Question about Russell Hobbs 15081 Steamglide Iron In White And Blue, 2400 W
Changing the flex cable - Russell Hobbs 15081 Steamglide Iron In White And Blue, 2400 W
My tefal steam generaitor no longer works as a big flash came out of flex at top of the iron on flex
BIG FLASH meaning what exactly . short in power cord . might be time to BIN it and replace
May 15, 2016 | Tefal Irons
Replace flex on iron model 19840
Stop using immediately! This model is faulty! Check with customer service as how to return for a refund!
Oct 16, 2014 | Russell Hobbs Irons
Russell hobbs repair
You get the flex unscrew the iron off you go.
Aug 29, 2014 | Irons
How to replace flex on 18651 steamglide iron
Stop using immediately! This model is faulty! Contact customer service for more advice on how to return!
Aug 18, 2014 | Russell Hobbs Irons
18651 Russell Hobbs change flex
Stop using straight away! This model is faulty! Call customer service for mor information!
Apr 06, 2014 | Russell Hobbs Irons
I need manuel.
i want to change the flex with a more suitable cable/plastic, but i have difficultty inlocating the bottom fixtures on the back plate of the iron, its just to good of an iron to discard.
Jan 08, 2011 | Russell Hobbs 14084 Iron
Wont heat up light will go on when i wiggle cord
Sounds like your flex is damaged. You need to get it professionally changed.
Nov 02, 2010 | Rowenta Powerglide DE011 Iron with Auto...
Tefal pro express turbo water flowing out of iron and soaking the clothes
i have a tefal pro express gv8110 iron and it keeps leaking out water onto the clothes and doesnt seem to heat up. i have only had it for 22 months so im not sure why it has been doing this. it also doesnt seem to let the steam out like it used too. please could u help me
Sep 08, 2009 | Tefal Irons
Turns on, flashes yellow but never heats up
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Jan 12, 2009 | Rowenta Effective DX1900 Iron with Auto...
When i am ironing all the power in the house goes off and it is a brand new iron
Patrick,
The iron may actually be ok. If not, remember that because it's new it will come with a guarantee.
Did you put the plug onto the iron yourself? Check inside the plug to make sure that there's no bare wires that can touch as the cord flexes as you iron. This would cause it to short and throw the power in the house.
Try using the iron in a different room. If you get the same problem then there's possibly a wiring fault (maybe a broken/worn insulation on the wires of the iron cord ... though as it's new, I would doubt this).
Are you using an electrical extension lead to plug the iron into? If you haven't overloaded the socket with other electrical appliances it may be that the extension cable has a broken/faulty/loose wire inside that when they touch, causes the power to go off. A few years ago the power in my house used to go off on occasions whenever someone went to the fridge. The fault was traced to split insulation on one of the wires in the extension cable I was using. Whenever somebody stood on the cable it shorted out and cut the power.
To be really sure - go into a neighbours and use the iron! If the power goes off - it's the iron at fault. If not, it's probably just a small problem like worn insulation/loose/broken wire in an extension lead in your own house.
Sep 19, 2008 | Conair Compact Garment Steamer Iron
Russell Hobbs 15081 Steamglide Iron In White And Blue, 2400 W Logo
22 people viewed this question
Top Russell Hobbs Irons Experts
Jim London
Jim London
AZBen
AZBen
richie46
Are you a Russell Hobbs Iron Expert? Answer questions, earn points and help others
