Gsh25ufrf cc - Office Equipment & Supplies
Why wont my toyota carina 2 ltr. E start its always been so good but we had one hard frost and the next day it would not start with a jump but did start with a tow, the following day went to start it
Not familiar with your specific engine so some of this may not apply. Generally, sounds as if whatever acts as a choke on your engine has failed. Most common would be a coolant temp sensor, cold start injector, or very likely a moisture related issue, such as bad plug wires,cracked distributor cap, etc.
Dec 30, 2014 | Toyota Cars & Trucks
Standard bore size mm
ENGINE 2 stroke single cylinder direct reed valve crankcase induction Liquid cooled 125 cc engine Cylinder size 124 8 cc Bore and stroke 54 x 54 5 mm 200 cc engine Cylinder size 175 3 cc Bore and stroke 64 x 54 5 mm 250 cc engine Cylinder size 247 7 cc Bore and stroke 72 5 x 60 mm 280 cc engine Cylinder size 272 2 cc Bore and stroke 76 x 60 mm 300 cc engine Cylinder size 294 1 cc Bore and stroke 79 x 60 mm I Cant put periods or commas so bare with me
Mar 15, 2014 | 1999 Daewoo Lanos
Does any one know how many valves a 1986-1987 toyota carolla 1.6 has, I think it is 12 or 8
Hi there:
Keep in mind this information:
Japanese market engines:
* 3A-U 1.5 L (1490 cc) I4, 8-valve SOHC, carb, 83 hp (62 kW)
* 3A-LU 1.5 L (1490 cc) I4, 8-valve SOHC, carb, transverse mount, 83 hp (62 kW)
* 4A-GEU 1.6 L I4, 16-valve DOHC, EFI, 130 hp (97 kW)
* 2E 1.3 liter
* 5A-F 1.5 liter
* 5A-FHE 1.5 liter
* 4A-FE 1.6 liter
* 4A-GE 1.6 liter
* 4A-GZE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, wide valve angle, supercharger, 165 hp (121 kW) GT-Z
* 2E 1.3 L (1295 cc) I4 cylinder 12v SOHC 73 PS (54 kW; 72 hp)
* 4E-FE 1.3 L (1331 cc) I4 cylinder 16v DOHC 100 PS (74 kW; 99 hp)
* 5E-FE 1.5 L (1497 cc) I4 cylinder 16v DOHC 105 PS (77 kW; 104 hp)
* 5A-FE 1.5 L (1498 cc) I4 cylinder 16v DOHC 105 PS (77 kW; 104 hp)
* 4A-FE 1.6 L (1587 cc) I4 cylinder 16v DOHC 115 PS (85 kW; 113 hp)
* 4A-GE 1.6 L (1587 cc) I4 cylinder 20v DOHC VVT 160 PS (118 kW; 158 hp)
* 4A-GZE 1.6 L (1587 cc) I4 cylinder 16v DOHC supercharged 170 PS (125 kW; 168 hp)
North American market engines:
* 4A-C 1.6 L I4, 8-valve SOHC, carb, 90 hp (67 kW)
* 4A-GE 1.6 L I4, 16-valve DOHC, EFI, 112 hp (86 kW)
* 4A-F 1.6 L (1587 cc) I4, 16-valve DOHC, carb, narrow valve angle, 95 hp (71 kW)
* 4A-FE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, narrow valve angle, 102 hp (76 kW)
* 4A-GE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, wide valve angle, 115 hp (86 kW) 1988/89, 135 hp (100 kW) 1990/91 GT-S
* 4A-FE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, narrow valve angle, 105 hp (78 kW) 93-94 SD
* 4A-FE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, narrow valve angle, 100 hp (75 kW) 95-97 SD
* 7A-FE 1.8 L (1762 cc) I4, 16-valve DOHC, FI, narrow valve angle, 115 hp (86 kW) 93-94 DX and LE
* 7A-FE 1.8 L (1762 cc) I4, 16-valve DOHC, FI, narrow valve angle, 105 hp (78 kW) 95-97 DX, and LE
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 18, 2012 | Toyota Corolla Cars & Trucks
How to have cityville cash?
In order to get city cash for the game Cityville you will need to purchase it online. Here's how
  1. When playing Cityville click the "add coins and cash" tab under city finances.
  2. Follow the games simple walk through on completing your purchase.
City Cash Pricing (USD) - 15 CC for $2.24
- 40 CC for $5.60
- 75 CC for $10,08
- 170 CC for $21.28
- 465 CC for $54.88
- 1,000 CC for $110,88
Jun 14, 2011 | Video Game Consoles & Games
How the **** do i take off captions off my philips tv
Hello
Press CC button on the remote to display the current Closed Caption Setting.
Press the CC button Repeatedly to choose from the four Closed Caption Options [CC OFF,CC 1, CC 2, CC MUTE].
When finished press the Status/Exit button to remove the Menu from the Tv screen
From the above said four Caption options just select as your need. OK.
Nov 12, 2010 | Philips 32PT6441/37 32" TV
THERE IS A BLOCK BOX IN THE MIDDLE OF THE SCREEN ON ONE CHANNEL
This is a text box. To get rid of it you press the cc button. You may have to press the cc button more than once or twice in a row. There is no harm in pressing the cc button. In fact turn to that channel and press it a few times in a row while looking at your screen. You will notice that you will see cc:1/2 cc:2/2 cc:text3/4 cc:text4/4 and cc:off
or something like that. When it says cc:off you will no longer see the block box on this channel or any other channel. You do not have to do this for every channel once it is done.
However the text box might be set on the caption setting in the cable box or satellite tv box. If so the procedure is different.
Mar 20, 2010 | Sharp LC-19SB25U 19 in. LCD HDTV
I have a philips magnavox tv with the original remote. closed caption constantly (writing script)comes on tv screen, even though the remote has a cc button,i press it until cc off comes on, the cc goes off...
You're not doing anything wrong. Your TV is somehow turning the cc on "all by itself". Some bit is getting flipped inside the TV, turning the cc on.
either that or there is some sort of rf or ir interference near the TV that is mimicking the CC button on the remote.
Have you pressed the cc button on the remote, verified the cc is "off" on the TV and then removed the batteries from the remote for a while to make sure there isn't something hinky with the remote???
Feb 27, 2009 | Televison & Video
15 people viewed this question
jasbo
jasbo
