Question about Compaq Evo Notebook N150 Notebook
Beeps on start up
Beeps continuosly on memory check and then starts .is it possible to turn off memory check on start up .
  • Compaq Master
  • 4,806 Answers
Hi there.
The continuous beeping means that there is a problem with the memory, take the system memory out and clean the brass contacts, then reseat the memory and try to boot the PC up again.
The memory is located behind a panel underneath the laptop like this >>>>>> beeps on start up - e1bc638.jpeg.
Good luck and thanks for using FixYa!!
Posted on May 21, 2009
My suzuki grand vitara v6 CHECK ENGINE light Blinks continuosly when the switch turned to on position
If a warning light is on, there's a trouble code stored in the computer. There are well over 800-1,000 possible trouble codes in the average late model vehicle, so asking us to guess what's causing your problem without knowing the code is a complete waste of time. Get the code read. Post it here. THEN we can help
Jan 12, 2018 | Suzuki Grand Vitara Cars & Trucks
The PC does not start.Only it beeps and a red light blinks,also fen is not working.
here are some of the basic codes, depending on which BIOS you have...
Also you do not indicate which fan? I would guess you mean the main Power Supply (PS)? In which case it could just be you need to replace the PS.
Here is a link to some other codes as well...
http://www.computerhope.com/beep.htm
AMI BIOS ERROR BEEP CODES
  • 1 Beep - Memory Refresh Failure (check memory)
  • 2 Beeps - Memory Parity Error in first 64KB block (check memory)
  • 3 Beeps - Memory Read/Write Error in first 64KB block (check memory)
  • 4 Beeps - Motherboard timer not functioning (possible motherboard replacement)
  • 5 Beeps - Processor Error (may need replacement Processor)
  • 6 Beeps - Gate A20/keyboard controller failure (possible motherboard replacement)
  • 7 Beeps - Processor Exception Interrupt Error (may need replacement Processor)
  • 8 Beeps - Display Memory Read/Write Failure (reseat or replace video card)
  • 9 Beeps - ROM checksum Error (replace BIOS chip or motherboard)
  • 10 Beeps - CMOS shutdown Read/Write error (possible motherboard replacement)
  • 11 Beeps - Bad Cache Memory - test failed (replace cache memory)
Phoenix BIOS ERROR BEEP CODES
Phoenix BIOS beep codes are a series of beeps separated by a pause, for example:
beep --- beep beep --- beep --- beep beep would be 1-2-1-2
  • 1-1-4-1 - Cache Error (level 2)
  • 1-2-2-3 - BIOS ROM Checksum
  • 1-3-1-1 - DRAM Refresh Test
  • 1-3-1-3 - Keyboard controller test
  • 1-3-4-1 - RAM Failure on address line xxxx (check memory)
  • 1-3-4-3 - RAM Failure on data bits xxxx of low byte of memory bus
  • 1-4-1-1 - RAM Failure on data bits xxxx of high byte of memory bus
  • 2-1-2-3 - ROM copyright notice
  • 2-2-3-1 - Test for unexpected interrupts
I hope this helps.
Mar 29, 2011 | HP Computers & Internet
My computer beeps continuosly when i start it what is the meaning of this?
This might indicate a hardware problem.. We can identify what hardware is failing depending on the BIOS beep code.
here's a link to guide you. click here
Mar 25, 2011 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
I have dh55tc, i7 860, 4gb transcend ram, xfx hd 5770, tagan stonerock -u37 600w psu, Its assembled in March 2010 & ran fine for 5 months. One day while watching movie it suddenly froze, i restarted...
3 beeps means that it's a RAM fault. If your memory worked just fine in another pc then it's the fault of the memory controller of the chipset on the motherboard - either the memory slot is loose (move the stick in the slot and try again) or the chipset itself is failing. That can't be fixed, the mobo is dead, replace it.
Nov 19, 2010 | Intel DH55TC Motherboard
My toshiba satelite laptop beeps continuosly, non-stop
First, check the memory (RAM) of your computer. remove and put it back in. Also checkif therre is only one or two memory sticks in, so you can check on both. It should work fine, and if not, try replacing the memory of your laptop.
May 19, 2010 | Computers & Internet
When i turn the computer on it starts then
SOS beeps are post codes the computer sends to alert you of problems detected during start up.
The beeps can mean anything from over heating to bad memory detected. Find out what your Motherboard bio is and check Here. This has a handy beep code listing for many of the common mother boards.
Hope this helps!
Nov 17, 2009 | E-Machines (BFB0505HA) Cooling Fan, Laptop...
When turned on loud beeping sound black screen
i sounds like a graphics problem but try and re seat the memory 1st. disconnect anything connected to the laptop, unplug it and remove the battery. remove the memory module(s) and re seat them. but the battery back in, plug it in and restart it.
Aug 07, 2009 | Computers & Internet
Fault code f90, door lock light keeps flashing and then the oven beep continuosly.
maximum oven door unlock time exceeded. Check wiring between eoc & door lock micro switch. more likely you need to replace the EOC
May 19, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Compaq Evo Notebook N150 Notebook Logo
120 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
