Question about Fisher and Paykel IWL12 Top Load Washer
Washer dont spin out clothing - Fisher and Paykel IWL12 Top Load Washer
  • Fisher and P... Expert
  • 554 Answers
Is all the water pumped out of bowl.
If all water is pumped out, try blowing air down the clear pressure
tube to dislodge any blockages that would stop the bowl from spinning.
Posted on Jan 02, 2014
Washing spins but dont take all the water out of the clothes
If like you said its spinning just not drying your clothes, then I would check the transmission plate and clutch. When the transmission leaks oil it goes into the transmissions plate wich has this break pad inside which hooks up to the clutch during the spin cycle in order to make the tub spin. If it is worn out or if it has oil it won't spin fast and will not dry your clothes.
Hope this video helps!
http://youtu.be/TB_W6sPdzkM
Oct 11, 2014 | Kenmore 24032\24036 Top Load Washer
Washer spins on delicate only. Won't spin on
Hello, Does it sound like its spinning in regular and just not spinning? If So You may just need to replace the belt. Also this unit the motor pulley would melt and break. Lean the unit back and you can see the belt and pulley. Hope this helps and please dont forget to rate me. Thank You...
Jun 08, 2011 | Maytag Atlantis MAV7551 Top Load Washer
Clothes washer will not finish spin cycle.
maybe something in the drain pump take bottom panel remove pump by turning filter and remove debris dont forget to vacuum out water from drain hose or your gonna get really wet.
Feb 21, 2010 | Washing Machines
Spin cycle problem
hi this is the part you need to replace motor drive coupling located on the motor and the transmission. replace this part $25.oo thanks the appliance doc
Oct 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer won't spin dry clothes
What model is in reference here? Please post back with model number.
Jul 02, 2008 | Whirlpool 3.2 cu. ft. Plus Washer
Help my washer
Dont put loads of clothes in, the zanussi has a sensor which, if the weight in the drum is not dispersed evenly it will not reach the final speed. best to take some clothes out it should work ok then
Apr 16, 2008 | Zanussi ZWF1430W Front Load Washer
Lg wm2785H*M clothes are not spinning dry
check your soap .you NEED to use HE( high efficency ) detergent. dont believe the saleman "just use less of your regular soap speech". immediatly swithc to HE detergent problem solved
Mar 01, 2008 | LG WM2487H Front Load Washer
Washer not spinning
my ge top load washer washes but wont spin at end of cycle to ring the clothes out. if i mess around with the switch or motor wire connections it starts to spin with some help
Jan 05, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer problems
if it wont drain , check your lid switch, check out your motor coupler, if it will not agitate and spin, replace your motor coupler, if it agitates and dont spin, replace your lid switch.
alot of times the washer will drain but we hurriedly cut it off when we hear noise or the water is out but it never spinned and so the clothes are soapy wet...
Nov 12, 2007 | Roper RAX7244KQ Top Load Washer
Fisher and Paykel IWL12 Top Load Washer Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
