Question about Belling XOU592 / XOU593 Electric Double Oven
Cooling fan on Diplomat ADP 4510 wont stop running
Hi, My diplomat df800 dl has an electric fan over keeps turning it's self on (it clicks on every now and again and then turns it's self off. any idea?
https://www.manualslib.com/products/Electrolux-Epee63cs-3049318.html
This web site has your owners manual. It is very vague on this condition so, I will speak in general terms. It may have a cool down function that keeps the fan running till a cooler temp is reached. It could be a malfunctioning controller. Without a wiring diagram, hard to be specific. I would call their help line. It is listed in the manual but it appears to be an overseas number. I have not located a stateside number at this time. So sorry I can not be of more help.
Sep 16, 2017 | Ovens
Diplomat ADP 5520 Stainless Steel Range not getting hot enough
The circular element that the fan sits behind heats the oven. Ensure the thermocouple is back in the right place. Too near the element and the oven will stay cool.
Circular elements can be pricey and fitting should cost no more than an hours labour.
http://www.espares.co.uk/search?SearchTerm=ADP5520%20element
Jun 23, 2017 | Ovens
My oven wont work
If your gas igniter is bad the gas well not turn on .replace the igniter
Nov 09, 2011 | Ovens
I have a diplomat 4510 electric oven, the pilot light is constaintly on even when the oven is not on,the oven does not heat up, i recently replaced the element
If you have replaced the element, and it does not heat up, then I would suspect the thermostat as being the cause of the problem, more so if it is the oven pilot light that is on.
To be certain, you really need to see if you are getting a feed to the element when you you set the thermostat.
Hope this helps.
Jan 31, 2010 | Belling XOU592 / XOU593 Electric Double...
Diplomat Softline ADP0300 Gas-just not cooking ...anything!
Hi there..
I Just recently had the same problem, also with a diplomat gas oven..
The problem I found was down to a small resetable component under the main cover. ..
It took me ages to find the problem and I had taken the whole electical parts of the oven to bits before 'accidentaly' coming across this 'thermal switch' (located inside the main cover, at the top, behind the display module).. - to reset this there is a tiny red button between the connectors.. press this - and it should all be fine again... : One importnat note is that this may be tripping as a consequence of the fan not running or by my thinking not running on after the oven is switched off, leaving the casing to heat up and then trip this switch component.. - if this component is faulty it can be found in RS components or Farnell components.. look for Thermal swich manual reset part no: L100C 9082 470.
Nov 29, 2009 | Ovens
The inner glass panel on my diplomat oven has shattered. What can I do?
My Diplomat Oven Heating element (ELEHY6075) stopped working with the FAN ON combination. I replaced it with a new one and it still does not work with the FAN option. All other combinations do work. What can I do?
Mar 07, 2009 | Ovens
Diplomat ADP3702 cooling fan problem
It could be a fuse or thermal cut out, you can test it with a meter. you should have continuity through it, if not then it is faulty.
If you do not have access to meter, then if take a piece of wire and connect it to the fan terminal and connect the other end to the origin of the ceramic fuse or what ever it is, and it should work, you are in effect bypassing the part in question.
If it still does not work then you are going to have to investigate further, or call some one in.
Plz rate my solution.
Thanks.
Jan 03, 2009 | AEG B1180-4 Electric Single Oven
Belling XOU592 / XOU593 Electric Double Oven Logo
19 people viewed this question
Top Belling Ovens Experts
ashburton
Lawrence Oravetz
Are you a Belling Oven Expert? Answer questions, earn points and help others
