Question about Sony 40 in. LCD HDTV
TV won't turn on
TV is plugged in but won't turn on. The Lamp light on the front of the TV flashes Red. Tried unplugging, waiting, then plug in. The Lamp light flashes green for a bit then turns red.
  • 111 Answers
Count the flashes. Then we can help.
Posted on May 21, 2009
Tv will not power up
Press the TV button or ON/OFF button while remote is in TV mode and there's a source of power to the outlet or outlet strip.
Make sure the TV is plugged in.
You might have tried to turn on the TV during the lamp cool-down. Wait a few moments and the picture will appear.
Has the power light on the front of the TV been blinking for one minute? If so, the lamp may be dead. Refer to the Power indicator
is blinking or flashing section below for more information.
When you first plug your TV into an outlet, the Power indicator on the front panel will light and blink for approximately 30 seconds
and then go off during the initialization of the TV. This happens only when the TV is unplugged and plugged back in. The TV can
only be turned on after the Power indicator goes off.
Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else, such as a lamp.
Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the
remote control solutions on page 53.
Multiple TV Setup might be set to the wrong option. Press MENU/OK on the front panel. Select Setup Options, then Advanced
Options, then Multiple TV Setup. Choose TV (default).
Sep 26, 2013 | RCA Scenium M50WH187 50" HDTV
Unplugged tv for storm, plugged it back in now it trys to turn on but won't
plug in a bed side light and see is it working and if it is not then the storm has damaged the tramsformer supplying your house
Aug 08, 2012 | Samsung Hlr5667w 56-inch Dlp Hd Tv
REPLACED THE LAMP ..... A RED LIGHT ON THE FRONT PANEL TO THE LEFT OF THE GREEN ON LIGHT APPEARS. THE TV DOES NOT COME ON. ANY SOLUTIONS?
make sure u put the door back for the lamp also unplug the tv fron the outlet wait 2 minutes plug back , sometimes when the lamp is replace when tv still plug needs to be reset
Jan 03, 2011 | LG RU-44SZ61 44" Rear Projection...
Well my mom was watching tv and it just shut off so then my mom turned it back on thinking she might have hit the power button accidentally. But when she turns it on it started blinking the green light for...
The flashing light red power light should only stay while the fan cool down for about 1 minute after a power off (remember to always wait before unplugging the TV so the lamp can cool down with the fan). Does that flashing start right away after plugging back the TV after an hour of letting it without AC power.
The red light should flash no longer than 10 sec. This prepare the light to be turned on. If all is OK the green should stay (no longer flashing) and the sound and picture come on.
As for the lamp flashing, i bet it's only 1 time each 5 sec? Or do it group many rapid flash each 5 sec?
Things that can be wrong:
-the fan lamp
-the lamp is not proprely inserted (wait an hour before manipulating it to be sure it cooled down, and use glove to not put body oil on it).
-Lamps is defective and is not operating properly so you can't get to the usual on screen message that recommend to change the lamp.
Sep 02, 2010 | Panasonic PT-60LCX64 Television
WILL NOT TURN ON. GREEN LIGHT; TWO RED LIGHTS
check the projectors lamp.look like to need replace
May 05, 2010 | Hitachi 60V500 60" Rear Projection...
The standby/timer is flashing 6 times on my Sony KP-53HS30 TV
no the 6 blinks indicates a missing voltage. If your talking about a sony lcd KD or KE model you probably have a bad thermal fuse. You must also clean or change the Lamp fan so it won't blow again.
Apr 16, 2009 | Sony KP-53HS30 53" Rear Projection...
Tv won't turn on, keeps flashing red, will not turn a solid color
Sounds like the lamp needs to be replaced.
Before any repair or replacement, unplug the tv from the electricity for an hour, plug it in. This forces a system reset on the tv and may solve the problem. More likely you need a new lamp.
Aug 17, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Sony 40 in. LCD HDTV Logo
187 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
