Question about MSI Computers & Internet
When i turn my computer on the display comes on for only a few seconds then it says no signal when i restart no display
H55mp31 motherboard
  • 979 Answers
Hello Heidi, you may have two VGA port. my guess is that your monitor is on the main board VGA, remove the VGA connector and locate the other VGA port. usually the graphics CARD. need to connect it there.
Posted on Jan 03, 2014
4 Suggested Answers
  • 5 Answers
SOURCE: computer will not boot up
no most popularly its because u have filled up the ram slots some pc need to have the driveres installed to take the ram try taking all the ram out apart from one stick in slot one the turn the monitor/tv on and then the pc this should work if i dosent then the pc is booting in too high or too low a resilution normaly too low try using a old moniter jst to set the pc up but try the ram first normally works
Posted on Dec 02, 2008
  • 6 Answers
SOURCE: Computer automatically restarts after shuting down
Did you install the drivers for the motherboard already? If so check the connections from the power switch to the board which all should be on the bottom right of your mobo. I switched a + and - one time and it went into a infinite look of turning on and off = / Beyond that ASUS Customer support sucks and I would just try to RMA it and start over.
Posted on Feb 20, 2009
darkhighrise
  • 56 Answers
SOURCE: motherboard turnon but few second after failure
A motherboard automatically turning itself off could be a few problems.
1: Your RAM might not be compatible with each other. If you have more than one stick of RAM, make sure the brands are the same, or are compatible with each other in the least. Also make sure that the type of RAM (DDR3) is the type of RAM you have inserted.
2: Cords. Inside the computer, some of the cord connections might not be properly connected. Check primarily on your HDD, as well as any other main drives you have (CD Drive, Hard Disk Drive, and a Floppy Disk drive if you have it.) Check to make sure all the necessary cords start somewhere in the board, and end somewhere in a place if there is a place for them to end.
3: Power Supply. On most computers that I've used, near the power supply is a tiny little level/switch thing that controls how much power the computer gets. It could be this. If a motherboard is getting more power than it needs, then it automatically will shut off because it has no place to put the extra energy.
Posted on Sep 20, 2012
Como conectar los Jumper JUSB1/JUSB2
USB pinout;
http://pinouts.ru/Slots/USB_pinout.shtml
Motherboard - MSI H55MP31,
http://www.msi.com/product/mb/H55M-P31.html
Hover your mouse cursor on Download.
(Overview, Specifications, DOWNLOAD, Support, Where to Buy)
In the drop down list click on - Manual
Left-click on the Blue, (Azul), -
M7636v1.0_Euro.zip
(Multi-Language - User Manual - Motherboard)
Front USB Connector: JUSB1 / JUSB2 / JUSB3
Shows the pinout.
Regards,
joecoolvette
Apr 18, 2012 | MSI H55MP31 LGA 1156 Intel H55 Micro ATX...
Screen is white will not come on help
Sounds like you may have a faulty motherboard.
Try taking out the battery, disconnect the power. Hold down the power button for 15-20 seconds. Re-install the battery, and see if your laptop boots up normally.
Jul 06, 2011 | Dell Inspiron E1705 Notebook
When OS starts I received an over range signal and my monitor turns black
1. restart your computer
2. change it to safe mode
3. change your screen resolution to lower
4. save and restart . .
have a nice day
May 10, 2011 | Computers & Internet
I have my monitor connected to my laptop because the laptop screen went out. The monitor has been working fine until the last few days but now when I power on the laptop & monitor, the monitor only...
Please restart the computer and go to safe mode by tapping F8 key once the system is restarting choose Enable VGA Mode (Windows XP)
choose Enable low resolution Video (Windows Vsita / 7).
Change the display settings to slightly lesser than what the monitor can handle and shut down and restart the computer in normal mode.
Jan 03, 2011 | Acer X163W 16" wide format TFT Screen 8...
MSI H55M-P31 board & having 2 2GB DDR3 modules and I7 Processors, installed memory on dual channel and sytem beeps 3 time and no display
Depending upon which BIOS make is installed in your computer, 3 beep means RAM fault.
Check the specification of your motherboard for the recommended RAM.
Reseat the RAM nodules in the motherboard.
Remove the RAM and get them tested at your friendly computer repair shop.
Sep 24, 2010 | MSI H55MP31 LGA 1156 Intel H55 Micro ATX...
Blank screen upon startup
Try taking out the hard disk, plug in power and see if you have a display on your screen or external monitor. if same thing happen, try taking out the memory card. If you hear a beep sound it's a faulty mem. card, if no beep sound appears I suspected it's a motherboard faulty.
May 31, 2009 | Lenovo ThinkPad T61 Notebook
Computer monitor flashes on then turns off
Try the monitor with another computer. If it works, the video circuitry (whether it is on-board or a separate adapter) in the Gateway is the problem and needs to be replaced. Otherwise, the problem is with the monitor itself. From your description it is probably the Gateway's video that is the problem since the power light on the monitor remains green indicating that it is seeng a signal, but not something it can properly interpret, i.e., one or more of the control signals are shot.
Mar 21, 2009 | Computers & Internet
Computer will not turn on. it is just "sparking" ie fans/lights/come on for split second and then everything goes off. on my evga motherboard there is a FF display. i have been troubleshooting easy things...
Not sure about the FF. If everything comes on and then powers off after only a split second, there is not time for the display to show anything. I'm suspecting it is indicating there is no signal.
The very first thing I would try on this computer is the power supply (assuming it's a desktop system).
A faulty power supply can act like this.
Jan 17, 2009 | Evga nForce 680i SLI (122CKNF68)...
Automatically restart my computer.
You need to check the connecters to the motherboard the ones that come from the power button to the motherboard. Hope this helps!
Jan 12, 2009 | Computers & Internet
Pc is not working
as computer starts hold down F8 and youll see a safe mode. use the safe mode and it might just come back, restart it....sometimes strange viruses does this but i dought in your case.it should come up in safe mode allowing you to save your files ...folders to cd record disks...then you can format and reinstall all programs.
Sep 01, 2007 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Computers & Internet Logo
83 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
