Question about Nortel Lands Phones
Nortel ntys19 Hi, I need to reset the time on this phone can you please advise?
2 Suggested Answers
dstrocen
SOURCE: need to reset the time on a client's nortel phone....
Press "OPTION" 27. OR Simply press "OPTION" and then us the scroll buttons to scroll through the list of options until you come to TIME/DATE
Posted on Jul 26, 2012
Nortel T7316e Mbox Locked, reset password
The system administrator must reset your password - it will default to 0000. advise if you are the system admin.
Oct 19, 2017 | Nortel Lands Phones
NORTEL IP 1140E + BT 2 WIRE ROUTER.
Try a different phone on the same router, does that fix it?
Dec 20, 2013 | Nortel 1140E
I have a Nortel Telecom Meridian phone at work. I often get unsolicited calls on my work phone and I just want to ignore them instead of answering them. How do I mute the ringer on my Meridian phone. It...
You can use the do not disturb function on your set. When used it will stop all ringing on your set(both line ring and intercom ring). To turn on DND, press feature 85, to turn the DND back off press feature #85.
Sep 10, 2010 | Nortel Meridian M7208 Corded Phone
Hi Team We replaced our existing Nortel Switches with Nortel 2550T 48 Port Switches and since then our VoIP phones are not getting IP from DHCP. Putting static IP is working. Can you please guide me...
As you described it there shouldnt be any problems with your configuration, there should be auto ip conf. enabled so VoIP phones should accept 1st IP range automatically. If that doesnt help contact your operators. Thats all. Good luck!
Please rate my solution! :)
Aleksandar Adzic
Aug 23, 2010 | Nortel 2550T 48-Port Ethernet Switch...
Need to reset the time on a client's nortel phone.
It depends on which Nortel System your client uses, and which level of software they have in the system. You can try "Feature * * T I M E" (Feature, star, star, 8 4 6 3). If that doesn't work, we'll need more info about the system. Good Luck!
May 20, 2010 | Nortel Norstar 16-Line PBX Speakerphone
I am locked out of my admin mailbox on my nortel nt8b26aabl phone, when i use feature 983 and then password 102000, it says invalid password.???
to reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000.
Dec 11, 2009 | NorStar T7316E Corded Phone
I am considering buying a Nortel T7208 2 Line phone for my home office. I have two separate lines, with two separate numbers. I need a phone that will allow me to plug both lines into the desk top unit. I...
Hi there...
OK, the Nortel T7208 set works only on a Nortel system.
It has only one line cord plugged into it, cause the telephone system can be programmed for more telephone lines and features from the system.
If you want just a home (analog) telephone service; look at Aastra/ Telematrix/ there are others - 2 line sets.
ONLY buy this Nortel set is you have a Norstar system. Otherwise the set will not work for you. It needs a system to run off.
Good luck in your search!
Aug 29, 2009 | Nortel Business Series Terminal T7208 -...
Meridan 7208 help please
Dear sheryl498,
Your phone is designed for a PBX (Private Branch Exchange) unit like the Compact ICS or the 6x16 TCU that was at the office. It is not compatible with regular POTS lines or standard home lines.
Jul 29, 2008 | Nortel Meridian M7208 Corded Phone
I have nortel phone ip 2002 i want use for my own carrier i need to reset
1. Reset the phone by disconnecting and re-connecting power.
2. When the Nortel logo appears, press each of the four soft keys in sequence.
3. If no other configuration changes are required, press OK repeatedly until the “PC
Port? 1-ON 0-0FF
” option appears.
4. Press 1 to enable the PC Port or 0 to disable the PC Port.
5. Select OK to confirm the change.
6. Restart the IP Phone.
When the IP Phone is restarted, the firmware sets the PC Port status accordingly
Apr 20, 2008 | Nortel 1140E
Problem with IP phone Nortel 1120E
Try to reset the bandwith of the phone by using the nortel software.
Jul 11, 2007 | Nortel 1120E
Lands Phones Logo
Top Nortel Lands Phones Experts
David Burbee
David Burbee
Oloyede Monsuru
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
