Question about LG 32LX4DC 32 in. LCD Television
Replacement stand base - LG 32LX4DC 32 in. LCD Television
I need a replacement base stand for this tv. Any help with this?
Shop for base stand for tv on Google
Television Stand Assemb...
$15.10
Sears Parts D... Sanus EFAB?B1 ? Modular Aud...
$79.99
Google Trusted StoreThe Simpl... Atlantic Furniture Tabl...
$32.78
Walmart Convenience Concepts Des...
$39.99
Google Trusted StoreWayfair Atlantic Table Top TV Mount...
$24.88
Jet.com Search Results
    Universal TV Stand / Base + Mount for 32" - 60" Flat-Screen...
    www.amazon.com/...Stand-Base...Flat.../B00DZVPFG...
    Amazon.com, Inc.
    Rating: 4.6 - ‎492 reviews
Jan 10, 2016 | Televison & Video
Replacement lcd tv base stand
Contact the authorized dealer for Samsung.
May 01, 2014 | Samsung Televison & Video
I broke the table top base for my new Haier HL32XSL LED LCD tv and can not find a part number or place to order a new one.
If it is not practical to glue the base back together with metal-filled epoxy (e. g., J-B Weld), then consider whether you can adapt the hardware to a custom wood base. If you are not comfortable with your woodworking skills, any cabinet shop could probably make a base for you. Be sure to include space for the base weight in the bottom of the wood plate, and specify that it must be capable of supporting the set. (The entire weight of the set including the original stand is 50.7 pounds; subtract the weight of the stand to find the minimum support capacity.) If the vertical arm broke, it may be better to replace it with steel or aluminum channel or tubing.
If the original stand mount scheme is not amenable to a hardwood base, you can build a stand to use the wall mount holes in the back. Be sure to offset the base weight forward enough so the weight of the mounting bracket doesn't tend to tip the set backwards.
May 24, 2011 | Haier HLH326BB 32 in. LCD HDTV
Lg 42lb5d base stand
Here's a link to order the original LG base stand assembly for this model (42LB5D) from a major parts distributor. Please note, you would have to verify the complete model number of the unit as their are 2 versions availible (there should be either a C or F at the end of the model #):
LG 42LB5DC Replacement Part Base Stand Assmebly
LG 42LB5DF Replacement Part Base Stand Assmebly
Mar 23, 2009 | LG 42LB5D 42 in. LCD Television
I broke the Stand that my 42''LG sits in. I need to buy a new one
You can find a new stand/base assembly for this model at the following link (Please note: the screws used for the base assembly are not supplied, so you would have to reuse the old screws):
LG 42LC2D Replacement Part Stand / Base Assembly
Dec 30, 2008 | LG 42LC2D 42 in. LCD HDTV
Missing LG pedastal
You can find a replacement base stand assembly for that model (42LC7D) at the following link:
LG 42LC7D Replacement Part Base Stand Assembly
Model # RU52SZ30 may have no stand / pedestal available.
Nov 17, 2008 | LG RU52SZ30 52" Television
Akai LCD 27 in stand
According to Akai, the base stand for this unit is not available as a replacement part. You may want to try ebay for a replacment stand.
Apr 15, 2008 | Akai LCT3201AD 32 in. LCD Television
LG 32LX4DC 32 in. LCD Television Logo
15 people viewed this question
Computer Repairing
Computer Repairing
