Question about Refrigerators
Gasket for h&k freezer
Freezer is not holding temperature. needing assistance in resolving this issue. possibly bad gasket???
  • CoolerGaskets
    CoolerGaskets Jan 06, 2014
    Lindsay call us with your unit's model and serial or profile and dimensions and we can locate a replacement gasket for your unit!
  • CoolerGaskets
    Orders@coolergaskets.com or 855-288-2259
  • Refrigerators Master
  • 9,587 Answers
If the gasket was bad there would be a frost build up on the coils very quickly.
Posted on Jan 05, 2014
I have the GLFU1467FW0 model Frigidaire freezer, and the temperature alarm won't stop going off. How do I flip it off for good? Pressing the alarm reset button does nothing.
Hello Whywhywhywhyshame, thank you for your post!
Based off the information you have provided the temperature alarm on your Frigidaire freezer will not stop going off. This sounds like a possible problem with your sensor or control panel. I would recommend performing a reset on your freezer and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not help resolve your issue I would recommend seeking assistance from a professional technician for proper diagnosis and repair. Hopefully this information is helpful. -Matt
Apr 06, 2015 | Frigidaire Freezers
My freezer has crystalized ice on everything in the freezer. what can i do about it? What is the correct temperature setting for the freezer?
Good Afternoon Friend, that's a great question!
First, try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and the door. Now close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocking by anything stopping it from closing.
If the door gasket is not the issue, then your freezer may possibly be experiencing an issue with the defrost control or have an air leak.
I do hope this information proves to be helpful. - Z
Jul 06, 2014 | Frigidaire Refrigerators
Electrolux dryer has code of E63
Hi
Thanks for using FixYa. Error E63 in your Electrolux Dryer indicates that the temperature inside is too hot/overheating, to start with check the vent and try to clean it. If still it's not resolved then the issue is with the thermal fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 09, 2010 | Electrolux Dryers
I recieved the following error code on my gas range with self cleaning oven... error code E2 F1... PLEASE HELP ME
Hi
Thanks for using FixYa. F1-E2 error indicates that the oven is too hot & the oven temperature sensor has gone bad and should be replaced to resolve the issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 26, 2010 | Washing Machines
Panel says E2 F1
Hi
Thanks for using FixYa. F1-E2 error means that the oven is too hot & the oven temperature sensor has gone bad and should be replaced to resolve the issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 25, 2010 | Whirlpool Ovens
I'm getting fault code f2 reading, do I need to replace the oven temperature sensor or relay board? what part number is this and where is it.
Hi
Thanks for using FixYa. Error F2 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Maytag 24" Built-In Single Gas Wall Oven -...
When I use my oven after it is on awhile it says F3E2 and burns my food. What does this mean?
Hi
Thanks for using FixYa. F3-E2 error means that the oven is too hot & the oven temperature sensor has gone bad and should be replaced to resolve the issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Ovens
We get F3 when we try to set the temperature on the oven. What does F3 mean?
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 11, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
F1-1
Hi
Thanks for using FixYa. Error code F1-1 in your Maytag Gemini Indicates runaway cook in upper oven and to resolve this issue you’ll have to check the oven temperature sensor & replace if it has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 20, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Top refrigeration portion smells like something is burning, warm temperature on top portion, bottom freezer appears to be working, unplugging and switching circuit breaker does not resolve problem, smell...
I need to let you know that your refrigerator may fall under a consumer alert. It is possible that the lights are remaining on while the doors are shut and can result in property damage. The issue is the light melt the plastic and damage the refrigerator, food and possibly smoke damage. If this is not the case please let me know and I will assist you if there is something other that this causing the problem. Thanks Sea Breeze
Oct 29, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
