Question about Sony Xperia J ST26I Touch Screen with Digitizer
Xperia j touch calibration - Sony Xperia J ST26I Touch Screen with Digitizer
Touch screen not working properly
Try to enter the following characters into the dialler: *#*#7378423#*#*
There you can test a fuctionality of the touch screen. If it's defective you have to change it. (In Sony service center they can do a touch calibration sometimes it helps)
Oct 14, 2013 | Sony Ericsson SONY XPERIA U ST25i...
My sony xperia tipo(DUAL) touch screen freezes after every 15-20 minutes of standby . plz helpp !!!!
There is a solution by Sony for this problem.
Just follow the instructions: http://talk.sonymobile.com/t5/Xperia-miro-Xperia-tipo-tipo/TIPO-TOUCHSCREEN-FIX-PATCH-HERE/td-p/262920
Sep 27, 2013 | Sony Xperia Tipo Dual ST21i2 Black Android...
I have xperia j.. it needs a hard touch even after updating to jelly bean version 4.1.2
For touch problems you can try to do touch panel calibration:
http://talk.sonymobile.com/t5/Xperia-J/Touch-screen-issue-in-Sony-Xperia-J/td-p/287066
Apr 13, 2013 | Sony Xperia J ST26I Touch Screen with...
I want to calibrate the sensor of my sony ericsson xperia arc s
I don't think there is a way to calibrate this by yourself. I suggest that you get this fixed at an repair center. Contact your local support team for more info.
http://www.sonymobile.com/global-en/support/contact-us/contact-info/
Mar 10, 2013 | Sony Ericsson Xperia Arc S
Touch screen problem
If you're still having touch-screen problems with your Tipo, you might need the screen calibration patch.
Download this file:
http://www.4shared.com/rar/3p6YulVl/ST21i_calibrate.html
The file is the official screen calibration patch from Sony for issues with the touchscreen of the 2012 range phones (I'm 100% sure it works on: Tipo, Tipo Dual, Miro and Xperia J)
Dec 20, 2012 | Sony ST21i Xperia Tipo Black
Sony mobile phone
Sony Xperia x comes with Android OS, v6.0.1 (Marshmallow), Qualcomm Snapdragon 650 SoC, Quad-core 1.5 GHz Cortex-A53 & Quad-core 1.7 GHz Cortex-A57, Adreno 510 Processor, IPS LCD Capacitive touch screen 16 million colors, multi touch up to 10 fingers with Scratch-resistant glass, Shatter proof glass, Triluminos display, X-Reality Engine, IP58 certified - dust and water proof, Water resistant over 1 meter and 30 Minutes, 5 Inches 1920 x 1280 pixels, 32GB Storage, 3GB RAM ans expendable up to 256 GB via microSD Card, 23 MP, 5520 ? 4041 pixels, autofocus, LED flash, 1/2.3 sensor size, ISO 12,800, geo-tagging, touch focus, face detection, image stabilization, HDR, panorama Back & 13 MP, f/2.0, 22mm, 1/3" sensor size, 1080p, HDR Front camera, Sony Xperia x Performance EDGE, GPRS, GPS, Wi Fi, 3G and 4G Android Smartphone by Sony. Sony Xperia Performance Saudi Arabia Price of Smartphone amp Specifications
Sep 07, 2012 | Sony Cell Phones
How to calibrate my screen
Tap the Dice icon. Tap "Settings". Tap "Touch". Tap "Touchpad Calibration." Follow the prompts.
Aug 08, 2012 | Sony Ericsson XPERIA X8 Cell Phone
What does calibrating a ipad mean
Whoever used the term "calibrating an iPad" may have been referring to touch screen calibration.
Some touch screens need to be adjusted, or "calibrated", or the device may act as if you touched a different spot on the screen than you did. The iPad screen does not need to be calibrated.
If the iPad make a mistake about what spot you touched, the error may be due to:
  • a defect or damage;
  • a screen protector;
  • a cold finger;
  • a hand that is holding the iPad and inadvertently touching the screen;
  • a finger that is inadvertently touching the screen.
Apr 26, 2012 | Apple iPad (16 GB) WiFi Tablet PC
Problem with the HP LaserJet 4730mfp All-In-One Printer Unable to use ADF. Red light under start button.
Do the calibration for the scanner.
1. Place letter- or A4-size paper in tray 1, and adjust the side guides.
2. On the control-panel Home screen, scroll to and touch Administration.
3. Touch Troubleshooting.
4. Touch Calibrate Scanner.
5. Touch Calibrate to print the first pass of the calibration target(Print out).
6. Place the first pass of the calibration target face-down in tray 1 so that the arrows are facing into the MFP.
7. Touch Start to print the second pass.
8. Place the calibration target face-up into the ADF, and adjust the side guides.
9. After the calibration target has passed through the ADF once, reposition it face down in the ADF and touch Start.
10. Place the calibration target face-down on the scanner glass, touch Start, and scan the page.
After this pass, the calibration is complete.
Calibration will fails if print quality is not good...ensure that print quality must be in order..
Once calibration successfully done, restart printer several times & verify start button light, if its green every time 'u' re success. if not cleaning required for CCD which is major work & not suggestable..
Aug 30, 2011 | HP LaserJet 4730mfp All-In-One Printer
Sony Xperia J ST26I Touch Screen with Digitizer Logo
149 people viewed this question
Top Sony Cell Phones Experts
M_Butkus
marykitty63
Nagendra Baliga
Are you a Sony Cell Phone Expert? Answer questions, earn points and help others
