Ovens Logo
M
Martha Boeyens Posted on Jan 02, 2014
Oven repair manual
Knobs loose
Help!!! Need Replacement knob kit for my Thermador double oven!
these are NLA. No Longer Available.
Try to get something that is acceptable to you and fits by researching "oven Knobs" at repair clinic dot com and selecting by looks and size.
1helpful
I have an old electric oven. Somehow after touching the timer settings the oven will now not work. What do I need to set the timer options to. The timer is adjusted using knobs - one for the clock and...
The timer must be in manual mode for the oven to work. Turn the oven ON. With the oven turned on make adjustments to the two knobs. These are generally stop/start timers. These turn and you can also normally press them in. Be patient. When the oven indicator light comes on it will be fixed.
Mar 02, 2011 • Ovens
I am looking for a manual for an Ignis oven FXVM6 AKL 887/01 1X I need to know how to separate the door and the glass for cleaning purposes
hi. I have the same oven at this house that I moved into recently. All the markings are faded around the knobs. Could someone please put up a picture of the knobs so I can try using my oven..thanks
Oct 20, 2010 • Ovens
We don't know how to turn the oven on! It is a Kitchen Aid convection oven. The instruction manual does not seem to include this! Help!
I fussed with all the knobs and figured it out!( wording on the knobs are gone) but we have it now! I was afraid of ruining something but ended up going for it! Thanks for following up. Lyn
I have a older Frigidaire oven model #RG74BC. I have messed with the timer knobs and the oven will not come on. Does anyone know what setting the knobs need to be on to fix this problem
You have probably inadvertantly put the oven into Automatic cook mode, where the oven will not come on until a preset time.
Try pressing/turning the clock/timer buttons and resetting the clock and this should put the oven back into Manual cook mode and you should be ok.
Jan 10, 2010 • Ovens
Need instruction manual for operating Indesit Automatic Oven
I have a indesit oven and not sure what model it is because i have no manual, its silver, has 3 control knobs and six small under the small digital screen, it has 1 door at the top which is blacked out cannot see through and the bottom door is clear glass, any ideas?
Mar 02, 2009 • Ovens
Self clean doesn't start
i would pop the top up and see if there is a bad switch on the handle that locks the oven.
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
