Question about AT&T Lands Phones
Phone will not register
Base unit will not regiser with hand held unit.
SOURCE: No Link To Base Unit
I am having the same problem!
Posted on Apr 08, 2008
SOURCE: Uniden DCT648 register phone problem
On the Base Station select HS Registration then on the Handset hold # for 2 sec
Posted on Apr 13, 2008
SOURCE: Olympia cdp24201
1. go to menu, then HS setting, then registration, register
2. follow the steps and register the set to the base.
3.press and hold the base mute button for 10 seconds, press next to continued
4.select the cbs and connect it.
5.enter 0000 as a password
Posted on Sep 18, 2008
SOURCE: the base unit goes blank no display
I had this same problem. It turned out to be a bad power adapter for the base unit. If you have another handset that has its own charger than the power adapters are interchangable. try swapping them and see if this fixes your problem.
Posted on Jan 18, 2009
  • 10 Answers
SOURCE: my motorola d10 phones will not register to the
Hi, I may be late at posting a reply but I had the same problem and I'm an IT Practitioner - So Motorola don't seem to like making things easy or even giving instructions - I tired out Google and eventually came across the result myself:
1. Go To Advance Settings
2. Then Go To Registration
3. Then Go To Search Base
4. And Keep Hold Of The Page Button On The Main Unit
( You May Have To Do This Several Times)
5. The Screen A Should Display PIN
6. Enter The PIN Which Is 0000 (Unless Changed)
7. REGISTRATION COMPLETE!!!!
Also I had problems with the intercom feature - when I attempted to intercom another handset - It wouldn't ring but this was fixed by turning the room monitor (Baby Monitor) off.
Best Wishes PINDY92
Posted on Oct 07, 2010
I have just inherated the at&t e5634b phone system. I have replaced the batteries in the hand sets. As per the manual I have de-registered each hand set. The problem is that when I register the...
This problem can be caused by the following, A bad battery, (which you say you are all new). A full base memory and a Faulty main base unit
This main base unit can only expand to four handsets and no more. If the base unit has been reset then the assigned numbers for each handset would begin with " handset 1" if they show any other number when reset then it would not have been reset..To re-set main base you will have to
De-Register All Handsets
Unplug the power supply from the base unit then Remove all handsets from the charge cradles and base then Press and hold the PAGE button on the base.
Plug in the power supply again while pressing the PAGE button, Continue pressing PAGE until the IN USE and CHARGING indicators are lit. (this could take up to 10 seconds)
Release the PAGE button All Handsets will display "enter base id".
If this does not solve your problem then you will have to replace the main base
Apr 20, 2017 | AT&T E5634B Phone System w/ Caller ID
Only bass set going extra hand set not working
This is because the extra handset might have not been registered with the base unit.The headset should be register to use the headset with that base unit.
To register the handset to base unit please follow the instruction:-
On registration the handset is allocated a handset number for use on the new base unit, the handset numbers are 1-5.
1. Press and hold
d65e3ff.jpgon the base unit until 608a95f.jpgstarts flashing. Registration mode will remain active for approximately 3 minutes.
2.Press and hold both
19efd34.jpg together until you hear a long beep.
3.Select the base unit you wish to register by pressing the corresponding number button 1-4.
4. When PIN is displayed, enter the units PIN number (0000 for this model).
5. If the registration is successful the handset will return to standby mode in a few seconds.
Thanx
Jul 22, 2010 | Doro DECT 540 Cordless Phone
I have a GE model 2810GE AND THE screen say's HAND SET NEEDS REGESTRATION. WHAT SHOULD I DO ? CHARLES
This is from the instructions at GE's site for the model 28110 (you said 2810, which isn't found):
  1. Press the mute/program button. Hold BASE PAGE for 5 seconds, then PRESS HANDSET PROGRAM shows in the display. (Your handset should be held near the base during registration process.)
  2. Press and hold the page button on the base unit until the charge/in use indicator flashes. Press the handset mute/program button. REGISTERING shows in the display. HANDSET X REGISTERED shows in the handset display, where X is the handset number
Hope this helps. Thanks for using Fixya!
Feb 11, 2010 | Uniden Cordless Phone
I have a Pansonic kx-tga270s that is registered to a base I do not have. Is there a way to deregister it.
you dont need to deregister it if you have not registered all 8 hand sets with your base unit. Just register the new one and the base will assign a new # for this new. I you had registered 8 hand sets with your base already, you need to remove(deregister0 one handset from your base(it can take only upt 8).
If it still not registering please deregister as follows:
on the base unit, press program, them mute, then enter 335#, then enter the handset number you wish to deregister.
after deregistering try to register your new hand set.
Nov 19, 2009 | Panasonic KX TGA270S Cordless Expansion...
Phones won't Register!!
It is possible that you have maxed all of the headsets that can connect to the base. Yes, the base can support 10 headsets, but there is a small chance that in some way you registered more to the base or you purchased a base that had phone registered to it that are not in your possession. Either way, if the base is maxed out, you will not be able to register any additional headsets to it. The only option is to do a factory reset of the base unit if this happens to be the case. This is done as follows according to Uniden Tech Support:
1. Disconnect the power from the base
2. hold down the following three (3) keys: [dnd] + [middle soft key] + [*]
3. While holding down the keys, plug in the base (hold the keys down until you hear a long beep). This is supposedly all it takes to reset the phone.
The way to determine the number of hand sets tied to the phone is to press the intercom key on the base and scroll through the list of phones. if you see more than the number you anticipate still being tied to the base, you will have to utilize the above procedure.
Jul 27, 2009 | Uniden TCX905 Cordless Accessory Handset...
How to register phones to base unit - uniden dct648
Unplug the unit again and press the intercom/find handset button while you re-connect the adaptor.  Then dock the phone unit once again and it will re-register.
Sep 14, 2008 | Uniden DCX640 Cordless Expansion Handset
Motorola MD400
Take battery out of handset for one minute.
Unplug base unit (power and phone line) for one minute.
Plug base unit back in (power and phone line).
Put battery back in handset. Place hangset on base for
one minute. This got my phone up and running.
I had no battery power in the base unit, but if I did, I think
you have to remove those as well.
Apr 17, 2008 | Motorola Mobility MD41 Expandable Handset...
Move closer to base
Either the phone is not registered to the base unit or the RF module is broken. It could be a bad battery but unlikely unless very old or you have not charged it. You should check the manual for registering the phone to the base unit.
Sep 07, 2007 | Panasonic KX-TG2584 Cordless Phone
No dial tone on handsets
Hey.. Did you check to see if the phone is registered correctly ???
Jan 09, 2007 | Olympia CDP 24201 Cordless Phone
Lands Phones Logo
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
