Question about LG Washing Machines
Beeping noise when powering on
I've loaded the machine, filled the detergent, when pressing the power button I get a beep-beep, beep-beep, beep-beep noise. No lights come on at all and the display panel does not illuminate. I have switched off and on at the plug, and checked the drain pump filter which is clear.
5 Suggested Answers
  • 38 Answers
SOURCE: Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Posted on Aug 26, 2007
futureloginn
  • 734 Answers
SOURCE: Zanussi IZ 12 Washing Machine Front Load
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Posted on Dec 03, 2008
  • 51 Answers
SOURCE: Stops drains and bleeps with only spin light illuminated
It sounds like you need to re programme the
machine.
With the machine plugged into the wall and
turned on and the headset turned off this is what
you do.
Push and hold down the start button, while doing that you need to then push and hold down the power button.
Hold them down for about 5 seconds, during
which time you may a series of up to 3 beeps.
Then release the buttons.
Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle.
This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
Posted on Jun 14, 2009
  • 713 Answers
SOURCE: MW512AU Fisher and Paykel top load smart touch
Hi Des, just read your posting.Now when you turn on the machine you say that some lights light up and it starts to beep.These lights will be in a row of 8 lights.Starting from left to right which lights are lit when the machine is beeping?Is it he 3rd and 5th or the 2nd and 7th ---etc---?Please reply with additional information on the question and I can help you rectify the fault.Looking forward to your reply.
Posted on Aug 18, 2010
New Control Panel instald all it does now is beep open lid stop beeping close lid nothing happens lights stay on help please
It is important to set the size switch setting into the Motor Controller's memory whenever a replacement Motor Controller and or Display Module is fitted
To set the size switch turn the power on at the wall and off at the machine. Press and hold the TEMPERATURE UP button then press the POWER button. SmartDrive will give 4 short beeps and the pattern of LEDs will change.
• Press SPIN SPEED UP button, the SPIN HOLD LED is on for (8.0kg) (650mm wide). • Press POWER to exit this mode.
If this doesn't work let me know
Jul 16, 2015 | Fisher and Paykel GWL11 Top Load Washer
Is there any way to silence the sounds these machines make when you turn the selector knob or push any button
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Apr 19, 2015 | Maytag Maxima MGD9000YW 27" Front-Load Gas...
My he2t kenmore front load washing machine won't power on and there's a clicking noise
Vicki, i think that clicking sound is ok when you press start. TRY THIS.
1. close door securely 2. press power after putting detergent.3 After making your selction for different levels eg hot,warm cold, press START.
usually these buttons are pretty reliable, GL
Jan 12, 2014 | Kenmore Front Load Washer
Kenmore washer HE3t won't turn on but is making beeping error sound when pressing power button. Is there a reset button to press or common problem
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 10, 2010 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@@
Jun 20, 2010 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
machine.
you do.
Jun 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
Wahing machine
Try pushing the skip button this may reset the prog. These machines will beep to indicate a fault. Dependant on how many times the machine beeps b4 it pauses ie 1 beep then a pause would indicate the machine isn't filling, 2 beeps its not pumping out, 4 beeps doors open. Hope this helps
Nov 30, 2008 | Zanussi FJS1225W Front Load Washer
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
GLW10US won't do anything but beep
well i don't have any experience with this brand but i would say you need to change the fill switch it senses how much water is in the tub shuts the water off then starts the washer its also called the pressure switch
Feb 16, 2008 | Washing Machines
Washing Machines Logo
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
