Question about Kenmore 64802 Top Freezer Refrigerator
Smells like burning plastic
Wiring to start dev is melted and charred
2 Suggested Answers
  • 1937 Answers
SOURCE: My kenmore washing machine mod.# 110.24642300 will
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11024642300/0582/0153200?pathTaken=&prst=0&shdMod=11024642300
and you'll see a list of major sub-components with diagrams and parts.
Two initial possibilities, neither is hard to fix or expensive.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
I'd also check the Motor coupler:
Look in the section for the motor, pump gearcase and you'll see the Motor Coupler.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Posted on Jan 11, 2011
My Frigidaire oven model feb386wech emits a burning plastic smell when heating up and cooking. What's causing this?
After 16 years of service, the oven may be starting to consume itself. I have found melted light fixtures and scorched, brittle wiring. If you can't isolate the source of the smell, it could be time to replace.
Nov 13, 2016 | Frigidaire Microwave Ovens
My mazda mpv wont turn over 1991 V6 and it smells like burnt rubber when trying to start it and it smelled liked that while running for a couple of days before it cut off
Unusual for a rubber smell could it be plastic? I would suggest possible a wiring loom that has either shorted and melted or has touched a hot component and melted. If you can smell burning with the electrics on but the engine off it is probably a shot and you may be able to trace with sight and smell with just the ignition switch in. This can cause issue with starting as it could be a feed to or from the starter, an imobiliser cable or just the ecu seeing an electrical fault and not allowing you to start. An unto electrician should be able to advise if you can't find it. You don't say if it is turning over but not firing or not turning over at all
hope this helps
Jul 05, 2014 | Cars & Trucks
Electrical burning smell coming from control panel on westinghouse dishwasher
Had the same issue with a 903sa. Strong burning smell. Continued to run for a while then just died. Opened the control panel (4 screws holding the plastic part at the top of the door on - open the door to access).
Mains feed into the controller was totally fried. Case was all melted. Very nasty. There was nothing obvious on the Board other than a mains resistor that looked like it had been pretty hot at some stage. The three pin mains connector (at least I think it was 3 pins) was just a big, charred bit of goop.
Feb 09, 2014 | Westinghouse Dishwashers
MIcrowave emits an electrical smell while cooking. It still cooks, but has started emitting an odor recently when in use.
Is the smell ionized (the outside smell of a cold winter morning air) or more of an electronic component burning??? if it's more of an ionized smell it could be normal, (if the smell is strong) it could be a leaking high voltage cable (electric arching) bad insulator, if it's more of an electronic component burning smell, it could be a overheating component, in both cases you should have it checked by a professional technician...
Cheers!
Jun 25, 2011 | Sharp KB-6024MS Stainless Steel 1000 Watts...
The breaker itself does not seem to trip completely. The power will go off to the lights and outlets on the circuit for the breaker. When attempting to reset, the breaker is not in off position, but when...
It is a clear case of metal contacts getting heated/melted/burn out due to overload/short-circuit inside. Please get the circuit breakers replaced with a new one to avoid fire hazard.
Jul 31, 2010 | Electric Electrical Supplies
Discolored terminal on cord
Check the dryer power cord for any signs of melting or charring. It could just be a loose connection. Then.....
Check the wall plug - there's a possibility the wall socket is either worn or the wiring to the socket isn't tight. The socket will need to be removed to check this, so make sure the power is off first.
Mar 30, 2010 | Amana NDE5800AY Electric Dryer
Burned plastic part on refrigerator compressor
side by side refrigerator freezer, smelled melting plastic, found a plastic box connected to the compressor burned. What is this and how much does it cost to replace?
Dec 13, 2009 | KitchenAid Refrigerators
1992 ford f150 Truck shut down at 60mph and now fuel pumps wont
Where does the fuel come from that leaks out when running? If you have dual fuel tanks and one tank is overflowing you will need to check the fuel tank switch in the dash. Ford had a problem with these that caused the fuel pump from one tank to pump fuel to the other tank and cause it to overflow. If this is the case the tank switch is probably defective.
They can get very hot and melt the wires into the back of the switch. Check the switch first.
Feb 17, 2009 | 1990 Ford F150
Overheating smell on hot wash
this may be charred wiring - most likely at the heater. take off the back bottom panel and look at the wiring at the heater
Mar 31, 2007 | Hotpoint Aquarius WD63 Front Load...
Kenmore 64802 Top Freezer Refrigerator Logo
21 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
