Question about HTC Touch Cellular Phone
Phone doesn't ring, but other sounds fine
My HTC Touch phone stopped ringing. It's set to vibrate and ring, but it only vibrates when there is an incoming call. I've checked the settings and the volume and that is fine. Other sounds, e.g. alarm and music, is also fine. It's just when there's an incoming call that I hear nothing, only the sound of the phone vibrating. I've had the phone for a year and it has never given problems before. I'd very much appreciate any help!
  • 2 more comments
  • marinaretief May 21, 2009
    Yes I did, but no luck.
    I also tried to change it to 'Ring only', instead of 'Ring and Vibrate - but then it also doesn't ring. It only displays the usual pop-up so that you can see there is indeed an incoming call, but there's no sound at all.
    My other applications work fine, so it can't be a hardware or driver problem.
    Doh! >:-( Just found the ringing volume was turned down to minimum - don't know how that happened. I missed it since the 'rest of the phone volume' was turned to max.
    Thanks very much for trying to help erincinci. I'm feeling pretty blonde now! *blush*
    Thank very much. I think I know which application is the guilty one.
    Nice day to you too :-)
  • Erinc INCI
    Erinc INCI May 11, 2010
    Hi. Did you try changing your ring tone to another file? (Using the Start Menu -> Settings -> Sounds & Notifications)
  • 148 Answers
:) Sometimes happens to me also. I faced a similar problem before, I think one of the installed programs on your device does it, I couldn't remember the name of the application now but whenever I launch it, my phone sound goes to minimum, Just to let you know. Have a nice day.
Posted on May 21, 2009
My phone has lost its sound and when someone rings it will only vibrate then when i answer, i can hear them but they cant hear me, I have checked and it is not on silent.
First make sure the phone is not on silent,
Try changing the ringtone, go into phone->options->sounds, make sure type is set to ring, if so select a different ring tone.
May 31, 2011 | HTC Touch P3450 Smartphone
PHONE DOES NOT RING
This might be due to the settings....
Ringer settings
To change the ring type and ring tone
1.
On the Phone screen, tap Menu > Options > Phone tab.
2. In the Ring type list, choose whether to be notified of incoming calls by a ring, a vibration, or a combination of both.
3. In the Ring tone list, tap the sound you want to use
You can find more information at the manual located at the below location.
http://www.htc.com/support/pdf/htctouchdual/NIKE_HTC_English_Manual_16-KEY.pdf
Refer the pages 33 & 83
I hope it will resolve your problem...
With Regards,
TPV
Feb 03, 2008 | HTC TYTN GSM Phone
How do I turn off the key pad tone on the impression sgh-a877
The Sound Profile only covers call sounds.
Sound Profiles
This menu allows you to specify how you are informed of
incoming calls.
Selecting a Profile
1. Touch ➔ Settings ➔ Sound Profile.
2. Touch the radio button next to the profile name. The
selected profile activates. Choices include:
• Normal
• Silent
• Driving
• Outdoor
Normal Profile
The phone’s profile defaults to Normal. Use the following
procedures to change the profile.
Editing the Normal - Call Profile
1. Touch ➔ Settings ➔ Sound Profile ➔ Normal.
• Touch the name field and not the radio button to the right.
2. Touch drop-down menu (upper-right of the screen) and
select Call.
3. Select the Call Alert Type field and select one of the
following and touch Save:
• Melody: the phone rings using the ring melody selected in the Ring
tone menu.
• Vibration then Melody: the phone vibrates and then starts ringing.
• Vibration & Melody: the phone vibrates and plays a melody
simultaneously.
4. Touch the Voice Call Ringtone field, touch to select a
ringtone and touch Save.
5. Drag the Ringtone Volume slider to the volume level you
desire (range is 1-7).
6. Touch the Vibration Pattern field, then touch to select
Vibration 1 - 5.
7. Touch Save to return to the Sound Profiles menu.
There is no mention of keyboard tones in the user manual.
Mar 19, 2010 | Samsung SGH-A877 Impression Cell Phone
HTC Touch Diamond will vibrate, but won't ring on incoming calls
I just had this problem - and I have been messing with it for an hour.... but I finally fixed it - Try this - touch the speaker symbol on top (The system status window should pop-up) then touch the speaker symbol again (Now you should have two tabs - one for system and one for ring) Touch ring and slide it up. This worked for me.
Aug 02, 2009 | HTC Touch Diamond Smartphone
HTC Touch Pro Won't Vibrate
So you having problem with vibrate capability?
Try this:
1. Make sure your phone not in charging (it won't vibrate for several phone like e.g. NOKIA)
2. Have you dropped it? If yes, immediately contact the customer service.
Hope this will help! PM me if there's any questions =]
Jul 07, 2009 | HTC Touch Pro Smartphone
HTC Touch doesnt ring on incoming call
Hi. First thing, you can check your sound settings, by tapping Star Menu, then Settings, then Sounds & Notifications, and through that page, you can check if your incoming call alert is on (just sound, or vibrate and sound), you can try to change the ringtone to see if your current ringtone is damaged or not. (Since other sounds are alright, there shouldn't be any problem in your hardware or in the sound volume levels) Hope this helps.
Jun 14, 2009 | HTC Touch P3452 Smartphone
HTC Touch HD - Vibrate function
The '********" is a little motor that spins with an offset weight. It sounds like the motor is stuck.
Feb 10, 2009 | HTC Touch Diamond Smartphone
HTC Touch Pro only rings twice before switching to voicemail
I think the issue is a misconception on the operation of the phone. The phone flashes for the first ring, vibrates for the second ring, and then rings for the 3rd and 4th ring before dropping to voicemail. it requires a registry modification as can be found on some forums to make it "ring immediately." If you put the phone on vibrate it will buzz immediately and skip the flashing lights step.
Feb 04, 2009 | HTC Touch Pro Smartphone
HTC Touch Pro T7272 - Sound problem
go to htc.com and download the last rom for touch pro and it will be fine!
NB: I downloaded the arabic rom wich have two features
1- on the first Installingthe rom is english
2- As u can active arabic, you can also disable it if you are foreign users but it will be better to install it without acivating arabic (case 1-)
Link: http://www.htc.com/mea-en/SupportDownload.aspx?p_id=140&cat=2&dl_id=516
Jan 07, 2009 | HTC Touch Pro Smartphone
Outgoing text vibration
Good Day,
Beginning with the start menu, go to settings, then sounds & notifications. From the drop down list, go to outgoing message and click the "play sound" box (to empty). That should stop the ringing and vibration.
Hope this helps
Jan 02, 2009 | Verizon Communications HTC XV6800 Cell...
HTC Touch Cellular Phone Logo
382 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
