Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
I have a motorola modem and i wanna change it to a modem that have a 4 port switch how can i change it
    President:
  • 2,992 Answers
You really don't need to change the modem. All you have to do is add a 4-port wired router (or wired/wireless one if you want to add the wireless capability). Netgear and Linksys units are easy to find at most retailers. Simply connect the router to the Ethernet jack on the modem, then plug your computer(s) into the new router.
This is much easier than changing the modem itself. You don't need to get your service provider involved if you just add a router.
Posted on May 21, 2009
How to change password
You have to Iogin to change it. If you forgot you may have to reset first.
If you have further questions contact ARRIS
Mark
Motorola Support
Aug 17, 2014 | Arris SURFboard SBG6580 eXtreme Wireless...
I can't get ports open on my surfboard 5120 modem, the router is configured properly and it showed them open when I first set it up but they closed and now I can't get them to open again. Once after...
call 1-877-466-8646 this is motorola's tech support line. Thier agents are very very good and will either fix your issue or tell you exacxtly where to go to get it fixed. But if they need to walk you through the set up process t does cost 30 dollars, but they can tell you how to get the set up info for free if you dont wanna pay
Oct 09, 2010 | Arris SURFboard SB5120 Modem
How do i accomplish port forwarding on a motorola sb5101
motorola sb5101 is a modem. Modems don't offer any settings to change. you would have to forward ports on your router if you have one. Other wise you will have to open the ports through your current firewall.
Jul 18, 2010 | Arris SURFboard SB5101 Cable Modem
Hi i am chinni working in a bpo company. i wanna configure dhcp network in my office. can any body helps me
Hi, by default the Linksys router is set to DHCP... So all you have to do is connect an ethernet cable from your modem to the WAN/Internet port of the router and then connect a PC to one of the ports, see if that will be able to connect to the Internet if not, try to do a power cycle (turned off everything and then turn on the modem first and wait for all the lights to be stable and turn on the router and then the PC) once the computer gets online you may connect the rest... should you require to connect more than 4 PCs, you may need to have a switch but with this setup the physical connection should be
Modem to WAN port of the Router to Switch port and all PC should be connected to the Switch's ports
Mar 27, 2010 | Linksys EtherFast 10/100 16-Port Workgroup...
Need to connect my old Linksys modem to a new Motorola SBV5121 cable modem.
THE MAIN LINE GOES INTO THE WAN PORT FROM THE MODEM PROVIDED FROM YOUR MOTOROLA .....THEN THE 4 PORTS ARE TO CONNECT THE COMPUTER ....HAVE FUN
Jun 02, 2009 | Linksys Wireless-G WRT54G Router
Problem replacing 4 port hub with 8 port switch for home network.
You can obtain IP details for Preferred DNS server & Alternate DNS server from your internet service provider.
don't use automatic ip addresses.
best regards,
Krishan.
May 08, 2009 | NetGear FS108 Networking Switch
2210 modem to befsr41 router connectivity
HI
JUST GO TO THE SETTING OF ONE OF THEM AND CHANGE THE DEFULT GATE TO CHANGE THE THIRD NUMBER BY ADDING ONE OR SUB. ONE
Dec 12, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Portforwarding using a Motorola SBG900 modem
Go to portforward.com,find your router in the device list and follow the instructions. Works great for me.
Oct 12, 2008 | Arris SURFboard SBG900 Wireless Router...
Ethernet cable port does not worked only the usb port worked
Have you tried changing the lan settings, or better still use the disc that came with modem and it will auto install modem and configure settings.
Jul 27, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Motorola SB5101
ya u should have a router instead of a modem because modem provide only one ip address>and there is no DHCP server in the switch or hub>so buy one router which has 4 ether net port and connect it directly to the modem and connect ur two pc's behind the router then both will get a seperate ip address from the router both will go online
the connection is
modem-->ether net cable to the inter net port on the router-->and two ether net cable from both pc's to the 1 and 2 ether net jack on the router reboot all the devices>and modem+router+pc's then it will work>rate me solved if its helps thx
Nov 14, 2007 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
63 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
