Question about Cell Phones
Motorola 2-way Radio
I am looking for instructions on how to setup a Motorola XPR 5350 2-way radio.
    Master:
  • 517 Answers
There is very little the end user can do. You need the programming software which must be purchased from Motorola with a Licensing agreement. Or you take it to a Licensed Dealer and pay them.
Posted on Mar 03, 2014
I have purchased a second hand set of Motorola xtnid radios, the old company's name is still displayed in the screen when I first switch it on, how do I remove it ?
Depending on the radio, mots Motorola business radios are programmed with a computer and a cable that attaches the radio to the computer, or a programming RIB. This all depends on the age and model of the radio, but since you said that a companies name appears in the display, I am pretty sure it is a business band radio that has to be professionally programmed. I say professionally because even if you have everything you needed to program the radio, I sincerely doubt that you will be able to do it. Motorola software is called CPS, but then again, it depends on the age of the radio, newer Mototurbo XPR radios use a much newer software, and they interface to the computer in a different way, that is without the use of a programming RIB. A RIB is a box that goes between the radio and the computer, newer radios only need a simple USB cable that is made to mate the radio to a uSB port.
Dec 09, 2015 | Radio Communications
How do I change the power up volume level.
David
Contact Motorola Solutions.
Get Support
Mark
Motorola Mobility Support
Jun 23, 2015 | Motorola XPR 4550 Two Way Radio
Motorola xpr 6500: How do I reset to factory condition?
This type of radio requires programming with Motorola software and a programming cable.
Mar 20, 2014 | Motorola Radio Communications
I am trying to program a xpr 4550 with a talkaround channel that is the same feq as a repeater channel with no luck.
Be sure "talkaround" is enabled on the code-plug, then use the "direct" or "talkaround" button on the front panel.
Jan 28, 2014 | Motorola XPR 4550 Two Way Radio
Motorola 4550 locked out
Hi Michael,
The answer is yes.
You need to reset your radio to factory default settings to be able to once again, use the radio. Your friend software will be required to do this, so... CHOP, CHOP, hop to it.
I hope you have been helped here.
Cheers,
Peter
Jun 28, 2012 | Motorola Xpr 4550 Two Way Radio Xpr4550...
I need to wire external speakers to a Motorola XPR 4350
usually when buying a 2way radio they come with a headset (a headphone and a mic) all you need to do is cut the mic and headphone off using the wires for the headphone solder them to a speaker.
(the higher the power of the speaker the more it will drain your battery)
Mar 22, 2011 | Motorola Talkabout SX900R Two Way Radio
Can you leave a Motorola XPR 6350 radio turned on while in the impres charging base? Basically I would like to leave the radio on at all times to hear any traffic, but I do not want to damage or shorten...
The radios will work just fine while they are charging, but the charging process will take longer, and I recommend that you do not charge the radios for more than 12 hours at a time. My Midland radios sit in the charger base all the time, and I just push them down to engage the charging function.
Bill B.
Nov 16, 2010 | Motorola Radio Communications
Motorola T5622 VOX Not Activating with Autocom Sys I have an Autocom (Kit 300) motorbike coms system. I bought the accessory cord that interfaces to the Motorola T5622, for VOX I have followed the Motorola...
Hi Folks, two seperate checks to do - to check vox on autocom and transmit on motorola. With the T5622 unconnected to anything, does the push transmit button work - e.g. does it make the beep noise at the end of transmission?
Does your autocom work with any other sound sources - i.e. mp3 player so you can hear music. Does this mute when you speak ? (it should if vox is working). Note that in this setup vox is provided by autocom - NOT BY THE T5622. The instructions you mention are for the motorola vox kit.
Wire the two together and you should get the motorola beeping through your autocom at the end of transmit - that's what my kit 200 does with my T5622.
Mar 13, 2008 | Motorola Talkabout T6310 (14 Channels)...
Cell Phones Logo
29 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
