Question about Sharper Image Ionic Breeze 3.0 Air Purifier
Dead variable motor will not start
Why is there delayed start & screeching?
The motor needs to be oiled. There are places to add oil on the ends of the motor. There may be a start capacitor that needs replaced too.
Jul 05, 2015 | Honeywell 17000 Air Purifier
Environizer doesn't work
Is it dead? does the motor run? Fan blow? No freshened smell from unit, only stale odor? You haven't given any usable info here but I'll address a dead unit condition for you: power cord stretched/damaged, on/off switch bad, fuse/cicuit breaker(if any are used).
Jun 15, 2014 | Air Purifiers
Wont turn on
does the lights come on but the motor does not turn, if it is this it can be the starter for the motor inside next to the motor is a started solenoid this starts the motor to run. when they start to fail you get a buzzing sound or a humming, eventually it just fails. also the motors are prone to fail after time, and they don't do replacements for this part
Mar 30, 2014 | Air Purifiers
GE Adora microwave worked 20 minutes ago. Now, totally dead. The lights, fans, turntable motor, microwave cooking elements, nothing.. works. AC power to the outlet is just fine.
Sometimes if a lot of steam has been produced while cooking, water may collect under the turntable plate and run down the spindle into the turntable motor. This can short circuit the motor and it will take the fuse out with it.
The fuse is usually housed in a plastic tubular case about 2inches long. Split the tube apart and replace the fuse if necessary (it's something silly like about 7000 volts). Switch on and check to see if anything else is not working like the turntable, lights, or fan etc and replace as necessary.
Feb 16, 2014 | General Electric DVM1950SRSS 505 Adora...
Eureka abs AS1050 will not power on?
There is a wire in the motor housing that comes loose plug it back up and it should start
Nov 30, 2013 | Eureka AS1104A Bagless Upright Pet Vacuum...
I HAVE 2 MODEL SI861 IONIC BREEZE UNITS. I BELIEVE I BLEW THE FUSES BUT CANNOT FIND OUT WHERE THEY ARE LOCATED. CAN ANYONE PLEASE HELP. THANK YOU.
There may be a thermal fuse in the vicinity of the motor, it may be held to the motor, there will also be one wrapped in the windings just for the motor, or it may just be covered with a section of black shrink wrap. It will have a current rating and a temperature rating as well. Otherwise look closely on the control circuit board as a "pico fuse" really small fuse can be there. It's only indicator will be a current rating like "2A"
Feb 13, 2012 | Sharper Image Professional Plus Ionic...
Have a Living Air XL15 > everything works motor, fan, BUT .....
look through the front grill while its "on" you should see a glow from a neon lamp inside. If its not on chances are the circuit card is dead (should have about 350VDC plate voltage).
I have a used but good board if anyone needs one.
dale.gilchrist@gmail.com
Apr 26, 2009 | Ecoquest Living Air Classic Air Purifier
My Venta Airwasher LW44 motor won't start
Test the motor to see if it works. Make sure the motor is removed from the rest of the unit. To find out how to remove the unit please hit the "Go Back button and select the "How to remove the motor button"...
  1. Plug the unit in to a working outlet.
  2. Push the #1 speed button on top of the motor.
  3. You now need to engage the saftey switch to start the motor.
  4. Protruding from the motor are two plastic about 3-4 inch guiding arms.
  5. Look inside the end of both of these two guiding arms. One of the arms are hollow and the other one has a white safety switch in the arm.
  6. Use a pencil or small item to push in on the safety switch.
  7. If the fan sarts to rotate the motor is still working.
  8. If the fan does not rotate then the life of the motor has probably ended and a new motor is needed. ( insert motor part link)
For additional support email abdistrsupport@gmail.com
Nov 16, 2008 | Venta - Airwasher LW44 Air Purifier
Fan motor is dead I think...is it okay to run ionizer still??
no , it is not advisable to run the machine while there is an exsisting problem , it would be best not to run it untill the motor has been replaced
electech
Nov 07, 2008 | Ecoquest Flair Air Purifier
Sharper Image Ionic Breeze 3.0 Air Purifier Logo
26 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
