Question about Digi International Digi TransPort WR41-U - wireless router - cellular modem - desktop
Can't access router by it's username and password set. After reset router i phase same issue
  • Alain Nemours
    Alain Nemours Jan 04, 2014
    the router has already been configured but we has not been using it for quite long time, so i have modified the configuration and need to access router via it's username and password but it's noot accessible. has try to reset router for it default config but i phase same issue mean no access to router. i want to know if their any option which i can take to access the router without using the two methode i already mentioned.
Forgotten password for wifi network
Which operating system ??
Your wireless Internet password is the encrypted security pass phrase that was set up when you installed your wireless router.
Your router allows you to access the Internet.
If you have access to more than one wireless network, you may need to remember multiple passwords.
If you happen to forget one password, you have two options: reset your password or locate the current password.
Windows 7 allows you to view the security characters of all your wireless network passwords.
Click the "Wi-Fi" network icon located on the Window's taskbar.
Right-click the name of your network's "SSID" name and select "Properties" from the drop-down menu.
Click the "Security Tab." The network security key is now visible but unreadable.
Click the "Show Characters" check box and this will reveal your wireless password.
http://www.thewindowsplanet.com/939/how-to-recover-wi-fi-network-key-in-windows-7.htm
or
Reset My WiFi Password
Wireless networking is a common feature in homes and offices.
Wireless routers provide access to a single Internet source, and wireless passwords ensure that only select users can access the network.
If a password is forgotten or lost, the password can be recovered or reset by accessing the router's Web-based settings menu.
Most wireless routers also have a reset button, which is capable of returning the router to its default settings which includes resetting the password.
Connect to your Wi-Fi or attach your computer directly to the router with an Ethernet cable.
Open your Web browser.
Enter the default address of your router.
The default address is listed in your user manual or on the product website.
Linksys and 3Com routers typically use "192.168.1.1" while Netgear routers use "192.168.0.1."
Enter your username and password.
Many routers use "admin" for the username and password by default.
Locate the wireless security settings. Disable the wireless security.
Reset to Factory Defaults
Locate the reset button on your router.
Typically the reset button is a small indented hole on the back of the device.
Insert a long thin object such as a paperclip and hold down the reset button for 30 seconds to revert the router to its factory default settings.
Locate the wireless security settings and add security as necessary.
How To Reset Your Router's Password
http://www.lostintechnology.com/how-to/how-to-reset-your-routers-password
Jan 06, 2014 | Computers & Internet
How do I recover a forgotten password for an overdrivepro63E wireless internet stick
Open your Web browser. Enter the default address of your router.
The default address is listed in your user manual or on the product website. Linksys and 3Com routers typically use "192.168.1.1" while Netgear routers use "192.168.0.1."
Nov 05, 2013 | Computers & Internet
How do I reset my password?
Step 1:
Wireless networking is a common feature in homes and offices. Wireless routers provide access to a single Internet source, and wireless passwords ensure that only select users can access the network. If a password is forgotten or lost, the password can be recovered or reset by accessing the router's Web-based settings menu. Most wireless routers also have a reset button, which is capable of returning the router to its default settings which includes resetting the password.
Connect to your Wi-Fi or attach your computer directly to the router with an Ethernet cable. Open your Web browser. Enter the default address of your router. The default address is listed in your user manual or on the product website. Linksys and 3Com routers typically use "192.168.1.1" while Netgear routers use "192.168.0.1." Enter your username and password. Many routers use "admin" for the username and password by default. Locate the wireless security settings. Disable the wireless security. Reset to Factory Defaults Locate the reset button on your router. Typically the reset button is a small indented hole on the back of the device. Insert a long thin object such as a paperclip and hold down the reset button for 30 seconds to revert the router to its factory default settings. Open your Web browser. Enter the default address of your router. The default address is listed in your user manual or on the product website. Linksys and 3Com routers typically use "192.168.1.1" while Netgear routers use "192.168.0.1." Enter your username and password. Many routers use "admin" for the username and password by default. Locate the wireless security settings and add security as necessary.
Feb 27, 2013 | Computers & Internet
I cannot reset my password
Im presuming its your internet connection password ?
Your Internet service provider (ISP) requires a username and password to access service features, including Internet and email.
Your ISP should provide this information when you set up your Internet service.
Typically, once you complete the setup and save the information, your router or modem transmits it behind the scenes when you try to access the Internet.
As a result, the username and password can be easily forgotten because they are not used daily.
