Question about Electrical Supplies
Digidoor installation manual
How to install 2 channel Dts-RX2 reseiver on to digidoor twentyfour pc board
2 Suggested Answers
blanchettohd
  • 143 Answers
SOURCE: Digidoor 3 garage door only opens about 60cm and
The problem might actually be the door itself. make sure it raises and lowers easily and is well balanced. If it is then find the power adjustments and turn up the up force to work the door. Do a 2x4 safety reversal test afterward. Thanks BB
Posted on Sep 03, 2010
Tip
Converting MKV to MP4 with DTS Audio to AAC for Galaxy S II Conversion
Galaxy S II Movies Converter-MKV DTS to AAC to Samsung Galaxy S II Video Converter <br /> Samsung Galaxy S II is the sequel to the critically-acclaimed Samsung Galaxy S Android smartphone.And hope Samsung Galaxy S II able to play my mkv files.But not. The audio on mkv files is mainly DTS, the Samsung is obviously not compatible with this. <br /><br />If you want to set output audio channel option to 5.1, you should choose AC3 or AAC as audio encoder. So many people think MKV DTS to AAC or AC3 is a nightmare. No, it's not so terrible any more. Convert MKV DTS to AAC, convert MKV on Samsung Galaxy S 2 with DTS sound to AAC is so easy if you owns such a powerful <b><a href="http://canon-videoconverter.com/2011/06/convert-mkv-to-mp4-and-mkv-dts-audio-to-aac-to-samsung-galaxy-s-ii-converter/">MKV DTS to Samsung Galaxy S II Converter</a></b>, which allows to you convert any types of MKV files like MKV DTS, MKV FLAC to AC3, AAC, and still keep its good quality. <br /><br /><b>Step-by-step guide</b>: <br />Free download <b>Aunsoft <a href="http://www.aunsoft.com/video-converter/">Galaxy S 2 Video Converter</a></b>, install and run it. <br /><br />Step 1: <b>Import or add the MKV DTS files into Galaxy S 2 Video Converter</b>. <br /><br />Step 2: Please select suitable format like Android - <b><a href="http://www.aunsoft.com/video-converter/">Motorola Droid X H.264 Video (*.mp4) for your Samsung Galaxy S II</a></b> as the output format for conversion.Set Size to 800*480 pixels. (This format profile is specially designed for Droid X, but it can also use for Samsung Galaxy S II phones with perfect effect, just select it for your Samsung Galaxy S II.) <br /><img src="samsung-galaxy-s-video-converter.jpg" /> <br />Step 3: Set the output audio as AAC with Stereo.Click "Settings" to select video codec (h.264) and audio codec (AAC), audio channels (Stereo). See as follow: <br /><img src="convert-mkv-dts-to-ac3.jpg" /> <br />Step 4: Click the "Convert" button to start <b><a href="http://www.aunsoft.com/video-converter/">converting MKV to MP4 with DTS sound to AAC for Samsung Galaxy S II</a></b> . <br /><br />Quickly you will get your converted AAC files and the audio/video synch correctly and perfectly.You may interest in <b><a href="http://www.aunsoft.com/how_to_put_and_play_movie_music_on_samsung_galaxy_s_ii/">how to put and play movie and music on Samsung Galaxy S II</a></b> .
on Jun 06, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
I bought a receiver to pair a Centurion D5 motor with thE Digidoor motor.How do i install the Receiver on a Digidoor motor?
Hi there Vusi.
You should have a manual open and close switch on the wall for your Digidoor. You need to find the two wires which control the open and close functions on the Digidoor Trace these back to the Digidoor motor connect these to the Comm and NO terminals. You also need to supply 12V power to the receiver This needs to be connected to the Possitive and Negative terminals on the receiver. These connections originate in the Digidoor motor housing and can be connected right there. Some Digidoor motors have connection terminals for additional remote receivers in the housing. Remember that the minimum connections needed are Positive, Common(Sometimes the common is also the negative supply so you can bridge the common and negative terminals on the receiver) and NO. Then pair the remote with the receiver as per the instructions in the receiver box. If you still cannot come right post pics of the PC boards of your receiver and Digidoor motor and I will identify the connections for you
Jan 05, 2015 | Televison & Video
DOD sites will not recognize that my pc has JRE 1.6 installed
im using windows 8 and installed, removed and re-install it and nothing works.
