Question about Kodak EasyShare C533 Digital Camera
Usb cable not recognized - Kodak EasyShare C533 Digital Camera
Set-up won't recognize that the USB cable is connected to both printer and computer and therefore printer won't work. What's up with that??
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
Aug 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
When I Connect My Aiptek 8100 camera to the PC, they show a message "USB device not recognized." Is this because I did not install it's driver? If so please tell me where I can find the driver?
Usually usb device not recognized is due to damaged usb cable or usb port..use a different usb cable and connect it to your pc, if your usb cable is ok then connect it to a different usb port. if the problem in not with the usb cable or port install driver from the cd you got with camera. if you dont have that cd download driver from the device manufacturer site.
Oct 03, 2012 | PC Mall 8100 (MODEL 8100) PC Notebook
USB Port Not Recognized
Here Two Reason for USB Port Not Recognized:
1. Check you USB cable properly connected to the you computer, If cable break or not connected properly, It will show your cable not recognized.
2. If again these problem shows. go to,
My Computer - right click - Properties - Hardware - Device Manager - and Unistall you USB drivers - then again scan new hardware.
Jan 29, 2010 | Emerson BAR900 MP3 Player
Usb not recognized? in my pc
Hi..
If your USB will not recognized try to check if the USB is correctly plug in, try also the another USB port of your motherboard, If it is a USB cable Try to replace the USB cable.
Regards
PCmania
Jul 10, 2009 | Computers & Internet
Canon MP240
Have a look at this link
http://windowsfixup.com/2009/03/usb-device-not-recognized-fixes/
"Delete the INFCACHE" has worked for me in the past.
Also I found that I was using a non USB 2.0 cable which caused the "unrecognized USB" problem. Once I used a proper USB 2.0 cable it was fine.
Hope that helps.
May 11, 2009 | Office Equipment & Supplies
I have a macbook and i connect the usb cable to upload my photos, but the usb is not recognized do i need to download any software. Its says that mac autmatically recognized the camara
the Mac normally recognizes the camera and launches iPhoto.
Try launching iPhoto, then plug in the usb cable. Make sure the connections are tight on the camera end of the cable.
Apr 22, 2009 | Fuji Finepix Z20fd Digital Camera
USB drive not recognized
I had this problem. The T.sonic supplied USB cable was faulty and when I used a quality cable the problem was resolved. If you have a USB cable that came with a digital camera it will do the job as well.
Nov 19, 2008 | Transcend T-Sonic 840 MP3 Player
Pleomax 6gb USB Drive No Longer Recognized by My Computers
It's either the USB port, the drive electronics itself, or the USB cable.
First I'd try a different USB cable.
Apr 06, 2008 | Computers & Internet
Kodak EasyShare C533 Digital Camera Logo
14 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
