Question about Pelikan Pelican 2000 Super Sabrelite Dive Flashlight - Yellow
Connections I am looking for the battery connection to the lamp.
    Sergeant:
  • 236 Answers
The top of the battery nearest the light bulb is the positive connection and is in direct contact with the bulb. The negative connection is a strip of brass that runs along the length of the torch from the bottom (bottom of last battery) to the bulbs side connection.
Posted on Jan 06, 2014
03 cadilliac deville brake lights won't come on
test brake light switch --underdash on bracket attached to brake pedal
Jun 06, 2017 | Cars & Trucks
I have a 2004 suzki xl7 is anti theft is not allowing my car to start. The battery lugs were connected wrong, while jumping another car and now my car won't turn over. How can I fix this?
connecting the main car battery backwards can damage some electronics
got you, no meter.
tow it to a shop, or
1: check all fuses, cab and hood.
2: do the head lights work ( it takes no key to do that) if fails, fix this first (fuses are blown)
or battery is dead or installed backwards.
3: turn the key to on.
do all normal warning lamps go out, after the delay
or are they dead, if dead fuses ARE BLOWN.
4: THE CEL lamp must glow key on or the PCM has no power, (fuses again) "check engine lamp"
5: the Immobilizer lamp must go out, key on, or the IMMO is not happy, it does just as the name says.
IMMO lamp in the cluster, tells you this,fact.
there you go 5 steps
fuses that look bad are in fact bad.
fuses that look ok, need to be tested, due to possible hair line cracks,.
Dec 20, 2016 | 2004 Suzuki XL-7
The right turn signal front is not working, All else works
Replace flasher, replace blown fuses.
remove bulb and put another new one in, test.
remove bulb check socket for corrosion - wipe with dielectric grease if corroded. reinsert bulb test.
very carefully check all wires connected to back of socket -
look for break or splits --R&R.
Check the signal feed wire with a probe from the back of the bulb socket - go back along wire towards signal light relay. R&R
You can find diagram on the web if you need one.
Feb 17, 2015 | 1999 Dodge Ram 2500 4WD
My farmall H will not turn over at all. Battery is good. 6volt. Manual push button start. New starter . Nothing Help please.
Haven't work on one these but following is what I use for finding bad grounds even though I got several meters.
You can rig up test light using some wire and a 6 v lamp bulb. It won't give an exact voltage readings but a brightly lit lamp indicates at the present of the voltage.
For testing for bad grounds use the main battery ground connection and probe the ground connections around the starter while trying to start. The test light will make it safer as you are just looking for a lit lamp will trying to start; just place the lamp where you can see it from the starting position. The test light will light if there is a bad connection between the starter's ground and the battery ground.
The same setup can be uses to probe to see if voltage is even reaching the starter through the switch and solenoid connections. If the starter solenoid is separate from the starter it can have a bad ground too and will not operate.
Nov 30, 2014 | Cars & Trucks
Got battery drain problem
First you need a 12v lamp in a holder or get someone to solder two wires to one, next disconnect the earth lead of the battery and connect the lamp between the battery and earth if you have battery drain the lamp will glow brit the less drain the less the lamp will glow, remember you will always have a bit of drain, now you can remove a fuse at a time and look at the lamp if it glows less this could be the circuit that's at fault. Good luck.
Aug 24, 2014 | 2010 Jaguar XF
The battery of my 2009 Ajs JSM 125 is not charging, how do I check the rectifier?
Find the rectifier. Use a paper clip (you will need two paper clips), a D battery and a single flash light lamp. Test that the lamp will light using your battery and the paper clip. Straighten/bend the clip in a manner that will allow the bottom of the battery to be connected to the side of the lamp. The solder joint on the bottom of the lamp touching the bump on the top of the battery. Disconnect the rectifier from the circuit. Put the light in each position of the four contacts using the paper clips, battery and lamp. The lamp SHOULD light in one half of the connections and should NOT light in the reverse positions. Your Bridge Rectifier is built using diodes. These diodes pass electricity one direction but not the other. Your D battery represents the electricity - the light tells if the power is passing or not. A rectifier is necessary because the Alternator on your motorcycle produces AC current. Your Battery needs DC current to charge. The diode more correctly assists in the 'creation' of rectified AC that looks and acts like DC the battery can use.
I hope this helps you.
Aug 23, 2013 | 2010 AJS JSM Trail 125
I need to replace the driver's side brake light.
