Question about Amaco Excel Kiln with Select Fire
Why amaco excel select fire kiln is beeping
My kiln is beeping when I fire it can you tell me why
I need an owners manual for modet lt-3k kiln
Do you mean the Dawson LT-3K kiln sitter, a control and monitor for the ceramic kiln? The manual for this is on the product page: http://www.paragonweb.com/ManualInfo.cfm?CID=42 . The direct link to the manual is http://www.paragonweb.com/files/manuals/ACF1B.pdf .
If you need information about the kiln, then please check that model number and add a comment with that information. If your kiln is from Paragon, then try http://www.paragonweb.com/Instruction_Manuals.cfm for a manual. Paragon makes the Dawson LT-3K.
I hope this helps.
Mar 26, 2017 | Cars & Trucks
What is ceramic fiber and how does it functions?
Ceramic fiber board was made by desiccation, machining and refined through vacuum forming or dry process. It's an ideal energy saving material for kiln, pipe and other insulation equipment.
The advantages of ceramic fiber board:
1. High compressive strength and long service life.
2. Low heat capacity and conductivity.
3. Non-brittle materials, good tenacity.
4. Precise size, good flatness.
5. Easy to cut and mount, convenient construction.
6. Good performance at anti erosion.
7. Continuous production, uniform fiber distribution and stable performance
Characteristic of ceramic fiber:
Beside the fine properties of bulk ceramic fiber cotton, ceramic fiber board has hard texture, excellent toughness and strength and good performance at weather-proof. It won't expand when heated. Besides, it has light weight so that it can be constructed convenient and arbitrary shear bending.
The application of ceramic fiber board:
1. The backing insulation for kiln of cement and other building materials.
2. The backing insulation for kiln of petrochemical, metallurgy, ceramics, glass industry.
3. The backing insulation for kiln of heat treatment.
4. The backing insulation for non-ferrous metals industries.
5. The backing insulation for high-temperature reaction and heating equipment. http://www.ceramicfibermanufacturer.com/
Mar 07, 2017 | Computers & Internet
Why does internal fuse on stafford 501 controller keep blowing
http://www.staffordinstruments.co.uk/files/install501.pdf
From the manual
This indicates an electrical fault in the control
circuit. The kiln has been on zero power for 15
minutes but the temperature has not fallen by at
least 1°C. Control contacts may have failed closed (e.g. welded). TURN OFF THE KILN [Error 4 should be present]
Nov 10, 2014 | Baby Gear
The cone set button on my Cress E27 kiln quit working, so I need a wiring diagram so I can determine if it is a loose or corroded wire.
Ceramic Glass Kilns Industrial Furnaces Kiln Furniture and Pyrometers... Scroll all the way to the bottom. Left side should be the proper pdfs. Instead of attaching the pdfs I included the link because you may find other helpful information for your kiln, just in case.
Mar 09, 2014 | Dirt Devil Vacuum. Jaguar Pet Bagless...
The set Code button on my Cress E27 kiln quit working, so I need a wiring diagram to determine if q wire is disconnected or corroded
Could you let me know if its the stock Cress controller or other controller. I have the schematics to a Skutt controller. They operate some what the same. Knowing the voltage and phase of your electrical supply connection would tell me what to send you.
Stevan
spiescic@cogeco.ca
Mar 09, 2014 | Cars & Trucks
I need an owners manual for a Knight Kiln Model103
did you find a Knight Kiln 103 owners manual?
Dec 17, 2011 | Dryers
I bought a brand new AIM electric kiln last fall. I did the initial burning off but have never fired with it yet. I am afraid to and even though it's band new, had never gotten a manual with it. In...
Why don't you try a simple test glazing or pot firing, something you don't care if you lose and see how it goes?
I assume it has a place to set the temperature? If so what is the problem? Just make sure the kiln is away from any flammable objects and watch the kiln while it is running (don't leave it unattended).
You should probably never run it unattended.
Hope this helps.
Jul 23, 2011 | AOL Instant Messenger
Amaco Excel Kiln with Select Fire Logo
733 people viewed this question
Top Amaco Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Amaco Craft and Hobby Expert? Answer questions, earn points and help others
