Question about Whirlpool Washing Machines
Need to calibrate after capacitor replacement cabrio w10280475c
2 Suggested Answers
  • 31 Answers
SOURCE: 1997 Volkswagen Cabrio TP sensor adjustment or calibration
the throttle position sensor has to be adapted/ calibrated with a diagnostic machine through the engine control module
Posted on Aug 22, 2010
Calibrating whirl pool washer after repair
Linda. I know nothing about this washer, but I did get this info from the attached link, you may still have to call a tech.
Put into diagnostics (left, right, right, right, left, right) @ done you see errors, @ spin you run calibration(this will clear codes and reset board). good luck
http://forum.appliancepartspros.com/washer-repair/537059-whirlpool-cabrio-washer-not-completing-spin-cycle.html
Apr 18, 2016 | Whirlpool WTW5700XW 3.6 cu. ft. Cabrio Top...
Calibrating whirpool washer after repair
there is nothing to calibrate
if it has been repaired properly, adjust the water level setting , wash requirement , soak period , deep rinse settings etc as to what you want and switch it on
Apr 18, 2016 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool cabrio washwer wtw5600xw0 washes fine but when it's time to drain ,it drain's some of the water and it stops i had the pump checked and thought it was bad but it was not , i had a local repair...
So when you say it's not pumping all water out, is there still water standing in tub or no water standing and clothes are just sopping wet? Is machine spinning? If not spinning, could be actuator that shifts transmission from agitate to spin.
Aug 24, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
The power comes on, I can select a cycle the sensor comes on but the dryer will not start
It is likely that the motor start capacitor has failed. This is not uncommon. You will need a serviceman if you do not feel able to replace it.
Aug 27, 2013 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool wtw6400sw0 washer-already replaced control module and user interface, still spins unbalanced, can I reset it somehow or calibrate it?
Please see the following Whirlpool installation and maintenance PDF on Cabrio washers. An F1 relates to a "primary control failure".
It also has a very extensive troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
May 04, 2011 | Whirlpool WTW6400SW Cabrio Washer
Jul 09, 2010 | 2000 Volkswagen Cabrio
I replaced the water pump on WTW6400SW2 cabrio washer twice already within the last two years. This unit is only three years old. Do you have a solution to the problem?
What was the reason. Pump Motor electrical coil failure ? or water impeller failed. If motor problem, you have to check the associated small capacitor also.Hope no water finds way to the motor.
Mar 30, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I am having trouble with my Bowflex TC5000. The calibrations is failing. The treads aren't moving but the monitor is trying to calibrate.
The motor must move the drive pulley for calibration to pass. remove rear covers and check drive belt. you should hear the lwr board relay click to engage the motor. if you hear it and the motor does not move and you have checked the belt then you need to test the motor. Typically remove the belt and turn by hand...it should be very smooth and spin freely. If not replace the motor. Direct 9 volts to the motor leads unplugged from the board will tell you if the motor is good. be careful as capacitors are present and risk of shock is always possible. capacitors stay charged for about 10 mins after unit is unplugged
Jul 30, 2009 | Bowflex Treadclimber
Washing Machines Logo
Sal De
Gerry Harvey
Gerry Harvey
