Question about Refrigerators
Cant Get fridge and freezer to cool to correct temp
Samsung Rb215labp. Al of a sudden fridge and freezer won't cool. Cleaned coil and waited 24hrs. now freezer does freeze things, have it set to -25 and displays -1c. Fridge is warm and displays 1c. Fridge coil is not iced up. Is there a problem with main board or perhaps another coil in freezer that could be frozen up? Panel shows error 12
    Filmmaker:
    Uploaded 5 video answers.
  • 18 Answers
According to the picture posted the freezer defrost is stuck on. Why it would not get cold enough. Contact a local appliance repairman and get professional help as this should require control board repair/replace.
Posted on Jan 05, 2014
4 Suggested Answers
huuum
  • 750 Answers
SOURCE: fridge/freezer not cool.
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
I believe your problem is an old thermostat or compressor !
How old is it?
My advice is do not put good money into bad!
A new fridge will pay for itself in a few years by using a lot less electricity!
Here is an interesting report I just read!
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please remember to leave me a rating before you sign off!
Thank You, HUUUM
Posted on Sep 29, 2008
SOURCE: Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Posted on Nov 23, 2008
  • 31 Answers
SOURCE: KENMORE MODEL 596 BOTTOM FREEZER, FRIDGE NOT COOLING
The freezer will stay cold because a small amount of cold air will be forced through the frost but that will not be enough to make it up to the refrigerator portion. You can defrost the unit by removing the metal panel and allowing the frost to melt. Careful use of a hairdryer can speed up this process. This will likely be a temporary fix. The root cause of excessive frost can be caused by a bad door seal or a defective defrost circuit.
First check that the door seal is good by closing the door on a dollar bill at several points around the door, both on the freezer and refidgerator door. If you can pull the bill out with no resistance, the door is not making a good seal. Inspect the seal and make sure there isn't anything stopping the door from closing such as food, or a shelf not pushed in all the way.
If the door seal is good, the defrost system is likely defective. The defrost system has three main parts, the defrost heater, thermostat, and timer. None of these parts are particularly expensive, or difficult to replace you feel comfortable with repairing it yourself. If you can troubleshoot this by manually starting the defrost cycle. Let me know if you would like this procedure.
Posted on Jan 07, 2009
Rb215labp Samsung fridge with freezer on bottom isn't working correctly. Fridge got cold after I defrosted it but only last 24hrs or so and keeps accumulating frost/ice on the back. Freezer doesn't hardly...
This is a twin cool unit. refrigerator works independently from freezer unless compressor failure so compressor is not the problem. you may have a defrost problem or an evaporator fan failure in the freezer easy way to check open door hold the door switch and listen for fan draft if you hear it is good is not you have a bad fan or a bad door switch. the refrigerator has a defrost problem usually is the sensor you try that the other thing can be the heating element but rarely goes bad.
Amazon com DA32 00011E Amazon com DA47 00095E
Dec 20, 2014 | Refrigerators
Fridge won't cool past 57 degrees
Guessing ether a fan, damper our defrost issue. Sorry cant be much help.
Aug 19, 2012 | Samsung RF266ABRS Bottom Freezer...
Fridge won't cool below 60, freezer won't go above 20
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 08, 2011 | Refrigerators
I have a samsung RS2578BB side by side refrigerator. my problem is .. the fridge side is not cooling sufficienlty , even after i set the fridge temperature between 46 F and 34 F. At first, the panel...
this is a common fault, you need to replace the defrost heater and thermal cut-out in the fridge section behind the salad buckets, a temporary fix for a few weeks is to switch the whole thing off at the wall and leave the fridge and freezer doors open for at least 24hrs to allow the frozen up evaporator to defrost.
regards
Ian.
Apr 17, 2011 | Samsung RS2578BB Side by Side Refrigerator
Samsung refrigerator freezer not freezing
I just returned the same fridge to Lowe's where I bought it using the warranty for the same problem. The temperature sensors went out, and everyone said the computer board needed to be replaced but no one could seem to get it together enough to order us one. Month later we are getting a new fridge.
Jun 02, 2009 | Samsung RB215LASH
GE Bottom Freezer Refrig
i assume this is a frost free type with air drive from freezer to fridge to cool fridge.
if so, take back plate off inside freezer and you may find ice build up especially towards the top of the coils. melt off with a hairdryer carefully. the nother thing that may happen is that the return duct for air from the fridge may also become blocked with ice. this is more difficult as it is usually hidden behind the coils and the best bet in this case is to switch off for 24hrs with the door open
Oct 06, 2008 | GE PDS22SBRLSS Bottom Freezer Refrigerator
Fridge is hot while freezer works fine
Defrost for 24hrs with doors open, turn back on it will then work ok. Regards Advisor
Aug 18, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
248 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
