Question about Vitamix Vita-mix Super 3600 Stainless Steel Container
Loosened blades on a vitamix 3600 stainless steel container
The acorn nut on top of the blade assembly on our vitamix 3600 stainless steel container (with the twelve-point spindle) has spontaneously loosened. I have had this unit for about 20 years (got it second hand). Have never serviced it. I use it at least once a day, and often more than that. Not sure how to approach retightening the acorn nut. It all seems very loose, and there is a good deal of vertical endplay in the entire blade assembly. Can you point me in the direction of how to fix this? I'm getting hungry. :-) Thank you so much in advance for your help! Marji in the Catskill Mountains of New York
    Problem Solver:
  • 19 Answers
If what you can't see in your device, namely the motor assembly, it may be that the assembly is one of those not designed to be taken apart and that it is wearing out. If so, that could be the cause of the looseness you are experiencing. It may be unrepairable or more costly to fix than to replace. Twenty plus years is a good run for almost any mechanical device.
Posted on Jan 02, 2014
SOURCE: Blade not spinning
My Vitamix 3600 plus has same problem. Result of detachment of rubber coupling between lower splined socket from blade shaft. This is a tough rubber molding that takes tremendous punishment through years of smoothies. Mine showed some rust on the bottom of the blade shaft, where it parted. I tried gluing back together with super glue and tried to eyeball it. Of course it was off by a few degrees. When I reassembled and turned it on, what a racket of vibration! But it held. Amazing. Obviously not good to go though. So I took assembly all apart and redid it, chucking the shaft and the lower nut in the lathe. This time, all true on axis. Glue held for about a week. Right now I am regluing, this time with epoxy. We'll see how it holds up. And meanwhilst, I'm researching replacement parts! I'm not too optimistic about the epoxy.
Posted on Jun 15, 2008
swami nathan
  • 208 Answers
SOURCE: Older Vitamix Problem
I want you to try this,
1.Remove the blender jar from the blender motor .
2. Check the jar by turning the shaft by hand to see if it rotates easily. .If not, disassemble the blade and ring. Check for obstructions or misalignment. It is better to change the shaft which holds the blade......
If it fails you again, you have to contact with the service center or visit this site
www.vitamix.com/household/service/service.asp
Hope my info helps you,
Thanx for using fixya,
Waiting to help you from your comments.....
Posted on Oct 01, 2008
EsWorld
  • 1618 Answers
SOURCE: blade turns with difficulty
Check the blade assembly it may be worn out.
Posted on Mar 26, 2009
  • 145 Answers
SOURCE: When trying to blend things like frozen fruit or
Frozen elements are generally not recommended for blenders of any brand. They may cause the blade assembly to stop moving completely, or to "bog down," and this may eventually damage the motor. It is recommended that frozen fruits and/or yogurt be thawed when possible before placing into a blender. If this is not a possibility for you, I would use a "pulse" or "chop ice" function to rapidly spin the blades for just a moment. This will chop the contents in smaller, more manageable parts. This should be done before adding other liquid ingredients.
Posted on Jul 10, 2009
SOURCE: The blade in my Super
Stiff or stuck blade problems can be fixed by replacing the two bearings and seal inside the blade assembly. Care must be taken in installing the new bearings as not to damage them. Ideally they should be pressed in, on a press, but they can carefully be tapped in using a sockets to match inner and outer races so your not tapping on the balls.
Posted on Apr 10, 2011
Testimonial: "Thanks,I took it to a local appliance repair shop,who did what you described for $45."
Vitamix blender recalls.
Important Vitamix Safety Recall Vitamix has issued a voluntary safety recall for the "64-ounce Low-Profile" container that has been sold with three of its blender models: the Vitamix 7500™, Professional Series™ 750®, and Professional Series™ 300®. A potential safety concern has been identified with the blades used in this specific container. If you own one of the affected blender models, please continue reading to learn how Vitamix will replace the blade in your container with an updated design.
If you have a question about this recall that has not been addressed in our FAQs, please contact us at 888-350-4386. Has your blender container been recalled? If you own one of the products below, your container may be included in this recall. You can quickly determine if your product has been affected by looking at the blade in your container. The part number and date of manufacture are etched on the top of the blade, under the logo. If the part number is 103208 A and the date of manufacture is before August 2013 (shown as 08-13), your container is affected and needs to be returned.
Container Blade Recall
Feb 15, 2018 | Vitamix Blenders
How to replace the blade assembly on my Vitamix commercial 4000 (stainless steel pitcher) I have the blade assembly but it's more complicated to replace than I thought. HELP.
there is a wrench (by Vitamix) for under $10. you can get it from amazon. it makes the job of removing a blade assembly much easier.
Jul 01, 2016 | Vitamix Blenders
Vitamix 3600 throws sparks when turned on
Sounds like it may need a new blade/bearing assembly or coupling or both.
Feb 25, 2014 | Vitamix Blenders
My vitamix4500 leaks
Your container may have a bad seal at the blade assembly??
You will need a special wrench to remove it.
check here:
Contact Us Customer Service Vitamix
Or here:
Amazon com vitamix wrench assembly Home Kitchen
Feb 24, 2014 | Vitamix TurboBlend 4500 Work Top Blender
Where can I find a motor
Vitamix says they will fix units up to 20 years old or so????
check here:
Don't know about 30-40 years old????
good Luck
Feb 23, 2014 | Vitamix Vita-mix 3600 / 4000 Handle For...
Vitamix TNC 60 oz container leaks when in use. how to replace seal and or bearings?
If it is not the HUGE blade retaining ring under the beaker a bit loose then you will be buying new parts to repair it. The only other possibilities are beaker cracked and leaking (new beaker) or bearings & seals worn (new blade & bearing assembly)
Oct 21, 2013 | Vitamix 5000 Work Top Blender
Vitamin 3600 canister leak
I think it's the little washer in the blade assmbly since mine was worn to a sliver when it started doing what yours did. I replaced it with a similar washer and it worked for a week and then started spitting out metallic dust until it stopped working again. Could be the bearing seized. I would say yes a new blade assembly but I hadn't found one- since I have a 3600 which is very old-when my husband bought a used replacement container with a working blade assembly on ebay. $37 bucks, problem solved.
Mar 28, 2012 | Vitamix Blenders
Vita-Mix 5000 blender shuts off under heavy blending loads.
first check the blades on the container thay should turn easy by hand if not thats your problem , you will need blades . blades turn easy ? you will need to replace the motor . the temp /overload has changed and is tripping to easy . this is common with people that use there vitamix for tough chores a lot . a lesser blender would just burn up a motor in a puff of smoke .a vitamix dies this way . in the end its the same you will need a motor
Mar 22, 2009 | Vitamix Super 5000 Work Top Blender
Blade not spinning
May 28, 2008 | Vitamix 36000 Work Top Blender
Blade turns with difficulty
Mar 27, 2007 | Vitamix 5000 Work Top Blender
Vitamix Vita-mix Super 3600 Stainless Steel Container Logo
496 people viewed this question
Top Vitamix Blenders Experts
Craig Butler
Craig Butler
Holly...
Holly...
Are you a Vitamix Blender Expert? Answer questions, earn points and help others
