Question about GE GSH22JFT Side by Side Refrigerator
GE Model GSH22JFTA Top of Fridg and Freezer not cold
Everything seems to function, the freezer now seems to have alot of frost build-up on the lower back wall. Again, both lower halfs are cold, it seem no air is circulating. When the unit is on the damper/thermister open fine, the fan is running, all vents are open? Help Please
  • 700 Answers
Check the door gaskets for air leakage
Posted on May 21, 2009
My Westinghouse Frost Free fridge is not working. The freezer is working. It is has the freezer on top of the fridge, separate doors
Even though it is frost free, try defrosting it by turning it off with the doors open for a few hours. There may be ice or something else blocking the vent between the freezer and refrigerator sections. Of course you will need to remove everything from the fridg and freezer and store it somewhere else that is cold.
Dec 22, 2014 | Westinghouse Refrigerators
My ge refrigerator side by side gsh22jfta ww freezer is cold enough but the fridge is not there is a vent between freezer and fridge, but I don't feel any cold air comming from it. Plz help me
The "damper" that open and closes is not working. It is controlled electronically with a thermostat. Here is the part to order.
All parts come with a 365 day, any part, any reason return policy
Apr 06, 2013 | Refrigerators
I have a Hotpoint hss251fmd and the freezer and refrigerator are getting warm at the top. the bottom and the back are cold. The freezer Is cold but not freezing everything. There's alot of frost inside...
Sounds like defrost cycle has been altered. Look into back of freezer and see if a layer of frost is building. If yes then unplug and place items from freezer into an ice chest or another freezer. Remove the panel that showed the frost layer and defrost the evaporator coils with a hair drier Examine the WR51X10055 Defrost Heater and test if you cannot see burn marks HERE It does not hurt to also change the WR50X10068 Defrost Thermostat Instructions on replacing the defrost thermostat are also on the same page. Here is a=> Service Manual
I will be here to answer any questions, Thanks Sea Breeze
May 08, 2012 | GE Refrigerators
My fridg and freezer is cold but not could enough the freezer wont keep food frozen. there is no ice build up, I replaced the defrost timer, and I cleaned the fan in the back what else could it be please...
Hello Nicole,
Their are a few things that couldbe causing your refrig.troubles.
1) their is ice build up in the return air vents that is not allowing air to flow correctly
you can see the air vents under the crispers in the ref.floor and can see if they
blocked with ice.
2) the freezer fan is bad and not circulating cold air into and out of the ref.
3) In addation to the defrost timer,perhaps the deforst heater and defrost thermostat are bad and frost is building up in the freezer,Do ya see frost
build up in the freezer??
GENE
Sep 21, 2011 | Amana BCI21V1C Bottom Freezer Refrigerator
Frost build up on the back wall of the freezer
The thermostat is not functioning the way it should leading to frost build up. You need to replace it. Should cost you around 40$
Sep 02, 2008 | GE GSS20IEM Side by Side Refrigerator
Ge side by side not cold enough in fridge or freezer
if there is no frost build up in freezer section sounds like a refrigerant leak
Apr 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refridgerator freezer GE
Frost is due to outside air leaking into unit. Check on back wall to see if hole for ice maker fill tube is still plugged. If not and you have no ice maker cover hole with tape. Also look for water or ice build up in bottom of freezer or ref. sections. May have a plugged drain. Let me know what you find.
Nov 11, 2007 | Refrigerators
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
GE GSH22JFT Side by Side Refrigerator Logo
580 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
