Question about Android Apps
Auto rotate is not working because Gsensor calibration is not returning to the center have pressed calibration re-set but all it dose is move to the extreme left/right and up/down any help would be welcome thanks
    President:
  • 423 Answers
Did you tried the full reset
Posted on Feb 14, 2014
How do I disable the auto rotate?
Windows, Android, iOS all below. Number 1 tip, MAKE and MODEL always on Fixya :>)
Press the Windows ( ) key + C, or swipe in from the right edge of the screen to open your Charms. Tap 'Settings' and tap 'Screen' in the bottom of the bar. Tap the little square icon above the brightness-slider to enable/disable auto-rotate.
Jul 22, 2015
How can I enable/disable the auto-rotate function in Windows?
https://us.answers.acer.com/.../how-can-i-enable%2Fdisable-the-auto-rotate-function-in-...
How to Enable and Disable Auto Rotate on Android - Technology Hint
https://www.technologyhint.com > Android
  1. Cached
Nov 12, 2017 - Android has the auto rotate screen option which automatically rotates your device's screen when you move your device between landscape and portrait mode. This feature is a useful one. But, not for all. If you don't want this option turned on, then you can disable this feature. In this post, we will see the ...
How to Lock Orientation to Stop Screen Rotation in iOS 10, iOS 9, iOS 8
osxdaily.com/2013/10/14/lock-orientation-ios-7-screen-rotation/
  1. Cached
  2. Similar
Oct 14, 2013 - Yes, you can still lock the screen orientation in iOS 10, iOS 9, iOS 8 and iOS 7 to prevent the display from rotating itself when an iPad, iPhone, or iPod touch has been physically turned onto its side. The orientation lock is now in a quicker access location contained within Control Center, making it much faster ...
Mar 29, 2018 | Tablets & eReaders
Auto rotate
Sometimes there is a second option called screen lock that keeps the screen from rotating even though you have auto rotate checked. Check thru your setting to see if you can find this.
Jan 10, 2014 | ZEEPAD Brand 7inch 4gb Android 2.3 Tablet...
HOW TO CALIBRATE A HILTI PRI 2
To check calibration, take it into a hilti center. they'll check it for you. Otherwise, set it on a countertop or table. Mark its level at a distance of 15 feet, rotate it 90 degrees, and check to see if the marks jive. If the dont a calibration will cost $60 plus shipping. call 800 879 8000.
Nov 13, 2012 | Hilti Rotating Laser Pri 2 331411
Htc one s won't auto rotate
I have the HTC One S too, and just got my screen rotation problem solved. It wasn't rotating either, even though auto rotation was checked, it was stuck in landscape mode. Then, I uninstalled a few apps that I didnt think were needed anymore, like a game, pixlr express, tango, and a dictionary app.. after that I cleaned the app cache and problem was solved without even restarting. I'm not sure why that worked, but you can try and see it if works for you. I hope it works :)
May 18, 2012 | HTC Cell Phones
The screen stopped rotating. what can I do?
You will have to do a factory reset, which will restore the default settings on your device.
1) With the device powered off, press and hold the Volume Up and Power buttons at the same time.
2) When you see the Samsung logo, release the Power button, but continue to hold Volume Up until the recovery screen appears.
3) Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4) Press Volume Up to continue.
Mar 14, 2011 | Samsung Galaxy Tab Tablet PC
When i turn my phone sideways during a text my phone does not respond (the keyboard is supposed to come up). Also when I take pictures they come out sideways. Im thinking maybe I turned something off but I...
hi considering this works the same way as my htc desire , you should go on settings , then display and then auto-rotate screen , followed by the g-sensor calibration , should be on same page ...put the phone in a flat surface and press calibrate that should solve your htc issues !
ps:regarding the keyboard when you`re texting press the language icon settings ,keyboards types and select qwerty (this works on desire if yours is not the same layout it still should be in message settings )
please rate if useful , it only takes one second .many thanks
Dec 21, 2010 | HTC EVO 4G Smartphone
Had the battery changed, but now the (heat) vents in the top of the van and the floor vent (heat) does not work - only cold air comes out. Also, the heating/cooling dial lets it get hot midway on cold...
Try this calibration procedure and let us know if you have more questions:
  1. Start the vehicle.
  2. Wait 40 seconds for the HVAC control module to self-calibrate.
  3. Verify that no DTCs have set as current DTCs.
  4. Clear all DTCs.
  5. Place the ignition switch to the OFF position.
  6. With the Mode knob in the PANEL position, press and hold the AC button for 5 seconds.
  7. Rotate the Mode knob fully counterclockwise.
  8. Rotate the Mode knob fully clockwise.
  9. Rotate the Mode knob fully counterclockwise.
  10. Release the AC button.
  11. Wait 40 seconds for the HVAC control module to self-calibrate.
  12. Start the vehicle.
  13. Verify that no DTCs have set as current DTCs.
Nov 14, 2010 | 2005 Pontiac Montana SV6
Auto rotate not working. g sensor calibration not
I have the similar problem on my touch HD. its vertical calibration bubble is not in the middle and pressing calibration is not fixing the problem. Auto rotate is also not working! Any one knows the solution??
Oct 25, 2009 | HTC Touch HD Smartphone
Screen rotate
Hello snapshots,
Here is what you do:
1) Click on a blank area of the desktop (not sure why, but sometimes this is necessary). 2) Press the toolbox button on your monitor. It is located in between the rotate screen button and the secondary "Esc" button. A tablet shortcut menu should appear in the middle of your screen. 3) Select "Settings" at the bottom left of the menu. This will open a "Customize Tablet Shortcut Menu Settings" Window. 4) In the "Auto Screen Rotation" portion of the window, make sure the "Enable ActiveRotate" box is checked.  5) If you choose, you may also want to click the "Calibrate" button. This will step you through customizing the ActiveRotate to your personal preference. 6) Click "Apply" and then "Ok".
Please note, that with the internal wi-fi connection enabled, you cannot use the X61 in tablet mode in certain orientations. Nothing bad will happen if you attempt to do this; but you will notice a message popup telling you this, as well as having the screen automatically switch orientations on you. This is normal and has something to do with the wi-fi antenna location.
Hope that helps!
Jeff
Feb 26, 2009 | Lenovo ThinkPad X61 Tablet PC
Android Apps Logo
64 people viewed this question
Top Apps Experts
Brett Duxbury
Brett Duxbury
Are you an App Expert? Answer questions, earn points and help others
