Question about Husqvarna Garden
I am removing Briggs and Stratton 31A6 500cc engine from a Husqvarna 316AWD ride on mower due to con rod failure. Below the chassis where engine is bolted to mower (with four bolts) there are two drive pulleys that will not come back up if I lift the now loose motor. My question is whether the engine main shaft is splined without being bottled on, or has a retaining bolt under the lower pulley. Theres no gap to access bottom of main shaft anyway or have a look.Appreciate help.
  • John Connell
    John Connell Jan 05, 2014
    thanks. It turns out there is a direct access tube from underneath to the head of the bolt holding on the pulleys. However its blind and a 8mm allen hex does work, nor a 10mm. I am now trying to source a 9mm hex allen socket and a 3/8th in case its imperial. Being briggs and stratton is the bolt holding on the pulley more likely imperial ??
  • Husqvarna Master
  • 2,478 Answers
Should be a bolt hold bottom pulley on. Need a puller pulley assembly off.
Posted on Jan 02, 2014
  • 6 Answers
SOURCE: drive pulley won't come off engine shaft
put the nut back on were it is even with the stud and hit with a hammer while pulling on the pulley
Posted on May 27, 2009
Mrteaze
  • 101 Answers
SOURCE: I am removing the blower fan from the 1
you may need a puller like a pulley puller or something like that if you look at the shaft it should have a convex spot in the middle for the puller to rest on
Posted on Sep 29, 2009
mickey813
  • 472 Answers
SOURCE: Riding Mower Variable Speed Pulley Locked Up. How to remove belts
ya it can be freed up with some W-D40 if you pah the cluch down then try to get the belt off i can get you a new pulley let me know
Posted on Oct 15, 2009
charleshucke
  • 1114 Answers
SOURCE: The main pulley below the motor is split and needs
I would recommend that you remove the deck, when you do you will have an adquate amount of work space. You may want a pully puller to assist in getting the pully off.
Posted on Mar 18, 2011
  • 640 Answers
SOURCE: motion drive belt shredded. what
It is normally threaded, which is to say it has right hand threads. So you will need to turn left to loosen. You can take a block of wood to brace the blade or use vice grip pliers to block the blade. The blade needs to be immobilized to loosen the bolt.
If this is really helpful for you, please rate four thumbs up.
Posted on Jul 18, 2011
I am looking to buy a used husqvarna mower 24hp 48cut turns over but wont start.do you think it will be a cheap fix or will i be wasting money.
it depends on the fault or problem it bears . I suggest to buy new instead of used , because it must be rusted and corrosion so it will continuously give you problems to repair and spending money .
Apr 07, 2016 | Husqvarna Garden
Husqvarna Z246
Husqvarna Z246 Briggs and Stratton Zero Turn Mower ...
? 1:28
https://www.youtube.com/watch?v=Ohx8nxNrgNs
Feb 23, 2015 - Uploaded by SleEquipment
Husqvarna Z246 Zero Turn Lawn Mower 46" - 23 hp Briggs and Stratton Engine: Briggs and Stratton ...
Nov 30, 2015 | Husqvarna Garden
How to remove engine cover?
The engine cover (Briggs and Stratton) is held on by approximately 6 small sheet metal screws. Then it lifts off of the block.
Sep 21, 2015 | Husqvarna Garden
Bolens 42 in riding mower with briggs and stratton
Check the battery and battery lead terminals are clean (wire brush or a scotchbrite) and tight.
Still not working: - then check the battery lead connections to earth (chassis), starter solenoid and starter motor.
Feb 05, 2014 | Briggs & Stratton Garden
Stator testing
I have no idea, if the engine is a Briggs and Stratton take the model, type and code from the engine cover and contact the local Briggs dealer, if it has a Kohler engine parts are available through Husqvarna or the local Kohler dealer, the model no. of the engine will be on the side of the engine cowl
Jun 04, 2013 | Husqvarna Garden
Briggs Stratton 24OHV ELS725
most all small engines have the same bolt pattern but a lot have different size crankshafts i have a 25hp on craigs list in hartford ct farm section
Jul 07, 2012 | Husqvarna Garden
I need a drive belt dagram for a husqvarna yth2348 hydrostatic
Looking at the IPL(exploded parts list) will give you a good look at the route of the belt. Here is a link to use and find your model
http://www.husqvarna.com/us/support/download-manuals/?query=yth2348&types=I&brands=
Apr 20, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
What kind of oil for a husqvarna riding mower?
Yes SAE 30 is the recommended oil for B & S engines. You can find it on amazon for good price. here: Amazon com oil 30w . Hope this was helpful. cheers
Jun 14, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
102 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
