Question about Gamo Pt-85 Blowback
Pellets jammed in the gun's barrel
I did a few shots with the CO2 bottle half empty and now the pellets do not come out...
  • Rui Barros
    Rui Barros Jan 02, 2014
    I've spent 3 bottles of CO2 without using pellets, but the barrel of the gun still jammed
The best way I found to fix this is to break the gun down. Once you've done that you can slide the barrel out and use a push rod to remove jammed pellets. To stop this issue, I've read to not use short skirted or pointed pellet.
Posted on Mar 06, 2014
Need parts for crosman 600 bb pellet handgun with co2 cartridge co2 semi automatic
Sorry we do not sell parts here nor do we have any parts locator services.
Jul 26, 2017 | Crosman Optics
Can't find the specs in ftbs. my Gamo .177 Bone Collector is rated a 1300ftps. How far can expect to shoot accurately with this break barrel pellet gun?
Depends on who is shooting. But just test your skills on a 75 yard range. Shooting competition, with the special competition guns are shot at 10 meters (about 30 yards) Without a scoop, they easy shoot 80 % of all pellets through one .177 hole on 30 yards.
Mar 12, 2015 | Gamo Bone Collector .177 Caliber Hunting...
My Crosman 1008 Repeat Air pistol leaks all CO2 out
The crosman 1008 does indeed fire pellets! NOT BBs. ONLY pellets.
Feb 03, 2014 | Crosman (4032)
I'd like to know how can clearing pellets that were retained in the barrel of the 85-pt
The only way I found to fix this was to break the gun down and remove the barrel. Once you do that you can use a push rod to remove the pellets. By sure to push them out the way they went in.
Jan 02, 2014 | Gamo Pt-85 Blowback
Co2 install
Your seal is probably out...
Jul 29, 2013 | Crosman Optics
What is a blowback airsoft gun?
Blowback Airsoft Guns are Airsoft weapons that seem much the same as true firearms, since genuine firearms, well some, are secured in a Blowback layer of paint or something to that effect.
The entire slide on the gun with re-cock itself consequently after every shot then generally in the wake of shooting the complete cut after the last shot the slide stays open. The main issue with these airsoft guns is they will consume through your gas. CO2 or green gas both can have blowback.
Jan 14, 2013 | Sport & Outdoor - Others
What would cause co2 not to work at times
seals are worn, not holding pressure
Sep 27, 2012 | Cars & Trucks
When i take the first shot whith my crosman 357 revolver it is full power. the second shot is about half power, and the third shot rolls out of the barrel. this does not happen though if I wait 10- 15...
try switching the CO2 cylinder if that doesnt clear up the problem then its probably a blockage of some type within the tubing from the air supply.
Apr 11, 2011 | Garden
I bought a Remington 870 at Christmas time. The first time i shot it the shells are jamming in the gun. I took it home cleaned it and oiled it real good. Went and shot it again same problem. Either...
If the 870 is a Magnum model it should accept 3" shells. After making absolutely sure you have an unloaded shotgun, both chamber and magazine are empty, empty, empty, proceed with these few checks.
Assuming it may be a 2 3/4' model, have you double checked on the left side of the barrel near the receiver? There will be gauge and shell length stampings on the barrel. If you are jamming 3" shells in to a 2 3/4" shotgun you will get jams as you describe. Look at the empty shell casings if you have any and see if the shell appears to be damaged from the chambered and firing process. This could also indicate you have a improper shell length issue.
If you are shooting reloaded ammo make sure it has been properly re-sized, crimped and reloaded.
sloppy reloading of shotgun shells can cause jams as you describe. Improperly re-loaded shells can also cause leaks of bb's, (shot) in to the receiver and bore area.
Check for a loose bb. or bb's, (shot) in the receiver and chamber area. A lodged bb. in these areas will cause problems you have described.
Run your fingers along the barrel and visually check it for any slight bulge. If you detect or suspect a bulge do not shoot or load the shotgun until a gunsmith or the factory check the barrel thoroughly. If someone had loaded a 20, 16 or similar smaller guage shell in the chamber by accident and the gun was fired it will usually cause at minimum a stressed and bulged barrel. Many times a slight bulge in the barrel may not be visually obvious.
Most of the time if a 12 gauge shell gets loaded behind that one and fired you will have catastrophic failures, i.e. the gun can blow up and cause serious harm, blindness or even death in rare cases to the shooter. Shooters call this a "20/12" catastrophic failure. This type of accident is not to be taken lightly! this is why shotgun shells of different gauges are different in color normally.
Never ever, mix shotgun gauge shells in a pouch or box.
If you pump the shotgun too easily, (i.e. wimpy) it can jam up. Always pump, "rack" a shotgun with vigor. I'm not suggesting abusive action, just don't be slow or overly gentle with the pump action that ejects a shell and reloads the next one. Something related to this is if your action/slide bar is out of alignment or has become torqued out of it's proper alignment this will cause problems as you have mentioned. The action/slide bar is a long single piece of flat metal that is in alignment with the barrel and is attached to the front forearm of the shotgun. This is the flat piece of metal that actually makes the action open and close as you pump the shotgun. There is one on the left underside of the bore and forearm of the shotgun. When you pump the action you will easily observe it moving with your pumping action.
Check how the empty action feels to you. While dry-firing, (using an unloaded shotgun), does the action feel smooth or perhaps, gritty, sluggish, overly tight? If any of the later the you need to double check for debris, shot, excessive old lubrication, gumming of the action, a bent action/slide bar, etc. A normal 870 has a very smooth action.
Also, check the bore for any obvious nicks or obstructions that don't belong there. A good quality shotgun such as your 870 should operate best with very little lubrication. Excessive lubrication over time can cause gumming up of the receiver area. Also, improper lubrication products. Improper lubrication can cause problems you have described.
I am not a gun smith. I am simply an avid gun enthusiast. If you have any doubts as to anything that you observe while performing these basic checks on your shotgun, I strongly advise you to call the factory or take it to a local gun smith. Many gun shops will give your shotgun a courtesy check over and if you don't find a solution, many times they will within a few minutes. Do not be embarrassed to take the gun in to a gunsmith! Trust me, they will most likely treat you and you gun with respect and courtesy. Otherwise they won't be in business much longer.
If the gun shop fixes your problem make sure and purchase some shells and perhaps something else from them. We must support our small business firearms dealers and gun smiths
Hope this helps you!
Feb 02, 2011 | Remington Shotgun Mount 12Ga Lh, B Square...
How do you caulk the gun brand new, never used before. lost manual
This gun is a break barrel or break action gun. Hold the stock in your left hand and pull down on the barrel with your right. Once the barrel is down you feed your pellet right into the chamber. Pull back up to set the barrel ready to fire.
Jan 01, 2011 | Crosman Optics
Gamo Pt-85 Blowback Logo
939 people viewed this question
Top Gamo Sport & Outdoor - Others Experts
Are you a Gamo Sport and Outdoor - Other Expert? Answer questions, earn points and help others
