Question about Neff B1428 Nostalgic Single circotherm Oven
Bumatic ceramic hob keeps tripping mains fuse
Keeps tripping the mains fuse
What is the worst that could happen if an electric double oven ceramic hob had the neutral and earth mains power wired the wrong way round ?
Electronic controller would most likely be damaged and need to be replaced. These things usually cost between $350-$400
Nov 28, 2014 | Ovens Ovens
Fuse keeps tripping
tripping a circuit breaker indicates a dead short or insulation failure
not being able to move the main switch indicates that the contacts inside are burnt together
only option is to call an accredited electrician to test the circuits and rectify the fault
tell him to bring spare elements is case on e or both have burnt out
Mar 27, 2017 | New World Ovens
Hob is tripping fuse box
If the hob is tripping the RCB or MCB on the consumer unit, there is a fault, usually in the elements or halogon heaters, you will need a multimeter to define but please ISOLATE FROM MAINS POWER BEFORE OPENING ANY PANEL
Some electrical knowledge would be helpful, check each element seperatly, you may have to carefuly disconect each heater on the hob, unless you know which blows the mcb, check all connectings to see thay are secure, work round the hab reostates, make sure there is no shorts to ground from elements, with temp control down at zero. Check wiring into mains as a loose connection will cause heat and mcb to trip.
If it is wired into the same outlet as an oven disconnect oven in case the other appliance is causing the problem. it is realy a question of eliminating causes one at a time, working round the affending appliance to define what is the cause.
Hope this is helpful
John
Jun 06, 2011 | Ovens
My glass cermamic cooktop is burned, i mean literally. Its milk stains or sauce stains all over it. And i cant remove it. There are dark brown stains on it. Please help me
try using a ceramic hob specific scraper to removed the burnt on bits then use a ceramic hob cleaner.
Can you let me know what country you are in and I can send you alternative links.
The following link are for the uk.
https://www.bosch-eshop.com/eshop/bosch/gb/ceramic-hob-cleaning-1.htm
311299 is the most cost effective as it contains cleaner and scraper.
Aug 21, 2010 | Ovens
Hob on my hotpoint oven trips my RCD
It is either a faulty ring, or the regulator that controls it is faulty.
You really need a meter to test the ring with to be certain which part is faulty.
Hope this helps.
Feb 21, 2010 | Ovens
I have replaced a Kelvinator hob with a ceramic hob. It works but the owen is not working. What is the problem?
There are possibly a number of options. It could be that in wiring the hob in you have disturbed the wiring for the oven. Normally the oven works off the main oven control switch on the panel and the hob could be wired into something else.
Is the oven totally dead no power at all for everything, or is the clock running but the oven will not switch on?
Dec 29, 2009 | Stoves 720EF Electric Double Oven
Zanussi 360 just tripped and now keeps tripping
You will probably find that it is the oven element that needs replacing, located at rear of oven compartment behind rear panel.
Please rate my solution.
Thanks.
Nov 11, 2009 | Zanussi ZBF360 Electric Single Oven
Samsung PKG001 Stainless steel Single Oven and Ceramic Hob : Hob working ok oven light comes on and fans work ok no display on oven and no heat any suggestions
Had exactly the same problem and just had the samsung engineer out (as it was only 3 months old ) who replaced the thermostat. all is now working ok
Jul 15, 2009 | Ovens
Neff B1428 Nostalgic Single circotherm Oven Logo
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
