Sharp el 501w calculator fractions
Where is the fraction key?
4 Suggested Answers
  • 8 Answers
SOURCE: what keys due i use to calculate a fraction
To do fractions, just use the normal divide button.
To see the exact answer, hit MODE and scroll down to Exact/Approx and change to EXACT. In this mode, it will give the fraction always unless you press the special (green button with diamond) before pressing ENTER and it will give the approximate decimal value.
Posted on Feb 05, 2008
Tom-p34
SOURCE: how do i do a fraction on my calculator
ok i figure this is like any other calculator, but without a fraction button. A fraction i somthing / something . so instead of the fraction button use the division button.
Posted on Jul 08, 2010
SOURCE: We purchased EL-W535X sharp calculator.
on the key pad row above 7-8-9-(-) all the way to the left there is a key that says change with two arrows moving in a cicle press after each answer will change from even fraction to uneven fraction then decimal
Posted on Oct 17, 2011
Convert decimal to fraction
If you have just calculated some value and it is displayed in decimal format, you may be able to recover the exact fraction by pressing the key (change) or the fraction key [a b/c] itself.
Sep 24, 2014 | Sharp El-520x Advanced Scientific...
How to change a fraction to a decimal on a sharp el-53wh
Press the fraction key after you get the answer.
Feb 04, 2014 | Sharp EL-531VB Calculator
My sharp el-531x calculator is sowing my answers in decimals. how do i solve this problem
If you have a key marked [change] press it to toggle from improper fraction to decimal to mixed number.
If you do not have the [change] key, press the [a b/c] key to change from decimal to mixed number. Press [2ndF] [a b/c] to convert to improper fraction.
Dec 08, 2013 | Sharp el-531x scientific calculator
What is the key to reduce fractions ?
The EL-501 doesn't display fractions. Some of Sharp's other calculators do, but not this one.
May 03, 2013 | Sharp El-501x Basic Scientific Calculator...
How to enter fractions into the sharp el-501x
The EL-501X doesn't really work with fractions. You can always enter a fraction as a quotient. For example, you can enter 1/2 as 1 / 2, but you'll get 0.5.
Feb 18, 2013 | Sharp Shar El501xbwh El 501X Basic Science...
I have a el-531x how do i cauculate fractions with it
Use the key marked [a b/c]
  • To enter a mixed fraction, enter integral part, press [a b/c], enter the numerator pf fraction part, press [a b/c], then enter the denominator of the fraction and press =.
  • To enter a fraction or an improper fraction, enter numerator, press [a b/c], then the denominator and =
  • If the displayed result is a mixed number , use [2nd][a b/c] to convert it in a fraction (improper fraction).
May 22, 2012 | Sharp EL-531VB Calculator
How do you do a fraction on a sharp el531w
Hi eamon at hom,
Doing fraction on the Sharp El 531W really isn't that bad. I had to use pictures because, the symbols will not transfer over to your posting for me to show you. When you select the [ON/C] this clears the calculator of previous calculations and, data so that they won't interfere with your new calculations.
Let take the first example where a mix number is being added to a improper fraction. Because I used the [a^b/c] key this makes the calculator display the answer in a mixed fraction format or, a proper fraction format. If I press the [a^b/c] key again after the answer the format will change to a decimal format. The fractional formats are displayed in a mixed number, improper or, proper fraction formats. A improper fraction is really a proper fraction number with the top number (numerator) is greater than or equal to the bottom number (denominator).
[ON/C] [3] [a^b/c] [1] [ [a^b/c] [2] [+] [4] [a^b/c] [3] [=] mixed number results. Now let's do the same calculation as a improper or, proper fraction format.
[ON/C] [7] [a^b/c] [2] [+] [2] [a^b/c] [3] [=] still a mixed number result. Even though I enter the fractions in a improper and, proper fraction formats the calculator will still display in a mixed number format. This is because the calculator first displays as a mixed number if it can. If it can't then it will display the value as a proper fraction and, never as a improper fraction. To convert from a mixed number to a improper fraction format if the calculator did not convert it to a proper fraction, I have to use [2ndF] [d/c] keys on the command line.
This show a little more complex raised power use of the [a^b/c] key.
This shows the [2ndf] [x^-1] keys being used to calculate fractions.
When I first saw this question being asked it, was answered with just use the / command. Which that isn't really a good answer because, in math we like to use elimination. If you use the / command eventually the numbers are going to be rounded off and, your not going to be able to eliminate anything. If you have any further question on how to preform fractions with this calculator be sure to post your comment and, I'll be glad to help.
Jan 13, 2011 | Sharp EL-501WBBL Calculator
How can I convert decimal to fraction on Sharp 531WH calculator
After you perform the calculations and press the = key, you can hit the ab/c key to toggle between decimal and fraction. Try .75= then you can toggle between 1/4 and .75
Oct 14, 2010 | Sharp EL-531VB Calculator
How do i do a fraction on my calculator
Jul 07, 2010 | Sharp EL-501WBBL Calculator
Fractions
I checked the manual for the EL-501W calculator and I found out that it does not do fraction calculations. However yours may be able to. Look for a key labeled [a b/c] and a [2ndF] key [d/c].
If you have them then you can calculate with fractions.
The way to use the [a b/c] key is as follows
15 [a b/c] 7 [a b/c] 19 [a b/c] should allow you to enter 15 and 7/19.
A mixed fraction can be converted into an improper fraction by pressing [2ndF][d/c]
Jan 08, 2009 | Sharp EL-501WBBL Calculator
65 people viewed this question
k24674
jasbo
jasbo
