Question about Vacuums
Hoover telios full bag indidcator
Loss of suction, hoover says the bag is full, but it is not??? filters and hose seem to be clear?
  • blackcorries Jan 02, 2014
    ps, its a bagged cylinder.
  • 55 Answers
Could be a hole or torn bag
Posted on Jan 02, 2014
reddevil6
  • 1673 Answers
SOURCE: Sudden loss of suction.
Check the inlet down by the brush roll to see if it is clogged. Also check the belt to be sure it is ok. Is there suction at the hose? If not then it is still clogged.
Posted on Feb 13, 2008
reddevil6
  • 1673 Answers
SOURCE: loss of suction and bag full
Sounds like you still have a clog, either in the hose, drop something down it to see if it comes out the other side. The other place is the dirt inlet by the brush roll. Take off either the top cover or the bottom plate and you can check it out.
Posted on Feb 19, 2008
  • 71 Answers
SOURCE: poor suction (new bag, clean filter, clear hose)
check the impeller on the moter it may be missing a fin or two (question does it make any unusual noise or vibration ?)
Posted on May 02, 2009
  • 4088 Answers
SOURCE: brush spin,good suction at hose, no suction at
Air passage from back of brush head, through the joint, and up to bag, may be blocked.
Posted on Jul 12, 2009
  • 8 Answers
SOURCE: my eureka smartvac 4870 has no suction at hose or
your eureka has no suction kuz the vacum hose needs cleaning
Posted on Nov 29, 2009
Doesn't seem to have much suction when I put my hand under the head. Have cleaned both the filter and the mesh screen
Check the suction from the hose for rge tools see if there is suction
also check to see if there is a obstruction on the short hose to the nozzle
May 16, 2016 | Hoover U5140-900 Widepath Bagged Upright...
Why does metallic cover keep blowing off when operating?
Hey there! It sounds like your vacuum may be clogged causing it to redirect the air flow which may be causing the cover to blow off. To check the vacuum for clogs disconnect the hose from the cleaner and the wand, use a broom stick to gently loosen and remove any clogs from hose. Also check the wand and the nozzle for blockages. If it is the filter cover that is coming off and there are no clogs, the tabs on the filter cover may be broken. Contact a local service center for information on replacing the filter cover. Reference part 59135033. Or you may contact Hoover Customer Service at 1-800-944-9200. Hope this helps!
Aug 27, 2014 | Hoover S3330 / S3332 Straight Suction...
Miele Vacuum Cat and Dog Upright S7260 Loss of Suction
could be a couple things first make sure the hose is clear check real good the other is make sure your bag is good and tight and clean and make sure you have no holes or tears in the hose
Mar 07, 2014 | Miele Vacuums
Hoover telios keeps saying bag full when its not
Something is plugged up making it sense there isn't vacuum and saying the bag is full
Jan 31, 2018 | Vacuums
The hose constantly falls out of the metal tube. Is there any remedy other than taping or glueing it in place?
the complete hose can be bought here for 20.00
http://www.bizrate.com/vacuum-accessories/oid1370892338.html
Feb 16, 2011 | Hoover S3330 / S3332 Straight Suction...
Telios 2000
This is normally caused by restricted airflow, causing the heat sensor switch to trip. Please make sure the hose and bag are not clogged, verifying you have good suction and airflow to the hose end when you initially turn it on. The heat sensor switch is intended to shut off the motor if sufficient cooling air is not present.
Mar 09, 2010 | Hoover Vacuums
Poor suction (new bag, clean filter, clear hose)
May 01, 2009 | Vacuums
The hoover keeps switching on and off automatically.
Sounds to me like there is either a loose wiring in the pedal or mains power cord. Check that the plug is secure. Check both filters though - one behind the bag (usually square and slides out) as well as the main exhaust filter at the back between the power on and cord rewind button. I used to own many Telios models but they are known to have cheap shearing cords which can only be replaced by a Hoover repairer. Sometimes the On pedal can be affected as well particularly if it has been stamped on heavily.
Dont forget to rate, ty.
Mar 28, 2009 | Hoover S3330 / S3332 Straight Suction...
Vacuums Logo
52 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
