Question about Photography
Kodak digital frame shuts off after 5 to 15 seconds
Within a few seconds after turning the frame on or pushing the reset button frame shuts off
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 86 Answers
This sounds like a setting issue on the photo frame. You should check for a timer for screen time on the frames menu.
Posted on Nov 06, 2014
2 Suggested Answers
Roynice152
  • 88 Answers
SOURCE: Unable to download pictures from computer to digital frame
The primary software is going to extract all the images, put only the images you want on the card, then insert into your picture photo frame.
Posted on Jan 08, 2009
Kodak picture frame will not turn on, has no reset button, unplug and restart does not work. How do you open the frame?
I had this same issue. I hadn't used my frame in about a year and wanted to turn it on to show photos during the holiday gatherings. When i turned it on it would boot up then shut off. I realized the cord I was using wasn't the original cord and the output voltage was too low to power the frame. Make sure you are using the correct ac/dc cord.
Dec 19, 2010 | Kodak EasyShare EX1011 Digital Picture...
Heated seats (both driver and passenger) turning
the heated seat relay is bad causing your dilemma
Feb 07, 2010 | 2003 Chevrolet Tahoe
My Insignia converter shuts off after few seconds
Try power-cycling the unit to reset it (turn it off and unplug for several minutes). Also, remove the batteries from the remote control and push all of its buttons, then install a fresh battery. If these steps don't resolve the issue, you may return with the unit to the place of purchase to pursue service options.
Jan 15, 2010 | Insignia Digital-to-Analog Converter for...
I have a kodak sv1011 digital frame and it stopped showing the pics. it boots up and you can see the pics if you look closely but there is no back light so it won't display? is there a fix for this?
On the other side of your frame there is a reset button.
It is below a small hole on the left back side of the frame. You will need a poky device in order to press the button which is located within the frame.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jun 19, 2009 | Kodak Digital Picture Frame
The kodak easy share digital picture frame won't show my pictures
Pls. check if there is any reaction when pressing the buttons onto the frame.
Check the batt within the remote.
Reset the frame.
If all fails:
Contact KODAK:
Jun 14, 2009 | Kodak EasyShare EX1011 Digital Picture...
My Kodak Easyshare 1011 has recently started to turn off
The firmware of your digital picture frame needs to be updated but since you can't do anything because after a few seconds the frame will shut down it needs to be send for repair. To process repair visit www,kodak.com/go/itg. Follow the troubleshooting guide page and at the end of the troubleshooting guide you will be able to fill up a form to send frame for repair.
Jun 06, 2009 | Kodak EasyShare EX1011 Digital Picture...
Shuts off after short Use.
You can try to reset the frame by pressing the RESET button at the back of the frame try to check the small hole that only paper clip can fit in, once done with reseting upgrade the firmware of your picture frame again even it has the latest version of the firmware
May 06, 2009 | Kodak EasyShare EX1011 Digital Picture...
Downloaded pictures from camera go all over
You check the frame settings and see if the shuffle option is activated. You need to turn off the shuffle option for the oldest-newest order to take effect. Also, you may want to reset the frame. Press and hold the volume (+) and the power button at the same time to reset the frame to factory default.
Mar 31, 2009 | Kodak EasyShare EX1011 Digital Picture...
Shuts down
try these troubleshooting steps:
1. Turn the frame off.
2. Unplug the power cable from the wall outlet.
3. Remove any memory card or flash disk from the frame.
4. Connect the power cable directly to a wall outlet.
5. Turn the frame on.
6. Use a paper clip to press the button inside the pinhole on the back of the frame.
If after trying the above steps and the frame still have the same problem, then we need
to send the frame in for a repair as per warranty guidelines.
Your frame will be repaired per warranty guidelines. A product is warranted for 1 year from the date-of-purchase. For an In-Warranty repair, a “Proof-of-Purchase” is required. If the repair center finds any customer induced damaged, the warranty will be voided and you will receive a notification from the repair center in such cases.
Process the repair at www.kodak.com/go/itg
Feb 05, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Photography Logo
210 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Are you a Photography Expert? Answer questions, earn points and help others
