Question about Razor E100 Electric Scooter
Chain keeps poppin off
Do not know how to tighten and keep chain on
  • 23 Answers
If you have adjusted the chain correctly and it still keeps coming off then your chain is worn. You should replace the chain and sprockets as a set.
Posted on Nov 02, 2014
    Sergeant:
  • 236 Answers
These are the instructions for adjusting the chain. They are taken directly from the manual available at http://ep.yimg.com/ty/cdn/razorama/e100e200e300manual.pdf
To adjust the chain:
1. Loosen the axle
2. Loosen the brake anchor (this is attached with the small bolt in the long slot on the left side of the rear fork)
3. Tighten the tension adjusters on the axle 1/8 to 1/4 turn to tension the chain. Tighten both adjusters the exact same amount to maintain the wheel alignment.
Note: this system of adjusters is common to motorcycles and BMX
bicycles so I your are not familiar with it, if you know anyone who is,
they would not have a problem adjusting it for you.
Chain tension: The chain should be "just not-quite snug" in other
words, not taut or sloppy loose. BE CAREFUL NOT TO ADJUST TOO TIGHT. The tensioning system can easily impart too much tension and snap the chain or bend the motor output shaft. Turn the adjusters 1/8 to 1/4 turn at a time and recheck the tension each time.
4. Once the tension is good, tighten the axle and brake anchor bolt. Test run the scooter. Readjust as needed.
Posted on Jan 02, 2014
My stihl ms-180-c chain saw will not keep chain tight. you tighten chain rev. engine chain will just about come okk -tighten chain rev. engine same thing.
you have to use the tension screw to move the cutter bar to tighten the chain then you do up the bar mounting nut to keep it tight
May 12, 2017 | Stihl Garden
Why does the chain keeps tightening
Has it ever come off while using it? If so, there may be burrs on the drive teeth making the chain wider than the bar opening, also if there is no oil getting to chain while operating chain could bind from heat, check sprocket on the bar tip for blockage and inspect the clutch bearing.
Sep 07, 2014 | Husqvarna 340 345 346 350 351 353 445 455...
How do i fix the rear sprocket on my huffy rock it bicycle
on all single speed bikes, it has been my experience, that chain tension is the reason for the chain to come off, try tightening it again, since this seems to keep happening the chain may be stretched out now and replacing the chain and getting it tight should solve the issue.
Apr 30, 2014 | Huffy BMX 20" Boy's Rock It Bike
Chain keeps going tight on my johnson red saw why
I think you should make sure that when you tighten the 2 nuts that hold the bar, that you raise up on the bar while you tighten nuts. That way the bar cant move up and tighten the chain.
Jan 26, 2012 | Televison & Video
I have a McCulloch chainsaw. The chain has jumped off the tract and I can't get it back on. Can you help me? Thanks.
You will need to loosen the blade locking mechanism and then push the bar back in a little bit and put the chain on then pull it back out and adjust to tighten like you would tighten the chain. Did you know that you have to keep adjusting a chain, especially the new ones because they stretch with use, and a lot when new. To keep them running properly and safely the operator must always be cognizant of the slack in the chain. If you are not familiar with the proper tension on the chain, then when it is all tightened down the bottom section of the chain should not be up tight against the bar. That is too tight. You may want to get someone knowledgable in setting the chain to show you or maybe watch a youtube video. It gets very wordy to describe all the factors for setting the chain and it only takes a minute to actually set one.
Sep 16, 2011 | Garden
My chain keeps falling of, when i put it back on and tightened the chain tension it brakes the chain. What do i need to do?
The chain shouldn't break from tightening the tensioner. Is this a bad chain? Tension should be tight enough that the chain has about 1/2 inch of back and forth movement in the middle of the longest run.
Let me know if this helps or if you need more information.
Gary
Dec 13, 2010 | Garden
Chain brake keeps tightening against bodywork
you can remove the chain brake , i have on all my saws. just be carefull if you do
Apr 28, 2009 | Garden
Chian keeps comming off. Need to know how to tighten
Hi..my name is Keith..i dont know what kind of mower you have..but most models that has a drive chain..to tighten it up..you unloosen the rear axle bolts and pull the rear axel backwards..and then retighten the bolts..but your model may not do that...i hope this helps
Apr 10, 2009 | Garden
Cannot tighten the chain bar
Make sure the bar is positioned on the bar adjusting pin before you tighten cover. Adjust tension with bar adjusting screw, then tighten bar bolts.
Mar 25, 2009 | Poulan PP4218AV 18" Chain Saw
Razor E100 Electric Scooter Logo
518 people viewed this question
Top Razor Toys Experts
Clif Roberts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
Are you a Razor Toy Expert? Answer questions, earn points and help others
