Question about Polaroid Televison & Video
Polaroid portable dvd player just says loading won't play movie
SOURCE: portable dvd doesnt play movies
Try cleaning the lasers lens with an anti static cleaning wipe. I used " nice'n clean" that I had purchased from Walmart to clean my laptop screen. My dvd player started back playing after gently wiping the laser lens.
Posted on Apr 21, 2007
SOURCE: DVD player reloads after 5 minutes into the movie
I have a K715 that was having the same problem. The "line select" had been switched from "in" instead of "out". Once I switched it back to "out", the player worked normal.
Posted on May 12, 2008
  • 103 Answers
SOURCE: apex AD-1100W dvd/cd/mp3 player quit playing movies
hi,
Does it happen for all dvd disc or some particular dvd disc. If it is with some particular disc then clean the dvd and try them. If the problem exist for all the dvd then try to clean the lens by dvd lens cleaner and try to play. dvd lens cleaner will be available in dvd stores.
Thanks,
Posted on May 23, 2009
  • 814 Answers
SOURCE: DVD player plays 10 minutes and then freezes screen.
You may have a problem with the transport of the dvd laser. Open the compartment that you place the dvd into. You will see the spindle,the laser lens and the transport device that moves it during operation. The transport system operates on system of gears and drive rails. You must check and clean the drive rails and gears. Use a can of compressed air and blow all the dust and debris from the dvd compartment. Then use some cotton swabs with a small amount of isopropyl alcohol on the tips and clean all the rails and gears. Check the transport action by moving the transport to its most outer position and back to its most inner position. The action and travel of the transport on the rails should be smooth and easy. The gears should be clean and move easy also.These parts will require cleaning every month or so . Remember do not touch the laser lens with your hand. You should also check the lens it should look bright and shine. If not try cleaning it with a cotton swab and a small amount of alcohol. Rub the lens gently back and forth unit it is bright and shines.Now you can try playing a dvd and see if the player works properly. If this does not fix you problem. You can reset the dvd player to the factory settings.1.Press the setup button on the remote control.2.Use the left and right arrows to highlight the preferences page.3.Press enter to to enter the preferences sub-menu.4.Use the up and down arrows to find the default function and press enter. You now have reset the dvd player to factory settings Now again play a dvd to see if the player is functioning normally. If not you may have a more serious problem with the drive motor or power supply circuits. you can call Insignia customer service support at this telephone number.1-877-467-4289. Give them the model number of you dvd player and tell them the problem you are having with the loss of operation during the playing of a dvd. They will be able to tell you how to get testing and service for you dvd player. I hope this information helps you with your problem.
Posted on Jun 03, 2009
shameerariff
  • 89 Answers
SOURCE: portable dvd player says loading but wont play
This is because of the problem with the pickup unit.. Your try to clean the lens with the help of the lens cleaner, if the problem still persist then open the panel, clean and apply the white grease on the moving parts of the Disk reader.
Caution always remove the main power before open the panel.
Posted on Jul 28, 2009
Keeps loading then nothing
The DVD doesn't load - it just plays. The player mechanism has failed, a common problem with portable players.
Apr 01, 2014 | Zenith ZPA-314 Portable DVD Player
Polaroid portable dvd player won't recognize disk
You have put a dirty CD in and now the laser lenses is dirty and cant read the finer details of a DVD.It needs a clean.
Dec 06, 2013 | Polaroid Televison & Video
Dvd-l200
It depends how you burn movies (for example). If you burned as data disc, it's probably won't play it. Make sure you burn movies as DVD format.
May 19, 2012 | Samsung portable dvd player DVD-L200 User...
Polaroid portable dvd-my screen says 'this screen is locked'. won't play movie. please help
One of the button of your polaroid dvd player is still in active mode.Try to keeps pressing all the button, so that it will go back to inactive mode.
Jul 23, 2009 | Polaroid PDM-1058 Portable DVD Player
Dvd player movie never loads
The lens on the DVD player might be dirty. Try taking a q-tip and soak it in rubbing alcohol. Next, open the cover and look for the laser lens. This is usually a clear white plastic circle looking piece. Take the q-tip and  clean the top of the laser lens but don't rub to hard. Let it dry for 10 minutes and see if the DVD will play. If not, then your DVD player is broken and needs to be serviced.
May 02, 2009 | Polaroid Portable DVD Player PDM-0822BD
My Polaroid DVD player has been used very little. I charged the battery; put a dvd in and it says "Loading" and never starts playing the movie.
Sounds as if the EYE is dirty. Look closely at the spindle (cd mounts on) and try to locate the glass eye. Swab with alcohol gently, I mean gently.
If still bad, then the eye transport mechanism needs to be replaced. Not hard couple of screws and flex cable, look for part number and then go to matelectronics.com good luck, be safe..
Mar 11, 2009 | Polaroid PDX-0073S Portable DVD Player
Good afternoon! My portable DVD player (PDM-0742) skips when playing a DVD. Any suggestions?
Clean the laser of the DVD player, clean the dvd, dont shake/move the DVD player while watching movie....
Dec 01, 2008 | Polaroid Televison & Video
Polaroid 0722 Player
On most of the set top DVD players you use the monitor button or the remote control menu button to access the mode that flips the display (invert). The mode is for those who mount the units to the ceiling of a vehicle for rear passengers to view. You might have to have a DVD playing at the time or just loaded in the stop mode to access the feature.
Jun 08, 2007 | Polaroid PDV-0700 Portable DVD Player
Player freezes partway through movie
If this happens on all disk and you have cleaned with proper laser disc cleaner there are small caps that are almost naked to the eye that needs changing in power supply
Feb 01, 2007 | Polaroid PDV-0700 Portable DVD Player
Televison & Video Logo
63 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
