but the rear bearings (unless its changed just recently) is a non servicable part, you will have to replace the entire rear tub section. Also, most of the time, you end up having to change the inner tub as well, the shaft is usually wore out as well.
Oct 30, 2008 | Kenmore 43142 Front Load Washer
Kenmore Model 417.44072300 Front Load Washer
Kenmore Model 417.44072300 Front Load Washer Kenmore Model 417.44072300 Front load washer.
The drum is loose. I pulled the back panel off and the nut is tight behind the drum? could it be the bearing? do I need to change the whole drum? is this a common problem or was this do to abuse.
Jul 28, 2008 | Kenmore 46462 Front Load Washer
Washing Machines Logo
184 people viewed this question
Top Washing Machines Experts
