Question about Electric Eyeware 12v Car Auto 12 Volt Electric Portable Tire Air Pump
Electrical tyre pump - Electric Eyeware 12v Car Auto 12 Volt Electric Portable Tire Air Pump
  • 3,368 Answers
Did you plug it into the car? What is the problem? You need to add more information if you want your question answered.
Posted on Jun 13, 2014
I am trying to replace inner tube for front tyre. i am having difficulty taking tyre off rim. any ideas?
tyres are a pain some times, but they can be a snap if you have a good tool to unhoop it the wheel. the best tool that i have found is a butter knife that has a few wraps of electrical tape (black tape) and take that and place it inbetween the tyre and the rim prying out ward get the tyre to 'jump' the rim and with your thumb keep it off the outer part of the rim. now firmly move the knife tape side in the wheeltug it around the wheel and keep the rubber out of the rim till you get the rubber off the rim. now remove the tube form the inside, and replace the new tube (or patch the old one) back inside the rim. make sure the stem is neatly in the hole and not pressed to one side.
Now with the same motion pry the tyer back onto the rum and using your thumb keep the tyre pressed on to the rum and go all the way around now just pump the tyre back up and you should be good ro go.
Jun 07, 2011 | Mountain Buggy Urban Single Stroller
The tyre keeps going flat. The valve on the inner tube was replaced and the tyre pumped up, but by the time I got the tyre home it had depflated again. There was a worn area on the inner tube and there...
Not a guru on Bertini but most strollers with pneumatic tires use standard tyres and tubes as used on kiddy bikes. I get tyres for Bugaboo's at my local K Mart. The size should be on the side wall of the tyre.
Apr 23, 2011 | Baby Gear
How do you pump up the bugaboo camelon tyres
the old tyres use a small bicyle pump or a foot pump
Nov 30, 2009 | Baby Gear
Flat tyre
If you have the "Mini Mobility System" your car has a tube of tyre sealant and an electric air pump. These are locate in the boot (trunk) under the carpet.
Shake the tube of sealant. Screw the filler hose onto the bottle. Unscrew the dust cap from the tyre valve. Unscrew the valve insert from the tyre valve using the screw device (very important). Push the tube of tube of sealant onto the tyre valve and hold the bottle with the cap pointing downwards. Squeeze the bottle and force the entire contents into the tyre. Replace the tyre valve insert using the screw tool (most important).
Get the electric pump and connect the hose with the pressure guage onto the tyre valve. Connect the pump electric plug into the cigarette socket in the car or power outlet in the boot (ignition key needs to be on position 1). Inflate the tyre to 1.8 - 2.5 bar. Switch the pump off for a moment to check the pressure accurately. Unscrew the compressor, and put everything away in the boot. IMMEDIATELY drive your car for about 10 minutes. This is to distribute the sealant throughout the tyre. Do not exceed 60km/h. After driving for 10 minutes, recheck the tyre pressures using the pump or at a service station. Continue your journey but keep below 80km/h until you have the tyre checked or replaced.
Oct 11, 2009 | 2002 Mini Cooper
How to remove a fuel pump in a 89 mercedes benz 190e 2.6l
Fuel pump is located at the rear next to your right tyre, unscrew the shield from the underneath, u have to lay down under the car, after removing the plastic shield, u will find the fuel filter and fuel pump, unscrew the bolts of filter as well as the pump, disconnect from the tank and electrical connections, remember, u shold put a new fuel filter with a new pump, hope this will solve the problem
Sep 19, 2009 | 1999 Mercedes-Benz E-Class
How do i pump up my tires in a bike
In order to pump up your tyres on a push bike or cycle.
You will neeed 1- A bike pump and valve adaptor
Attach the pump and adaptor to your tyre, and then pump it up?
Jul 01, 2009 | Yamaha RX-V663 Receiver
Flat tyres and no manual - new scooter user
not sure about the handbook.
but the tyres should be around 30psi i use to blow my tyres up with a foot pump but when you have bad legs you have to use your hands and thats no fun so i bought a electric one 5 seconds and done hope this helps.
clive
Mar 30, 2009 | Health & Beauty
Want to fit new inertube and tyre to rear wheel
fitting innertubes and rims wether that be rear or front its easy as long as you have a spanner pump and sum levers to lift the tyre off the rim your fine its all easy
i hope this help and get on your bike lol :) :)
Mar 20, 2009 | Electric Bicycle Motor, Bike,electric...
Tyre pressure sensor
its a renault ,what else do you expect ??renault electrics are a dealewr only job encrypted software
Jan 19, 2009 | 2006 Renault Le Car
2001 corolla fuse problem
inside the cover of the fuse panel there should be a diagram of which fuses control what.
the fuse box is usually on the drivers side by where your feet are.
Dec 30, 2008 | 2003 Toyota Corolla
Electric Eyeware 12v Car Auto 12 Volt Electric Portable Tire Air Pump Logo
32 people viewed this question
Top Electric Eyeware Plumbing Experts
Donni Steen
Tom Chichester
Are you an Electric Eyeware Plumbing Expert? Answer questions, earn points and help others
