Question about Phones
Rewire antique phone to modern lines
I have a north electric mfg. co. phone I bought and want to be able to us it but don't know how to change the wiring to be able to use it in my house
2 Suggested Answers
  • 65 Answers
SOURCE: home telephone wiring
If you have a dial tone at the closest jack and it doesnot go on through the house check to see if the red or green wire has been pulled loose or is broken at that jack or the next one. What happens when some one calls you? if they get a busy then there is a short where the red and green are touching each other. This sometimes happens only when a phone is plugged into the jack, in that case you can replace the jack. If the phone sounds like it is ringing to the caller and you do not hear the ring signal then you have a wire loose or broken( usually in a jack.) check each one and sometimes you need to pull on the wires the outer coating might hide the broken wire, Sometimes it might be just a loose screw in the jack.
Posted on Feb 25, 2008
  • 463 Answers
SOURCE: have 3 phone jacks in house in 2 different
Posted on Mar 16, 2009
0 characters
1 Points
Don't see my phone line once someon else picks up a lilne on My Panasonic KX T7433
Start by pressing PROGRAM 99 on the phone and press the line buttons one a t a time. It will tell you what CO(central office) line is assigned to the button.
They should be in sequence 1,2,3,4 etc. If they don't, dial 0 + 0x STORE to program it and make it work.
Aug 22, 2012 | Panasonic KX-T7433B Corded Phone
Line no 4 is always showing co in use
When you press PROGRAM and CO4, what does the display say? A Panasonic TA series system starts with 3 lines. If you're trying to access line 4 and you don't have it, you might get that display, or line 4's button may be assigned to something else. Last, try unplugging the phone system cabinet and plugging it back in. That will reset all calls.
Jul 30, 2011 | Panasonic KX-T7730 Corded Phone
Hi, Can any body help us? We have a M7324 on a Norstar Compact with two line pools, Pool A is on Line 1,2,3 and Pool B on Line 4,5. We want to add another line on Pool B so I tried configuring Line 6 which...
On the cross connect do you have a CO connected to that line. That is most likely the cause of no dial tone. If you don not know how to check that call a phone system expert to connect and verify your system.
Feb 15, 2011 | NorStar M7324 Telephone
Hi, Expert Guy , I have some problem with Panasonic TDA100 about calling Out by co line i have 20 extension and 4 CO line , so when i need to call out , i press number 9 , it will switch to the line free ....
To call out: Go off hook press an idle CO button-- Dial outside phone number. There is no need to dial "9".
If you need a copy of the manual you can get one for free at the following link: HTTP:// me know if this answers your question. Master FixYa...
Dec 05, 2009 | Panasonic KX-T7630 Corded Phone
GE 900MHz, Model No. 26928GE1-D, S/NO: 40336671 Cordless with phone line base Would like to request a free owners manual so that I can program the phone. The phone was given to me. Is the manual available... TRY GOING TO THIS SITE AND DOWNLOAD THE MANUAL YOU NEED....:)
Nov 16, 2009 | Uniden Cordless Phone
How do I remove the wires from an existing wall phone jack and then rewire to a new jack
pop the front cover off write down witch color wire goes to witch letter on the plastic change to same, most phones line need two wires green and red, but 4 are hooked up black and yellow, for a second line, hook them all up just in case the other wires had a problem and the phone company switced to the other two
Sep 09, 2009 | Phones
Nortel T7316E acts like M7310
Feature *81 will move line buttons.
May 04, 2009 | Nortel T7316E 2-Line Corded Phone
Need to reverse line 1 and 2 so that line 1 is the primary number
you could swap at the demarc(where telco responsibility ends) usually a box with screw down lugs one side marked customer the other marked phone co.
Jul 24, 2008 | GE 29439GE2 Corded Phone
Phones Logo
402 people viewed this question
Top Phones Experts
Are you a Phone Expert? Answer questions, earn points and help others
