Question about Viking VCFF136SS 36" Professional Series French-Door Bottom-Mount Refrigerator - Stainless Steel
Vcff136ss freezer drain hose
I have water at the bottom of my freezer and I was told to check the drain hose for blockage. however, I do not see a hose of any type and I'm wondering if I have to remove the back wall of the freezer in order to see it? appreciate any instructions on how to locate and clean the drain hose. thanks.
    Problem Solver:
  • 17 Answers
Look at the bottom in the back for a small (usually black) rubber hose. this wil be the drain and the only way to clean them that I am aware if is to blow up through it ( makes amess inside the freezer or fridge but does work. some models drain the freezer into a funnel like thing on the back wall inside the fridge and then to outside.
Posted on Jan 02, 2014
Why is my Viking refrigerator/bottom freezer leaking water out bottom of door? There is a layer of ice on bottom of freezer.
The ice on the bottom of the freezer is blocking a drain hole. When the freezer defrosts automatically, water drains out the bottom into a tray, where it evaporates away and you never see it under most conditions.
The solution is to either defrost the freezer manually and let the ice melt, or pour some hot water into the bottom of the freezer to thaw out the ice and clear the blockage.
If the drain is plugged because of some foreign matter, either method will make a mess, so have some towels at the ready to sop everything up if need be. If it is blocked, a can of Air Duster (like for cleaning electronics) might be able to blow the blockage out, if you seal the nozzle tube up as it is stuck into the drain.
Most likely it is just ice blockage.
You can access the drain tray (where the water goes to evaporate) by removing the grille on the front bottom of the fridge and peeking / poking around. You might want to keep an eye on it as you defrost the freezer or pour hot water in the bottom - it can over-fill quickly.
Jul 20, 2014 | Viking Refrigerators
My ge gts201cncww fridge has ice freeze up in the bottom of the freezer and water drips into the fridge and freezes the fresh food
the drain tube behind the inside rear freezer wall below the drain pan there is plugged,remove rear inner freezer panel you will see the drain tube take a piece of hose and insert it down this drain hole and seal the drain opening as best as possible the blow into the hose to remove blockage,a piece of wire will work too,but the drain is not a straight run and getting a wire down there to remove blockage is difficult,then also put very hot water into the drain hole to help melt ice if this is the blockage problem
Feb 12, 2013 | Refrigerators
Layer of ice builds up on bottom of freezer
A common cause on many refrigerators is the the aut-defrost drain hose is plugged resulting in a back-up and depositting in freezer compartment. Check the drain pan under the fridge, if it is dry, then check the drain hose for blockage.
Gabe
Aug 01, 2011 | Kenmore 72282 / 72284 / 72289 Bottom...
Water collecting in bottom of refrigerator side under meat keeper. Wards model no. HMG 2290
Check to see if your ice maker is not leaking water. Otherwise, the problem might be a clogged drain in the freezer. Need to remove the back cover in the freezer to check that the drain is clear. If it is clogged, try removing any blockage that you see and push wire down the drain tube to clear any blockage in the tube.
Oct 04, 2010 | Montgomery Ward Refrigerators
How to get to the drain line on my Frigidaire side by side refrigerator model number MRS22WNGW7. Water keeps coming out of the freezer side onto the floor (front left side). I was told it could be a...
I just opened up the back of my Frigidaire Side by Side counter depth to find the drain hose was bent and collapsed coming right out of the bottom of the freezer and the pan was dry as a bone. It doesn't look like my drain hose has ever drained a drop of water. The freezer bottom is full of ice And the rust and chipping paint under the bottom of the freezer door along with the mysterious puddles of water every morning means the drain system definetely never worked. Frigidaire should be responsible for this. This, along with the ice maker rebuild I had to do,... after ice was spilling all through the fridge. I actually had warrantty left on that one and called customer support in India to find out I could make the repair myself. Yep I had to do it. Frigidaire you failed.
May 14, 2010 | Refrigerators
Side by side, water build up in the bottom of the freezer.
this is usually a blockage with the drain in the back of the freezer compartment you can pour some hot water in the back or try and clean out the drain hose
Apr 13, 2010 | Refrigerators
Water in bottom of freezer
the drain needs to be check for any kind of blockage. if the drain is blocked or frozen over this needs to be cleared
Sep 16, 2009 | Woods Upright Freezer MU07W
Amana refrigerator top freezer going out; water under crispers
you are right about the cause of water in the fridge - blockage in the drain. i'v never met this caused by ice but it is possible.
with the freezer, the cause of the fault is the fan not working - probably jammed with ice. take back panel off inside freezer and check for ice build up. if loads of ice thgen defrost system has failed. you can do a temporary repair by melting the ice off with a hairdryer
Sep 24, 2008 | Refrigerators
Ge profile leaks from front of freezer
your drain will be plugged under the tray. there is a hose that runs to the drip tray. the back cover comes off you can then get at the hose
Sep 05, 2007 | GE GSS25JEMWW Side by Side
Internal water leak Amana AT5518SW
King, you probably have a defrost drain port that is frozen over. When the unit goes into defrost it's running through the air damper instead of going out the drain line. Therefore you get water into the refrigerator section. You can verify this by removing the evaporator cover in the freezer and checking the drain hole. You can clear it by running hot water into it. You will have to remove all the built up ice from water that did not drain in that area...Catriver..post back.
Nov 13, 2006 | Amana ATB2135HR Top Freezer Refrigerator
Viking VCFF136SS 36" Professional Series French-Door Bottom-Mount Refrigerator - Stainless Steel Logo
79 people viewed this question
Top Viking Dishwashers Experts
Mike
Ronald Rissel
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
