Question about Sinclair SC488-HF9LDFD00 - 694-746 MHz 10dBd Collinear Omni
Loosing power between battery input and keypad
Key pad does-nt get power while battery is conected
My keypad stopped working. Is there a battery for this?
if your keypad is factory installed there is no battery . if after market yes has battery. if factory, be sure no keys are in car, when you press in a code number does the pad light up ,if yes its getting power then it is probably the keypad needs to be replaced ,if not lighting up its not getting power, check fuses and wiring connections
Dec 23, 2014 | 2005 Ford Escape Limited
My keypad are not working....
there is a flex cable which connect from the mother body to the key pad panel, if this cable is not conected properly the key pad will not work.
Mar 20, 2011 | Motorola Mobility L6 Cellular Phone
Keypad in w350i not working...how 2 repair tat
Remove the external key pad and press the internal keypad on the phone board directly, may be the external key pad rubber is not contacting the one on the phone board.
Or you can loose the phone, and clean the internal part of the key pad. There might be dust on it, you could also use this medium to service your phone. If it does not work after all these, then I think you have to change the key pad completely.
I wish you the best.
Nov 23, 2009 | Computers & Internet
My blitz doesnt text
Try this. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
Hope this helps, let me know if this works or if I can help you with anything else.
JimmyC
Aug 05, 2009 | UTStarcom Blitz Cell Phone
Keyboard will not work
Try this and see if this works for you. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
Let me know if this works for you, if not let me know.
JimmyC
May 07, 2009 | UTStarcom Blitz Cell Phone
No power to key pad after new battery put in
correct polarity. what battery. 9 volt or a23, did you recode combo byu hitting learn button for a second and then entering combo.
Feb 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Won't accept key input
There might be a problem in ur.....key pad. Did u tried to install the previous battery.......again.....
Jul 14, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Sinclair SC488-HF9LDFD00 - 694-746 MHz 10dBd Collinear Omni Logo
81 people viewed this question
Top Sinclair Radio Communications Experts
eradiostore
eradiostore
Are you a Sinclair Radio Communication Expert? Answer questions, earn points and help others