Rear Combination Light- 2007 might vary from these diagrams:
Removal & Installation 2004 (Early Production) 4 Door To Remove:
  1. Disconnect battery negative cable.
  2. Disconnect electrical connector. Rear Combination Light kia-06-18-7495.gif
  3. Remove 2 screws and 2 nuts and remove light assembly.
To Install:
  1. Install light assembly and 2 screws and 2 nuts.
  2. Connect electrical connector.
  3. Connect battery negative cable.
5 Door To Remove:
  2. Disconnect electrical connector. Rear combination light kia-06-18-7496.gif
  3. Remove 2 screws and push light assembly toward outside of vehicle. CAUTION
    Use care to not damage gasket.
  4. Pull rear combination light from vehicle.
To Install:
  1. Install rear combination light and 2 screws.
  2. Install 2 screws.
  3. Connect electrical connector.
  4. Connect battery negative cable.
2004 (Late Production), 2005-2009 To Remove:
  2. Remove 2 screws and cover inside trunk.
  3. Remove 4 nuts and disconnect electrical connector (A).
  4. Remove rear combination lamp.
To Install:
  1. Install rear combination lamp.
  2. Install 4 nuts and connect electrical connector (A).
  3. Install cover inside trunk and install 2 screws.
Oct 28, 2010 | 2007 Kia Spectra5
I need a detailed instructions on how to connect a toogle switch to a fuceable link to a battery and to a halogin headlight bulb?
Ok there are 2 ways todo this ,, the first is the easiest but not the cleanest..
First ..
1.) connect 8 guage wire from postive battery terminal to (2 port fuse holder)..
2.) from each of the fuse in the holder connect to the positive lead of each bulb (which should be in the bulb holder and in the headlamps or fogs or whatever).
3.) connect negative to a bolt on cars body.. Lamps will come on..
4.) remove positive from battery terminal..
5.) connect to your spst switch (what ever kind of switch u are using.)
6.) mount switch inside car,
7.) connect wire from other lead of switch to battery terminal..(pos)
Switch the lamps on and off using the switch..
Second method..
you will need
2 4-pin relays
8 guage wire
tester
1.) remove connectors from both head lamps
2.) turn on head lamps and test to see which is positive on each
3.) bridge this wire to the Com on the relay .. (1 head lamp to 1 relay)
connect positve wire from battery termial to relay (each relay seperate wire)
connect negative wire from cars body to relay (each relay seperate wire)
4.) connect Out from relay to Positive on Halogen bulb
6.) connect negative from bulb to cars body
now the lamps will come on and off with the head lamp switch..
Alternatively you can connect the fuse holder to the battery, and connect a switch to that and then that to the positive in on the relay..
Sorry I dont have any diagrams didnt have the time to draw one,, answered this quickly this morning before work..
Sep 08, 2010 | Lincoln Mark VIII Cars & Trucks
Battery keeps dying, it's alternator was replaced in August and a new battery, so why is there a problem now ?
You may have another Alternator issue so get the charge rate checked. Then, look for a leakage issue like the glove box lamp staying on, or the lamp in the trunk or boot staying on. I have even seen the lamps in the footwells stay on and drain a battery overnight.
An easy test is to use a test lamp. Make sure all the doors are closed and everything is turned off (tail lamps etc). Disconnect the battery negative and connect the test lamp between the battery post and the cable clamp. If the lamp lights and stays lit, you have a leakage. Begin by disconnecting the courtesy lamps or removing the bulbs. When the test lamp goes out, theres ya leakage. If you have a charging system connected to the vehicle which charges a second battery, like one in a caravan, check those circuits too.. And even though the Alternator is new, it may still be the cause of the problem.. So check it out as well..
Dec 12, 2009 | 1997 Volvo 960
Ups is not glow any indication, just give buzzer sound , APC make 2000va RS model kindly tell me what i can do to repair it.
It look like dead battery. Try to connect carefully new (or allmost new) battery with 24v lamp in (+) wire. If UPS alive - you'll see only small momentary sparcle. After this - connect battery as usual and try to turn system on. Be carefull! If lamp lit in full power - it means a serious internal problem. Best solution - look for qualified serviceman. (maybe yoir system needs reprpogramming).
Apr 13, 2009 | APC Back-UPS® CS 500 UPS System
Pelikan Pelican 2000 Super Sabrelite Dive Flashlight - Yellow Logo
101 people viewed this question
Top Pelikan Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Pelikan Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
