Question about Panasonic TX-32PL10 32" TV
When turned on,only red signal comes on but the screen dont plz help
Rgb internal wires which ones can u use to convert it into red, white and yello at other end for tv
RGB is a term that means the guns in the crt or other display are only driven by amplifiers for that color. So you have to have seperate signals and inputs for red,green and blue. Those come from the source in that method. They are then fed into the monitor for which each of those colors has its own channel and amplifier. If you dont have something that is supplying the RGB singals then it is of no use. The colors that you listed as red white and yellow are for COMPOSITE video with AUDIO. The yellow is the whole video signal and the red and white are stereo sound signals. No attempts at making that work will correct this unless you buy a converter.
May 14, 2014 | Philips 107E66 17" CRT Monitor
95 mustange gt brake light dont work check #9 fuses change all bulbs replaced switch on brake pedal hazards lights works ,parking or running lights works,turning signal lights works,what other places i...
I assume the fuse has power if the hazards work.
The third brake light skips the turn signal switch, the regular brake light circuit goes thru the turn signal switch.
Do you have power going into the turn signal switch on the red lite green wire from the brake switch ?
Feb 17, 2013 | 1995 Ford Mustang
I have an 02 kia sportage. my signal lights come on but dont blink outside. no lights for the signal lights come on on the dash at all. also, no hazard lights.
If the 15A HAZARD fuse in the passenger compartment fuse box is OK, power is getting to the hazard function of the flasher unit. Pressing the hzard switch should cause the hazard lights to flash. HOWEVER, there is an electronic time and warning indication system module connected to to the hazard switch lead and that may be affecting things. If the 10A TURN fuse is OK, power is applied to the turn switch (with the engine in START or RUN) and you state you can select a right or left turn. HOWEVER, the RED/WHT and RED/BLU outputs from the flasher unit connect directly to the front and rear turn lamps and the instrument cluster turn indicators so you are not getting any flasher output. Again, that electronic time & warning indication system module could be affecting things
Oct 26, 2012 | Cars & Trucks
Blue screen and power button red
protron pltv-27 cm screen lights up then green comes on and turns red no signal.
Sep 27, 2012 | Protron PLTV-32 Television
When i power on wii it stay black and my disc eject work n power button n the led blink blue 1 time but screen stay black plz help me my wife goin to kill me it her wii
have you check the input on your tv , make sure you are at the right input , also check you cables , these cables sometimes come loose
Feb 20, 2012 | Nintendo Wii Console
My turn signals dont work in the frunt but they work in the back. bulbs are new in the frunt i just put new ones in and still nothing works in the frunt i got a flasher but i dont no where to put it plz...
to start with if the flasher unit was faulty none of the turn signal lights would work, your problem may be the wiring to the front signal lights a loose wire or connector plug,you need to check all the wiring to see if you can find the problem......hope this helps.....cheers.
Sep 19, 2011 | Buick Century Cars & Trucks
Ps2 controller buttons dont work
I have the same problem!
my BLACK
i actually have 2 controlers and both of them dont work on this game i dont know why..
but when i restart my PS2 and the menu pops up i can move upi and down and all the buttons work, how come they don work in the game?!?
Jan 16, 2009 | Sony PS2 Dual Shock 2 Controller...
PLZ HELP SIDEKICK 3 SCREEN WENT RED AN GREEN
reylakers-
You can try and reset the flex cable on the lcd.
follow these instructions.
Fix Sidekick White LCD Screen
If that doesnt work then a new lcd screen unit will.
http://repairmysidekick.org/SideKick-Repair-Parts/Sidekick-LCD-Screens
Jun 08, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Panasonic TX-32PL10 32" TV Logo
14 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
