Question about ATI Computers & Internet
Properties color management - ATI Computers & Internet
I have a hp 2575 printer, i need to know how to print with out color cartridge. I keep getting error code to remove color cartridge
that's not the right way too remove color. in your printing. put back all the colored cartridge you remove. go to printer properties. > settings > color management or details > then find the button that indicates that will like to print in a black and white scale. do not remove the colored cartridge.
Jul 13, 2011 | HP OfficeJet 6210 All-In-One InkJet...
I have an HP officejet 4215 printer. I cannot get the cartridge (color) 57 to print color! It has been working fine with the smaller cartridge but due to high level of printing, I was told to get 57. I...
If all the the computers connected to this printer via network:
  • Shut them all down except for one.
  • Go to that computer and go to your printer and fax settings
  • Identify the Hp OfficeJet 4515 and right click on the icon and select properties
  • On the General Tab, click on the button that says, "Printing Preferences"
  • Select the "Features" tab and go down to Color Options and check to see that the radial button is green for Print in Color option
  • Underneath that, there is another setting thatsays, "Color Management".
  • Check to see that it is already selected with, "ColorSmart/sRGB or Adobe/rgb
  • Click Ok and return to the Properties
  • Go to Color Management Tab and check to see that it is set to Automatic.
  • Underneath that, you'll see "Color Profiles currently associated with this printer.
  • Look to see that the field is populated, if not click on ADD, and select each color profile that is available
  • Click apply, then OK
  • Shutdown Computer
Turn the printer off, unplug the power from it, wait a couple of minutes, then plug power back to printer, then power it up.
  • Restart the computer you were working with
  • Go to printers and fax options window
  • Select the HP OfficeJet 4515
  • Right click, select properties
  • On General tab, click on, Print Test Page
  • Go to printer to see if printing test page
  • Check to if the Microsoft Windows logo was printed in color
If it is in color, then print the color document you were previously attempting in color.
If it does not print in color, you will have to check your settings on the program that is being used for the document.
Jun 02, 2011 | HP Officejet 4215 All-in-One Color Photo...
I have no wireless lan in my asus
HI bernardo_tam
Turn on your wireless button (enable)
if it is to do so but still no wireless icon appears.
Check your device manager.
- right-click the My Computer icon-properties
- system properties box will appear
- click on hardware tab then click device manager
see your network adapter, if there are colored yellow question mark means youhave to to install the driver software for your wireless adapter ,if not I suggest you to check whether your operating system is fully operational .
regards
Jan 11, 2011 | ASUS Eee PC 701 Notebook
Hp printer 7450 won't print colored text from a word document. test page shows colors on the windows logo flag. changed the ink cartridge....color one that is....no help i will try to print something else...
It may be set for grayscale (black and white) in the print properties. Go into the print properties in Word and look for a color or black and white setting, either under Color Management or Advanced. Set it for color, and then print your color document.
Jun 19, 2010 | HP Photosmart 7450 InkJet Printer
Color doesn't print in true color.
It may be the printer color settings in your printer properties. May be set to draft. Change it to best or normal.
Go to Control Panel> Printers and Faxes> right click on your printer's icon, go down to properties. There unerd advance, you can do a head cleaning. Under color management, set it to automatic.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 29, 2008 | HP DeskJet 940c InkJet Printer
My printer does not allow me to print out pages with color.
go to start>printers and faxes> look for your printer and right click on it.. go to properties.. and look for the advance tab.. there.. click on printing defaults... what you see next dependes on your printer properties and features.. look for a setting that says something like "print color images in black and white" and uncheck the box.... look in to the quality or color management section... refer also to your printer documentation.
Sep 21, 2008 | Computers & Internet
Printer
Go to control panel. Click on the printer icon.Open the printer file. Go to properties then color management.
Dec 10, 2007 | Office Equipment & Supplies
COLOR QUALITY
Goto control panel, look in printer"properties" select "color managment" set color profiles to automatic, if this doesn't work run nozzle cleaning in printer maintenence.
Dec 07, 2007 | Lexmark X4270 All-In-One InkJet Printer
Computers & Internet Logo
Top ATI Computers & Internet Experts
David
David
Computer Links
Tony
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