If you reset your router or simply forget the password, gaining access to network resources and the Internet becomes a challenge.
Call your ISP's technical support department.
Many ISPs set a default username and password for their routers.
If you didn't change the username and password, your ISP can provide the original information.
Before you hang up, make sure the information is correct by entering it and trying to connect to the Internet.
If the information is incorrect and you still cannot get a connection, keep the information for later reference.
Call your router's manufacturer.
The manufacturer of your router sets a username and password prior to shipping the device to your ISP.
Look at the router for the contact information of the manufacturer.
Call their customer service or technical support department and ask for the default information.
Reset your router.
If you changed your router's username and password and cannot remember what you entered, you may have to reset the router.
Insert the resource CD into your computer's CD drive.
When the software installation program starts, search the screen for "Resources" or "Documentation" or "User Manual."
Click the documentation link and search the table of contents for resetting the router.
When you reset the router, the username and password return to the default set by your ISP or manufacturer.
Enter the information provided by your ISP or manufacturer.
Hope this helps.
Nov 15, 2012 | Computers & Internet
Hi my belkin F7D5301 wireless router light has went from a solid green color to a solid amber color and now i cant connect to the internet unless i bypass the router i have tried resetting the router but...
It just can be ISP issue.To fix belkin router from a solid green color to a solid amber color.
Just follow these steps and let's see if they work for you
1.Restart the Modem then after 20 sec restarts the Belkin wireless router
2.After restarting you need to wait for 2 minutes
For more you need to visit https://fixingblog.com/why-belkin-router-is-blinking-orange-and-not-working/
It will be help full for you
Sep 06, 2011 | Belkin Wireless Surf Router (F7D2301)
How can i find out my pssword.
The default username and password for Linksys routers are:
Username: admin Password: password
or
Username: admin Password: admin
or
Username: <no username> Password: password
If all of this fail you'll need to reset your linksys router so that it will also reset the password to the default. To reset you linksys router you can check it out on this website: http://technicallyeasy.net/2008/01/how-to-reset-linksys-wrt54g-wireless/
Note: Reseting your router means it's going to reload the factory default settings and all of the settings that you made on your router will be deleted permanently.
Apr 23, 2011 | Linksys Wireless-G WRT54G Router
RE INSTALL 2.4 GHz WIRELESS-G BROADBAND ROUTER .CANNOT RECALL PASSWORD CANNOT COMPLETE SET UP&gt;?????? JERRY HELP. jerry.morey@sbcglobal.net
Perform a hard reset by inserting a paperclip into the reset hole while powering up. To access the router use address http://192.168.1.1
On older LinkSys routers, the username is set to blank and the password is set to "admin" (without the quotes). On newer Linksys routers, both the default username and the default password are set to "admin".
Mar 05, 2011 | Linksys Wireless-G Broadband Router
I am trying to helpy parents. They have a netgear wireless router. We know the ID but my mother made an 8-character long password that no one can remember. The router was originally set up on a computer...
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
Try using a pen or paper clip to press the reset button on the back of the device. Keep the button pressed until the lights in the front of the Netgear router start flashing. The router will reboot after resetting the configurations.
Open a internet explorer browser window and enter 192.168.1.1
the Netgear router configuration console will open and will prompt you to enter username and password
Enter the default username and password. Now that settings have been reset, you can use the Netgear global default username and password listed below:
username: admin
password: 1234 or password
Unplug the router's power cable if these passwords do not work. If you are still unable to login, the router may not have been reset. While the router is unplugged, hold the reset button for 20 seconds before plugging in the power cord. Repeat Steps 2 and 3 to gain access to the router, using the new admin username and password
Dec 26, 2010 | Computers & Internet
Linksys wrt150n
username is blank and password is admin.
However I have seen some routers not follow that. Those will sometimes have a username of admin with a blank password. Try the first one first.
Mar 09, 2010 | Linksys Wireless-N WRT150N Router
Forgot linksys password
Reset your Linksys router back to default:
The easiest method of resetting your Linksys router’s password is to reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password “admin”, in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to “admin” on some of the newer Linksys router models).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 31, 2009 | Dell Inspiron 6400 Notebook
Digi International Digi TransPort WR41-U - wireless router - cellular modem - desktop Logo
18 people viewed this question
Top Digi International Computers & Internet Experts
David Payne
David Payne
Are you a Digi International Computer and Internet Expert? Answer questions, earn points and help others
