Question about Kitchen Ranges
Beko odf21300 built in electric oven
Main oven developed a fault yesterday (midway through cooking New Year's Day dinner). The main oven stopped working and the timer/clock display keeps flashing and bleeping and won't reset. This happened a couple of weeks ago after a power cut but we were able to reset it. This time it won't. Murphy's law that the guarantee ran out at the beginning of December. Any help or info would be appreciated.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
    Problem Solver:
  • 10 Answers
There has been masive probs with this company so id switch it ff and either rtn to the suppler or replace just type beko in any search engine news keep safe
Posted on Jan 02, 2014
  • 1462 Answers
SOURCE: Zannussi Gas cooker
make sure clock is set properly - refer to your instruction book. to test if clock is in fact faulty, access the clock and bypass it by shorting together the two wires to the clock relay
Posted on May 04, 2007
catriver
  • 878 Answers
SOURCE: oven display won't work
rmedrano, Try pressing and holding the stop-time and cancel pads together for 5 seconds, see if it comes back to life. If not, try the cancel and clock keypads together for 3 seconds. First is the control lock-out funtion and the second is the display blank mode. If these fail to work, you are going to have to test for power at the board. The clock (ERC) has a 3 year warranty incase you have to call for service. Catriver.post back.
Posted on Dec 16, 2006
  • 1462 Answers
SOURCE: Problem with main fan oven - electric
there is an overheat stat and this is operating and cutting out the oven. the causes are several but here are the main things to look for: oven stat is faulty causing the oven to overheat. you should check over the range to see if stat is reasonably accurate. overheat stat itself is faulty. there is another stat which turns on the casing fan. (this is the fan which is out of sight - not the fan inside the oven) if this stat is faulty and not turning on the casing fan, then the overheat stat will operate. the casing fan is faulty or jammed. lack of ventilation. see if you can narrow it down a bit and get back to me if you wish
Posted on May 06, 2007
  • 1462 Answers
SOURCE: Display clock failure so no main oven
check you have power to clock and if not, check wiring back to find out why not. to get oven working, you can bypass the clock by joining the two wires to the clock relay. these clocks are remarkably expensive
Posted on May 07, 2007
  • 49 Answers
SOURCE: suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Posted on Feb 19, 2008
What's wrong and how do I fix it?
The circuit breaker outside in the power panel for the stove has a bad breaker. It will be two breakers with their handles joined together by a pin so if one tripe it takes the other so 220 V is no longer present. When one, but not the other trips you only have 110 V. That's why the lights and clock still work but no heating elements.
Nov 16, 2015 | Frigidaire Kitchen Ranges
Smeg oven stopped working
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jan 27, 2012 | Smeg Ovens
When I was cooking dinner and went.. when I was
did the clean lock get pushed to lock it ,let the oven cool down and it well unlock. it should open at about 100 degrees
Jul 21, 2010 | Crosley CE35111AA Electric Kitchen Range
Beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
May 16, 2010 | Ovens
Beko dvc62 main fan oven stopped working, doesn,t get hot but fan still works, it tripped circuit breaker and hasn,t worked since, peter
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Jan 14, 2010 | Ovens
I have a built in electric oven and yesterday the power went out all day and the temperature is in C not F, and the clock will not set
find the main breaker for the oven turn it off for about a minute and then turn it back on ...yep some times you have to reboot even your oven
Good Luck
Oct 10, 2009 | Ovens
F24 Error code and incessant beeping
Being a software developer I guessed that the keyboard (the touch pad) was bad, because in my case one of the keys (the Top Oven OFF key) did not beep or work. So I went on the Thermador website and found the touchpad on the schematic. I ordered one yesterday from a firm called Mar-Cone in St. Louis, and it arrived today. It is a very easy replacement, and takes about 10 minutes. Happily it was a good guess, and it works fine. For the 27" SEC272BS/01 (stainless) the part # is 474083, and cost $189.20. They will express ship for $25.
Phew, we have 20 people coming for dinner on Thursday.
I'll be happy to let anyone know how to change the panel.
Nov 09, 2008 | Thermador SC272T Electric Double Oven
All my burners arnt working! HELP!!!
There is a cooktop PCB (power control board) which is separate from the oven. Perhaps that is the problem. That board is located behind the cooktop control membrane panel.
Oct 24, 2008 | LG LRE30755 Electric Kitchen Range
Tricity bendix fan oven
The element is almost certainly burnt out .A replacement element is fare cheaper than a new cooker and relatively easy to fit
Apr 07, 2008 | Ovens
Kitchen Ranges Logo
170 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
