Question about Miele CVA4070 Coffee Maker
Miele coffee maker dripping too slowly
Cleaned, descaled, rinsed brew unit, but coffee is dispensed too slowly...down to a slow drip.
3 Suggested Answers
  • 128 Answers
SOURCE: I have a three month old Miele CVA 4066. I have
your brew unit is clogged. It will need to be removed and cleaned every 24 hours as per the owners manual. There is a yellow laminated card in the box with the accessories that shows step by step how to perform the 24 hour maintenance. To prolong the life of the brew unit, make sure the coffee grind size lever is in the middle or to the right of center, rather than the left (fine) side. Also, you only want to use dry beans, preferably espresso beans. Oily beans like french roast will clog that brew unit up very quickly.
Posted on Feb 24, 2011
  • 70 Answers
SOURCE: Miele coffee maker water not coming through to brew unit
try cleaning the nozzles using fine wires or tobacco pipe cleaner kit. it look like you have a blockage on your tubing leading to nozzles.
Posted on Nov 06, 2013
How can I fix a very slow coffee cycle.
Maybe a very obvious question, but did you try descaling it?
Nov 15, 2015 | DeLonghi Prima Donna Avante ESAM6700...
My cva 4066 will not make coffee, I descalled it, that function worked fine,all it does is make the grounds a little wet and the rest of the water goes in the drip tray. Can you help me?
Have you Cleaned the Brew unit? The descale Tablets are to clean and descale the internal plumbing - the cleaning tablets are to remove the oils from the brew unit. If clogged the water will not flow through , instead it will dump into the drip tray.
May 11, 2014 | Miele Coffee Makers & Espresso Machines
Water will not dispense on my Keurig Vue .Brewing process stops after a couple of seconds
It may be time to descale. Most models will give you a message when it's time to have the mineral deposits cleaned.
HERES HOW TO DO THAT...
Empty water resevoir. Disable auto off. Pour approx 48 oz of undiluted white vinegar into resevoir. PLace large mug on drip plate, run brew cycle, dump contents of mug in sink. DO NOT USE A K-CUP.
Repeat this process until the add water light is indicated.
Let brewer stand for at least 4 hours while still on.
Discard any residual vinegar in the resevoir and rinse thorughly.
AFTER approx 4 hours...fill resevoir with water.
RINSE:
PLace a large mug on the drip plate and water brew cycle. Pour the contents of the mug into the sink.
REPEAT this brew process until the add water light is indicated.
YOU MAY NEED TO REPEAT THIS "RINSE" PROCESS if you notice any residual taste
Sep 29, 2013 | Keurig Vue Brewing System
Cant get my keurig b31 mini plus to use water it just sits there
RINSE:
YOU MAY NEED TO REPEAT THIS "RINSE" PROCESS if you notice any residual taste.
Jan 02, 2013 | Keurig Mini B31 Plus Red Coffee Maker
I have a three month old Miele CVA 4066. I have recently cleaned the unit twice (using little tablets in coffee grinder), as well as descled. The coffee, expresso, etc. is barely dripping out of the unit. ...
Feb 10, 2011 | Miele CVA 4066 Stainless Steel
We have a five year old Gaggia Titanium regularly descaled. In recent weeks the flow of coffee has considerably slowed to a drip and we now get a message saying 'Brew Unit Missing'. The machine also now...
Remove the brew unit, find the 2 screws above the top shower the connects the discharge tube to spout. Remove screws and carefully remove spring and ball some have a plastic seat at end of spring. Clean tube make sure there is no coffee grounds blocking tube, reassemble and test.
Aug 23, 2010 | Gaggia Titanium Espresso Machine
Keurig B60 is real slow , displays brewing for 30 sec.
mcdevito75 here, It may need to be cleaned, water used to brew coffee leaves deposits in the brewing holes and must be cleaned every once in a while. Refer to the owners manual on cleaning the coffee maker.
Jun 20, 2010 | Keurig B60 Coffee Maker
I have a new Z5 (less than 300 cups) that began dispensing a slow and reduced volume of coffee and also began leaking approx 3 oz of water into the tray after just 2-3 cups of coffee. I have meticulously...
If the grounds are really wet and not looks like a round firm cake, you need to use coarser grist on the grinder. The water in the drip tray is coming from the brew unit. The o-rings are not holding the pressure inside because the sieve is clogged. It could also be that the o-ring are dirty, then the brew unit needs to be disassembled and cleaned.
A good way to controll if the grist is too fine, is to watch if the coffee is just dripping from the outlet. Then try adjusting the grinder until the coffee flows evenly. You can also hear if the pump works harder during brewing.
Apr 26, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Miele CVA4070 Coffee Maker Logo
97 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
