Question about Tefal T-FAL FZ700251 Actifry Low-Fat Multi-Cooker, Black Best Deal $185.20
Lid not sealing around edges properly
Lid not closing properly and steam escaping from sides taking 50 minutes to do chips
2 Suggested Answers
SOURCE: Steam is escaping from the sealed tank. Pro expess
I haven't solved the problem yet. I didn't realise, to begin with, that I was on a USA website. I am in Uk and felt this would be too problematic with charges etc.
Thanks for getting in touch I'll get back if I need to.
Posted on Feb 17, 2010
Oval lid, what is the correct fit, should it be a tight fit, or my just sits on top, there is a small space around.
You should have a fit that has a little wiggle room, including a little space around the edge of the lid. When you cook in a slow cooker, you'll make a bit of steam, and it needs room to escape. A super tight lid would likely end up 'burping', and possibly spraying spurts of whatever your sauce is, across your kitchen. Having that small groove there also leaves you a space where a bit of steam can condense and either trickle back into the pot to keep things moist, or just sit there in the gap and not drip all over your counter. Having a little bit of give also means that if you cook and let things cool, the condensing steam won't create a partial vacuum and leave you having to plant a foot on the side of the crock pot to pull the lid off (likely with more spectacular spew-age ready for viral videos).
Cheers!
Nov 06, 2015 | Crock Pots & Slow Cookers
How do i keep water out of my trunk
New trunk seal , that rubber thing around the edge of the opening !
Nov 01, 2015 | 1998 Buick Regal
Manual for Mirro pressure cooker Model M- 0536-1
go google and type in -- user manual for mirro pressure cooker model m-0536-1-- and if there is one it will be a pdf version down load
make sure that the lid seal went in without any twists
put something under the seal and go around the lid several time to allow the seal to untwist
Oct 26, 2015 | Crock Pots & Slow Cookers
Shark steam cleaner sc 505
you need a new seal to put on the lid
Mar 17, 2014 | Vacuums
My pressure cooker always makes a hissing sound. Is that close properly?
As long as the lid is properly locked into position it should be closed properly. A certain amount of air and steam will escape from the valve on the lid and will male a hissing sound but this is perfectly normal.
Jan 17, 2011 | Manttra 38131 8qts Stainless Steel
My hoover steam vac
OKay! I've figured it out! After making sure I had the cleaning solution container connected properly, the "lint filter" thingy clear, the attachment plug thingy unplugged, the filter in it's proper position, (about a cm down from the seal), and the seal on the filter was all good, etc etc etc, the brushes in properly...I was about to drive over this steam cleaner with my car!
After taking a break and going back to it, I discovered that I didn't have the lid to my dirty water tank (or air tank, as I was starting to call it) properly closed. There are two lips that you have to make sure the lid "hinges" from, and THEN snap the lid shut. This made a seal that allowed this steam cleaner to **** up all kinds of gooey gunk from my carpets! The brushes work, the suction works, it's a FABULOUS machine! It doesn't get any louder when it's sucking up water, either.
All this AND I had the instructions! Go figure!
Jul 12, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Kenmore Elite coffeemaker - excess steam
Fold a large piece of foil into quarters. Place foil over reservoir and firmly close lid. Open lid and massage edge of foil inside and out with finger to get a kind of cap. Remove foil and trim neatly around outer edge of lip. Fill reservoir with water, place cap on top and close lid. Make coffee.
Mar 02, 2008 | Coffee Makers & Espresso Machines
Crock pot use
You should keep the lid on as much as possible. You are correct; once you open the lid, the liquid inside can quickly lose temperature at a rate of 10-15 degrees per minute.
Additionally, taking the top off allows steam to escape, which reduces the point of cooking in a slow cooker (cooking in a relatively closed system, with the steam condensing back to water and flowing back into the broth).
It's not doing a whole lot to the flavor (aside from causing the stew to thicken with the loss of water), but it is definitely causing the cooking to take longer than it should.
Nov 02, 2007 | Rival 38601 Smart Pot 6-Quart
Frost buildup on ice/water dispenser
Is the trap door flap closing properly where the ice comes through the door? If open, warm air would be coming in frosting and maybe iceing things up
Aug 27, 2007 | GE GSS25QGPBB / GSS25QGPCC / GSS25QGPWW...
Tefal T-FAL FZ700251 Actifry Low-Fat Multi-Cooker, Black Best Deal $185.20 Logo
85 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Oscar Netto
Oscar Netto
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
