Question about Buffalo Technology Buffalo Hd-pnt1.0u3r Ministation Plus 1.0tb Hard Disk Drive hdd Red
My buffola hard drive is being recognized as Buffalo Virtual Cdrom USB device I have changed cable also went to another computer still seeing it as CDrom
    Problem Solver:
  • 12 Answers
Virtual Cdroms are used to provide the computer with drivers. As soon as the driver is installed, the Cdrom should disappear and the harddrive should be revealed. Windows used to autostart the Setup utility, but since this is a security risk, this was disabled.
You should try to manually run the setup or switch to a drive that is supported out-of-the-box.
Posted on Jan 17, 2014
HD-PNTU3 recognized as cdrom
No dont see it doing that cd/dvd and hard drives both seta and peta ares still all IDE devices so try to find it in your bios set up . but for "normal" install it should auto install the device firm ware and be visible in my computer as a removable mass storage devise
Sep 14, 2013 | Buffalo Technology Buffalo - Hdpnt500u3s -...
My buffalo drivestation external harddrive don't power up?
A USB hard drive is a portable external storage device that works just like a conventional hard drive. The device is simply plugged into a USB port on your computer as you would connect a flash drive. Unlike a flash drive, however, a USB hard drive can store a much larger amount of data. If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely. Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7). The USB device should be listed as "removable disk" once it is plugged into the computer. If it is not listed among the available drives on your computer, proceed to the next step. Ensure that the data cable is working properly. Sometimes they become faulty due to overstretching age or heavy objects sitting on top of them. Try another USB cable if you have one available. Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive. Reboot the computer if the USB hard drive is still not recognized. Plug the USB cable into another USB port and check to see if the device is detected. If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port. If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem. Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager." For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter." Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives." If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears. Windows 7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. If the hard drive that has failed is the same one that you are trying to recover from might the reason that you are getting this error. This could be an issue where the part of the hard drive you are trying to access is corrupt and not accessible which would explain the reason that it would let you access the other partition. Now I have seen cases where Malware can break the link of a Hard Drive. So let's try a couple of steps. Let's go back in to "Disk Management" Lets right click on the partition that you are not able to access and select "Change Drive Letter and Paths" Now try selecting a new Drive Letter. This will restore the path if it has been broken. The external hard drive may have been detected but the device is not working properly. If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced. Hope this helps.
Jan 02, 2013 | Buffalo Technology Buffalo 1TB Drive USB...
Windows 7 won't recognise buffalo hd-ce1.otu2
you might back up your data to another drive if possible
then format your buffalo drive then transfer it back
i have had similiar issues with xp and w7 using usb drives and have found that i have to designate certain usb drives to the computer running windows 7 and same running xp
if i try to use the one designated to windows 7 in my xp get this drive is not formatted do you want to format
although these drives are not buffalo just usb data drives but of large capacity 128GB
make sure the lead/s that attach to your hard drive are securely seated
if your computer came with a motherboard disc the drivers could be on it
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
hope this helps
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Feb 13, 2012 | Buffalo Technology Computers & Internet
During a recent power surge my Buffalo 2TB external hard drive has ceased to power up. Does it have an internal fuse that may have blown ?
i dont know of any fuses in these usb hard drives
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Sep 22, 2011 | Buffalo Technology HD-CX500U2(1071) 500GB...
500gb buffalo external hard drive not working in my win 7 computer. not able to format as well..as there any way to format it.
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
click start click on my computer you should see your drive
right click then select format
another way is to control panel administrive tools computer management disk management right click on your drive select format
hope this helps
Jun 12, 2011 | Buffalo Technology (USA), INC. - 500GB...
The drive is no longer recognized by the computer. When I plug it in the computer slows and freezes. When I unplug it the computer goes back to normal. Drive is Buffalo Drive Station External USB 2.0...
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
hope this helps
May 02, 2011 | Buffalo Technology DriveStation HD-HC500U2...
My Buffalo HD-PX320U2 External Hard Disk have a strange problem, after I've input the password the computer won't recognize my storage drive
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Dec 11, 2010 | BUFFALO hop 320GB MINISTATION METRO(...
I have a 500GB unit - my computer, running Windows
maybe you need to reinstall usb drivers. did you check device manager to see if any conflicts exist?
if you need help doing this please reply. good luck
May 13, 2010 | Buffalo Technology 320GB MINISTATION TURBO...
Buffalo Technology Buffalo Hd-pnt1.0u3r Ministation Plus 1.0tb Hard Disk Drive hdd Red Logo
217 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
hellics
Level 1 Expert
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