Dec 12, 2013 | Computers & Internet
Digidoor remote
"Another reason is problems with the radio frequency of the remote control system used, some older systems use frequencies that are liable to interference from various sources such as police and fire department radios and military communications. The effects of this interference are many for example, the garage door may open and close on its own or the operating range of your remote control may become so poor you cannot open or close the door with your remote control even whilst standing next to it."
source
Jul 29, 2013 | Audio Players & Recorders
Ok i have a new conex 3300 in a box never used now im try the radio and go over heat and reseive put no trams
first of all ,remove what you put into it and install the original parts back into it. Now see if it still heats up.If it does what is it thats heating up? Check it out,maybe install a different transistor with higher voltage to keep heat down.Could be a transformer in there heating up .Do the logical first then procede to the next step.
Jan 26, 2013 | Connex 3300 240-Channels Base CB Radio
Need manual for timer dtsx-240-hc
More information is needed.
Review options below:
1) Add a comment and describe timer in detail for best possible answer.
2) DTSX timer appears to be older-style GE/Grasslin or Intermatic/Grasslin/Frost King defrost timer with selectable voltage and F 3 1 2 4 N X wiring terminals.
Open following links to identify timer and download possible manual
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#defrost
http://waterheatertimer.org/pdf/DTMV40-instruction-manual.pdf
Additional resources explaining more about defrost timer operation:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#8145
3) Tork makes DTS series timers with 1, 2 and 4-channels:
Each channel can be programmed separately to control different loads with different on-off schedules.
Timer clock is 120Volts, but dry switch terminals can be wired to control any voltage load.
http://waterheatertimer.org/Tork-Digital-timers-and-manuals.html#DTS
Sep 28, 2011 | Hardware & Accessories
Ram support
As much as I would love to spend a couple hours making you a list of Ram that your board supports, not happening.
However you can do this your self by looking in your manual.
Download your manual here:
http://www.giga-byte.com/Support/Motherboard/Manual_Model.aspx?ProductID=1863
Go to the top of page 15.
Your board requires a voltage of no more than 2.5v
GA-8IPE1000 Series includes 4 DIMM sockets, and each Channel has two DIMM sockets as following:
Channel A : DDR 1, DDR 2
Channel B : DDR 3, DDR 4
If you want to operate the Dual Channel Technology, please note the following explanations due to the
limitation of Intel chipset specifications.
1. Dual channel memory cannot be used if one DDR memory modules are installed.
2. If two DDR memory modules are installed (same storage capacity), one must be added to the
Channel A slot and the other in the Channel B slot in order to use dual channel memory. Dual
channel memory cannot function if both DDR memory modules are installed on the same channel.
3. If four DDR memory modules are installed, please use memory of the same storage capacity in
order to use dual channel memory and for BIOS to detect all the DDR memory modules.
We'll strongly recommend our user to slot two DDR memory modules into the DIMMs with the same color in
order for Dual Channel Technology to work.
You board supports this type of memory:
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80097-16
Or
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1717669&CatId=1352
Good Luck & kind Regards.
& please vote.
Mar 16, 2008 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
Motherboard Missing instruction manual for dual mode memory
Your instruction manual for the mother board should have this, however, with dual-channel motherboards, you will want to fill the same colored slots together if you have dual-channel capable memory, otherwise you'll want to fill in the off-colored slots first.  ASUS has it's manuals online, so if you've lost yours you should be able to download a pdf of it from their website.
Nov 09, 2007 | ASUS A7V8X Motherboard
Electrical Supplies Logo
67 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
